    Spartan Trainer Wrist HR battery indicator show wrong level
    2 Posts 2 Posters 249 Views 3 Watching
    • R Offline
      RVIVASNA
      I have observed that the clock indicator always reflects a battery level higher than what is indicated when I connect it to the suunto application on the PC. For example, the clock indicates 60% battery and after connecting it, immediately drops to 20%. My suspicions began when, randomly, the clock was reset by pressing a button. After analyzing it for a while I saw that it only happened when the battery was close to 40% -30%. Then note that when connecting to the PC the battery level was too low and surely the problem is that pressing a button turns on the backlight and consumption goes up and when there is not enough charge the clock restarts. Can it be a problem of how the clock software calculates the remaining battery or is it a problem of the clock hardware? Why does the PC application update this battery level?
      carussC 1 Reply Last reply Reply Quote 0
      • carussC Offline
        caruss @RVIVASNA
        @rvivasna
        Me too. When you connect the cable first to the computer and then to the watch, trainer battery level goes crazy if the contact between cable and Watch is goes wrong. This happen to me while i had a screen protector and the cable did not fit well.
        Do you have a screen protector?
