    Reset while charging
    36 Posts 14 Posters 5.4k Views 13 Watching
    • jjpazJ Offline
      jjpaz Bronze Member @pavel.samokha
      @pavel-samokha Done, thanks!
      • Todd DanielczykT Offline
        Todd Danielczyk Gold Members @pavel.samokha
        @pavel-samokha thank you. I will check and send.
        • pavel.samokhaP Offline
          pavel.samokha
          @Todd-Danielczyk @jjpaz
          Thanks for your logs.
          Unfortunately we couldn’t pinpoint exact cause from them, but there are two things I’d like to ask you to do:
          • Try to disable WiFi on the watch (Settings -> Connectivity)
          • If issue happens again please try to send the logs as soon as possible
          Todd DanielczykT jjpazJ 3 Replies Last reply Reply Quote 3
            @pavel-samokha Will do, and thank you and the team for looking into this for us.
            • jjpazJ Offline
              @pavel-samokha Just out of curiosity (or in case it’s related), the problem arose when I connected the watch to the charger in the office where I work, and there the watch does not have any Wi-Fi network configured…
              Could it be a bug when trying to connect via Wi-Fi when connecting the battery charger?
              It would be easy to reproduce.
                Another two crashes while updating maps and connected to wifi. Captured error 1403 after it hard reset. Watch was at 81% charge and showed the same symptoms as above going from charge ring to watch face with charge icon. (logs sent to Suunto)
                Appears to be a bug with wifi and wifi is required to download maps. It would be extremely useful to allow maps to be downloaded via mobile data as well as login wifi (hotels); neither currently work with the offline map feature.
                Traveling remotely doesn’t always give a dedicated wifi connection without a login and it could be useful having different options to download maps while traveling. Personally, I have mobile data and verfication wifi much more often than I do a dedicated 2.4GHz network to use when I am traveling.
                Mff73M 1 Reply Last reply Reply Quote 4
                  Mff73 @Todd Danielczyk
                  @Todd-Danielczyk
                  You can use your phone hotspot wifi 2.4GHz to share your phone data to your watch.
                    surfboomerang @Mff73
                    @Mff73 Unfortunately that can get really costly when roaming in some countries.
                    Downloading on phone and then transfer later to the watch might be an option. This way you can use public WiFi for the download.
                      Mff73 @surfboomerang
                      @surfboomerang, OK.
                      I will try to validate (except if an expert confirm) , but I think that you can connect your phone to a WiFi network, and in parallel share a “phone” hotspot from your phone which finally will share the WiFi data.
                      I may be wrong, but I think it should work.
                        @Mff73 I’m not sure. My phone tells me it will disable WiFi when I enable mobile hotspot.
                          @surfboomerang
                          Test done, Samsung S20, connected to home wifi, mobile data turned off, phone hotspot on, and Suunto SV connected only to phone hotspot.
                          I downloaded successfully one map 😉
                          surfboomerangS 1 Reply Last reply Reply Quote 3
                            @Mff73 Ah, found it!
                            I noticed that my “wifi sharing” option was disabled under advanced settings.
                            • jjpazJ Offline
                              @pavel-samokha
                              Today I’m recharging the watch (2 weeks after the last time), battery was at 25% but tomorrow I’m travelling so better traver with full charge.
                              I’ve disabled Wi-Fi connection before charging and watch is recharging correctly with the “charging screen” (it’s 96% just now).
                                SirMcKey Bronze Member
                                Goode evening everybody,
                                today I charged the SV. It had 50% of battery at the start. At 97% the watch went blank and I had to press the upper button for 12 seconds to reset the watch. Firmware 2.30.26.
                                Greetings!
                                • W Offline
                                  wheeler @Lechamoix
                                  @Lechamoix it’s happened three or four times to me all in the last month. I assumed it just went to sleep after it charged but I only charge it a couple of minutes while I shower
                                  • pilleusP Online
                                    pilleus
                                    Today the first time, that my Vertical powered off after charging and I was forced to do a soft reset. I forgot to remove the watch from the charger after the 100 % were shown and I think this is the trigger for the bug. If I remove the watch immediately after charging to 100 % there has not been any problem until now.
                                    Suunto Vertical Black Lime
                                    Suunto 9 Peak Pro Black
