    Questions about Ressourcen Monitor from 18 to 60 suddenly
    14 Posts 7 Posters 1.9k Views 7 Watching
    • GiPFELKiNDG Online
      GiPFELKiND Silver Members
      This morning I start my day with 70% resources. I went for a run at 05:30 this morning and after that my battery was at 30% and went down to under 18% in the coming hours. I then take a leisurely walk with my Family, 2 hours. Then when I got home, my vertical suddenly showed more than 60% again… suunto what’s going on here. could that be? please look at the picture, think about it and please explain to me how that can be. how exactly does Suunto calculate all this? Who knows about the team and can give a well-founded and accurate answer on this? does anyone else have such strange values ​​on the clock?Screenshot_2023-07-12-13-38-20-029_com.stt.android.suunto-edit.jpg
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race 2, Vertical 2, Race 3s Ti, SA (Beta) Android Insta: @gipfelkind
        zhang965
        How about buy a watch from another brand?
        • isaziI Online
          isazi Moderator @GiPFELKiND
          @GiPFELKiND I will respond here. Not sure how your resources got back to 60%, the only thing I could see is that your HR got back to being low. Anyway, the Firstbeat resources will be replaced by something else before the end of the year, so bug reports on this algorithm are not being forwarded.
          Ivan De RasisI 1 Reply Last reply Reply Quote 4
            GiPFELKiND Silver Members @zhang965
            @zhang965 said in Questions about Ressourcen Monitor from 18 to 60 suddenly:
            No never a Garmin 🙈 i am so happy since 2001 with suunto, i had my first Diving Computer, then so much GPS Multisport watches from SUUNTO. All worked fine 😀but actually to much bugs with the new vertical.
            • Ivan De RasisI Offline
              Ivan De Rasis @isazi
              @isazi GRAZIE PER ESSERE SEMPRE OPERATIVO E PRESENTE IN QUESTO FORUM!!!
              Suunto 9 Baro
                Egika Platinum Member
                @GiPFELKiND how does the corresponding HR graph during this time period look like?
                Did you put the watch on the charger?
                As isazi mentioned, currently Suunto is looking to replace the Firstbeat algorithm used here by a better one. I have so far not been looking at the resources calculated from my watch, but with the new algorithm this gets more interesting.
                  GiPFELKiND Silver Members @Egika
                  @Egika this is the heart rate AND Ressourcen Screenshot from this day Screenshot_2023-07-12-14-10-01-395_com.stt.android.suunto-edit.jpg
                    Egika Platinum Member @GiPFELKiND
                    @GiPFELKiND charger?
                    SuperFlo75S GiPFELKiNDG 2 Replies Last reply Reply Quote 0
                    • SuperFlo75S Offline
                      SuperFlo75 Silver Members Bronze Member @Egika
                      @Egika please tell me how it would be possible to charge the watch and get a heart rate at the same time? I cannot wear my watch when charging it… and my charge does not have any heart rate… 🤔
                      Suunto Spartan Ultra
                      SA iOS 3.13.1 (23404)
                      Instagram @superflo75
                        Egika Platinum Member @SuperFlo75
                        @SuperFlo75 good point. Though it does not answer if the watch maybe was 1min on the charger or so…
                          @Egika No charger
                            @GiPFELKiND thx - am lost now…
                            but can tell you that this is work in progress on Suunto side.
                              @Egika thank you for your answers Special on my air Quality questions 👍😊 understand it now
                              ChrisAC 1 Reply Last reply Reply Quote 1
                              • ChrisAC Offline
                                ChrisA Platinum Member @GiPFELKiND
                                @GiPFELKiND the resources jumps (up and down) are discussed here quite often and they’re not really reliable when you look at them in short time intervalls, like a single day. In the long run, they pretty much fit my personal feeling. But afaik no one at Suunto can look deeper in how the resources work, since they are Firstbeat „stuff“. I found that I can raise them significantly (about +20% ) while meditating for 30 to 60 minutes and there my HR drops to sleeplike values, so my guess is, that sudden changes in HR will influence such highs in resources .
                                Currently Race I
