    HR sensor not always connecting
    14 Posts 7 Posters 1.2k Views 7 Watching
      be1t0n Bronze Member
      I have a S9 Baro and pair it with a wahoo Tickr. I’ve never really had an issue that wasn’t fixed by the strap just needing a new battery. Over the last couple of days I’ve found that my watch isn’t always connecting to the HR sensor when starting a new exercise despite it showing up on other devices (the Tickr supports multiple Bluetooth connections).
      I’ve tried a couple of new batteries and have deleted/reconnected the strap a number of times. The watch sees it to add it as a sensor……just doesn’t always connect to it when starting an activity.
      Any ideas?
      BrunoHB 1 Reply Last reply Reply Quote 2
      • BrunoHB Offline
        BrunoH Gold Members @be1t0n
        @be1t0n I used to have the exact same problem with Suunto Movesense HR strap. The actual sensor module (the round detachable button) was perfectly ok, but the connectivity of the belt was failing. I had bought it second hand and it was a little bit small for me, so it was under lot of stress and strain while wearing. Also all the sweat and chlorine water while were probably bad for it.
        Can’t be sure about it, but my bet is that the strap has gone bad. I am not familiar with Tickr; but can you replace the strap only?
        Compasses: M-311, A-10, SK-7
          be1t0n Bronze Member @BrunoH
          @BrunoH hi.
          You can. Strap looks fine. It’s not very old. It’s strange that everything else was seeing the sensor at the same time that the S9 wasn’t. The Tickr can link to multiple devices at once and it was rock solid on everything other than the watch.
            TiagoSPM
            once, when the battery was below 10%, the original suunto belt with new batt, never connected. No matter reseting connections. Then recharged the watch til 21%, turned off wrist HR, then back to connection! Another time, didn´t notice the batt was below 10%, out for a run with the belt, HR was recorded just on wrist… wich accuracy is always worst…
              I had this problem. Its reported and fixed on next FW update. This is a veru specific scenario it happens. Reboot fixes it
              B 1 Reply Last reply Reply Quote 4
              • TieutieuT Online
                Tieutieu Platinum Member
                I Also had a strange disconnection few weeks ago before an important race.
                The sensor of my HR suunto belt disconnected from my SV. I’ve Tried everything I could (unpairing - reappairing, changing battery, changing belt, SV soft reset, restart…). Never succedeed to connect it again. No reasons, It had worked just fine for hundred of hours and few years…
                I resigned myself to buy another sensor, It works fine. I’ll try the old sensor again someday or with my wife’s S9pp to see if it still works.
                  be1t0n Bronze Member @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos
                  Reboot of what? The watch?
                    I can also confirm this issue is the same on the Suunto Vertical
                    EgikaE L 2 Replies Last reply Reply Quote 0
                      Egika Platinum Member @be1t0n
                      @be1t0n said in HR sensor not always connecting:
                      this was meant in reply to @TiagoSPM’s comment
                        this makes me think it is rather a strap/sensor issue than a watch one.
                        Can you rule out that both BT connections are in use already?
                          be1t0n Bronze Member @Egika
                          @Egika Sensor this sensor can connect to more than one thing at a time and is connecting to everything else as expected. The watch will allow me to add it as a sensor but (usually) won’t connect to it for use during an activity.
                          When I’m at the gym it would only have my watch to connect to and nothing else. At home it would connect to my watch and to my bike trainer.
                          These all worked perfectly until recently.
                          I would agree that the issue is with the strap if it wasn’t for the fact that it connects to everything else without issue.
                            @be1t0n thank you for clarification.
                            I am out of ideas now…
                              Likarnik Bronze Member @be1t0n
                              @be1t0n happened to me as well couple of times. I had to pair sensor again. It had nothing to do with bad strap or low battery.
                                be1t0n Bronze Member @Likarnik
                                @Likarnik yeah, pairing again made no difference for me. Really odd.
