    Charging problem
    24 Posts 18 Posters 5.6k Views 22 Watching
      larrybbaker
      I have never had issues charging my Vertical. I lower the watch towards the charger. Let the charger snap to the watch and then set it down and forget it. Honestly confused why this is such an issue for some.
      SV Solar
      iPhone 16 Pro
        maszop Bronze Member @larrybbaker
        @larrybbaker Try to charge in the tent, in a mountain hut or somewhere in the field during activities.
        Well, unless Suunto watches are some kind of Samsung/Apple smartwatch for admiring the color screen, and you can charge it on the table while watching TV.
        • MiniForkliftM Offline
          MiniForklift Platinum Member
          I’m having problems with charging my SV since the last update, never had any issues before that. Currently whenever I plug it in it either:
          • Does absolutely nothing at all
          • Shows the battery percentage as if it’s charging, but then nothing happens and it doesn’t charge
          • Beeps like crazy and goes absolutely mental
          I can usually get it to charge as normal after a few ‘Power Off’ and a handful of soft resets. I’ve never seen this charging issue mentioned here which seems odd, anyhow I’m realy hoping that this will be rectified sooner rather than later. FWIW I usually charge at the start of the month and then again mid month
          SV Titanium Solar Forest
          • Alexander AvezbakiyevA Offline
            Need your help, isn’t responding, not charging phone ,like disable plug in ,plug off, this phone isn’t reply on overheat. Truly need help please, your effort also
