    GPS Lock and Offset
    23 Posts 8 Posters 2.4k Views 9 Watching
    • stromdiddilyS Offline
      stromdiddily Gold Members
      I have recently been experiencing some longer than usual duration for my vertical to lock onto a GPS signal which has pretty much always resulted in a decent GPS drift (ie on my route just shows me running through houses).
      It’s to the point where I’m tying my shoes outside, warming up, checking the mail, etc waiting for my GPS to lock and then giving it an additional minute or two after it finally does. I’ve confirmed my AGPS is updating so not sure what else to do.
      Anyone else seeing similar results?
      zhang965Z isaziI 2 Replies Last reply Reply Quote 0
        zhang965 @stromdiddily
        @stromdiddily hello, do you mind if you can share some screenshots on your gps tracker
        stromdiddilyS 1 Reply Last reply Reply Quote 1
        • C Offline
          Chris Kusmider
          was happening to me as well, cutting thru neighbourhoods and streets. Also noticed this always happens at the start of the run/walk and then is ok. Also noticed when I paused the walk and got a coffee, after resuming the walk it cut thru the street and then was ok. Wonder if there is a glitch in initially locking into satellites with the watch.
            stromdiddily Gold Members @zhang965
            @zhang965 said in GPS Lock and Drift:
            Like this one?
            GPS was locked THEN I proceeded to tie my shoes and do my warm up before starting.
            zhang965Z freeheelerF 2 Replies Last reply Reply Quote 0
              @stromdiddily said in GPS Lock and Drift:
              Like this one?
              It looks like a dick
              stromdiddilyS 1 Reply Last reply Reply Quote -4
                freeheeler @stromdiddily
                @stromdiddily
                did this happen once or did you notice this behaviour more often?
                  stromdiddily Gold Members @freeheeler
                  @freeheeler said in GPS Lock and Drift:
                  @stromdiddily
                  This is the first time it’s done anything like this but like the title suggests I have issues basically every time I start a run w tracks being in line but offset
                    Like this one?
                    feel free to include it in your next product review
                      isazi Moderator @stromdiddily
                      @stromdiddily no, didn’t happen to me, and it sounds strange that it just started to happen to you now. I guess you already tried with a reboot 🙂
                      If this becomes a constant let us know, with logs and everything. Sony is baking GPS firmwares often recently, and the Vertical will get an update with next firmware release.
                      stromdiddilyS 2 Replies Last reply Reply Quote 3
                        stromdiddily Gold Members @isazi
                        @isazi said in GPS Lock and Drift:
                        Thank you sir. Will shoot you a DM if it doesn’t sort itself out.
                        Today on the same route, I had absolutely perfect tracks so hopefully just a one off!
                          This is quite predictable now whenever I run in a new area. First run in Mexico on vacation had pretty significant offset and a long-ish time to acquire signal. First run back home, same deal.
                          Both times I made sure to sync with the app to get updated AGPS and wait a good 30 seconds or so after GPS signal acquisition to start the activity.
                          I am willing to bet good money that my run tomorrow from the same location will lock before I can tie my shoes and have no such offset.
                          surfboomerangS Brad_OlwinB 2 Replies Last reply Reply Quote 0
                            surfboomerang @stromdiddily
                            @stromdiddily for what it is worth: I had a huge GPS drift last two days here in the neighborhood. I have never seen this in years. Rebooted the watch and hopefully it will be gone next activity.
                              No issues for me in the past few days, but next update will also have GPS firmware updates.
                              surfboomerangS stromdiddilyS 2 Replies Last reply Reply Quote 1
                                surfboomerang @isazi
                                @isazi The contours were good, but the whole track was displaced.
                                isaziI surfboomerangS 2 Replies Last reply Reply Quote 0
                                  @surfboomerang I have only seen that happen with wrong (not as not updated, but wrong) AGPS data.
                                    @isazi only time I have seen this was indeed with the huge Sony AGPS issue 1-2 years ago. Hopefully the reboot worked for the next activity
                                      e6321 Bronze Member
                                      Run yesterday had a good 20m offset as youve reported, for first 10 mins.
                                        Fingers crossed!
                                          Brad_Olwin Moderator @stromdiddily
                                          @stromdiddily This is odd, I travel a reasonable amount and this does not happen to me. For example on my last race I had not used the Vertical in quite some time. I charged it for the race and started off. The last time I used the Vertical was a week before near my home. Here is the beginning of the Race located 800km away from home. I have not seen this when traveling.
                                          stromdiddilyS 1 Reply Last reply Reply Quote -1
                                            @Brad_Olwin
                                            That’s what has me thinking there might be something up with mine. Folks are raving about the accuracy and if this was a common occurrence, someone else would have brought it up (5k, dc, etc)
