    VO2 max chart
    3 Posts 2 Posters 1.3k Views 2 Watching
    • Stefan KerstingS Offline
      Stefan Kersting
      I see that my Vo2 max goes up and down over time which is quiet natural. I have periods with running and periods with other activities that are not so useful for calculating my Vo2 max.
      I have seen many different charts on the web showing Vo2 max intervals for men/women where you can find out - depending from your age - how fit you are.
      Has anybody seen the chart with the Vo2 max values that are used for the Vertical?
      • TieutieuT Online
        Tieutieu Platinum Member @Stefan Kersting
        @Stefan-Kersting Never seen the chart, but the thing I don’t understand is why walking activities are also used for V02max calculation. It’s a bit anoing to have to disconnect HR mesurement if we don’t want the VO2max value to go down…
        For sure the algorythm that estimate the VO2 uses Age/genre/HR and probably other things like NGP/pace…
        (I went on july for a full shape test in a lab (with VMA/VO2 estimation). My VO2 estimated is not very far (but above) the one I get with Suunto.)
          Stefan Kersting @Tieutieu
          @Tieutieu you can find the chart here. Wondering if Suunto uses the same for displaying fitness level on the vertical.
          https://www.suunto.com/nb-no/Support/Product-support/suunto_ambit3_sport/suunto_ambit3_sport/funksjoner/ytelseniva-av-loping/
          Good point with the developing of the fitness level. After som hiking trips the Vo2 max is dropping 😞
          It is bin said that the calculated Vo2 max is pretty near that you are measuring at a lab test
