    Sleep Tracking with Suunto Smart Belt
    9 Posts 5 Posters 973 Views 6 Watching
    • Stoke80S Offline
      Stoke80
      Hello
      Would it be possible to do the daily sleep tracking with Suunto Vertical by using the Suunto Smart belt?
      Suunto Smart belt can measure Heart Rate and HRV.
      Or would that only be possible in connection with a third party app?
      Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S
      isaziI pilleusP 2 Replies Last reply Reply Quote 0
        isazi Moderator @Stoke80
        @Stoke80 it is not possible to use an external sensor in daily mode, you can only use an external sensor during activity.
        • pilleusP Offline
          pilleus @Stoke80
          @Stoke80 said in Sleep Tracking with Suunto Smart Belt:
          You can use Sleep as Android (PlayStore) and connect your Suunto Smart Belt for capturing hrv (then you will get a detailled statistic in the Sleep as Android app).
          https://sleep.urbandroid.org/hrv-tracking/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Stoke80S 1 Reply Last reply Reply Quote 1
          • Stoke80S Offline
            Stoke80 @pilleus
            @pilleus
            Thank you for the hint. Unfortunately I am on iOS
            • Stoke80S Offline
              Stoke80
              Can anyone recommend an app under iOS which is good to cover sleep (and HRV) with a HR belt?
              Wouldn’t mind if there is something usable for free, as I would only need it to compare with the values my Vertical gives me.
              An no worries. I won’t complain afterwards about the bad values from my SV. I really just want to compare.
              OnlyoneKenobiO EgikaE 2 Replies Last reply Reply Quote 0
              • OnlyoneKenobiO Offline
                OnlyoneKenobi @Stoke80
                @Stoke80 ha detto in Sleep Tracking con Suunto Smart Belt:
                Qualcuno può consigliare un’app su iOS che sia buona per coprire il sonno (e la HRV) con una cintura HR?
                Non mi dispiacerebbe se ci fosse qualcosa di utilizzabile gratuitamente, perché ne avrei bisogno solo per confrontarlo con i valori che mi dà il mio verticale.
                E non preoccuparti. Non mi lamenterò dopo dei cattivi valori del mio SV. Voglio davvero solo fare un confronto.
                wqeeerrc
                Suunto Ambit3 Vertical
                Suunto Spartan Sport
                Suunto Vertical titanium solar
                Suunto Race titanium
                OnlyoneKenobiO 1 Reply Last reply Reply Quote 0
                  OnlyoneKenobi @OnlyoneKenobi
                  @OnlyoneKenobi
                  Mi scuso, è andato storto qualcosa…
                  Stoke Elite HRV should works for you
                  Stoke80S 1 Reply Last reply Reply Quote 0
                    Egika Platinum Member @Stoke80
                    No problem. Many people have already compared the SV HRV data to other devices like AW or Oura ring etc. with great results.
                    • Stoke80S Offline
                      Stoke80 @OnlyoneKenobi
                      @OnlyoneKenobi
                      No worries. And thank you for the hint.
