GPS Lock and Offset
@stromdiddily said in GPS Lock and Drift:
That’s what has me thinking there might be something up with mine. Folks are raving about the accuracy and if this was a common occurrence, someone else would have brought it up (5k, dc, etc)
I agree and would wait for the firmware update coming this fall. That will give you a good reboot as well. If this continues I would definitely contact support. I will look back through my files but I cannot remember an issue like this with my Vertical using either production firmware or newer FT firmware.
@surfboomerang said in GPS Lock and Drift:
@isazi The contours were good, but the whole track was displaced.
For the record.
Reboot did the trick. The recorded track is spot-on again. -
S surfboomerang referenced this topic on
@Brad_Olwin said in GPS Lock and Drift:
New firmware and after a factory reset for my battery drainage problem. Second run after all that and first at this location so basically the same symptoms as before w offset tracks
I sent my logs to Suunto today. Not sure if I have a problem but with my experience I certainly would not describe the GPS accuracy as groundbreaking or phenomenal
