    Suunto Peak 9 Pro (not tracking sleep and where is flashlight?)
    suuntosleep trakingflashlight
    9 Posts 5 Posters 2.1k Views 5 Watching
    • yfipohs yfipohsY Offline
      yfipohs yfipohs
      After the most recent update, the watch doesn’t take sleeping into account.
      Even when the sleep time is set and activated, it won’t recognize it.
      Before the update, it was working fine, and even the flashlight was accessible.
      I couldn’t find it in the settings to activate it, or perhaps I was in the wrong section?
      EgikaE E yfipohs yfipohsY 3 Replies Last reply Reply Quote 0
        Egika Platinum Member @yfipohs yfipohs
        @yfipohs-yfipohs are you sure that you have 24/7 HR enabled? This is required for sleep tracking to work.
          Elipsus Silver Members @yfipohs yfipohs
          @yfipohs-yfipohs For the flashlight you can long-press the bottom button to access the control panel and enable it from here.
          On my watch I set the top long-press shortcut to enable flashlight too as its very convenient
          yfipohs yfipohsY 1 Reply Last reply Reply Quote 1
            yfipohs yfipohs @Elipsus
            @Elipsus yeah for me it’s taimer. I don’t know how else to setup.
            i wrote support they never came back.
            Why make update and mess everything…
            Dimitrios KanellopoulosD E 2 Replies Last reply Reply Quote 0
              Dimitrios Kanellopoulos Community Manager @yfipohs yfipohs
              @yfipohs-yfipohs you can rollback to the prev FW if you want to
                @yfipohs-yfipohs I’m confused, you don’t know how to change the shortcut ?
                in the setting screen (long press middle button), then “customize” (second option), then last option !
                  yfipohs yfipohs @yfipohs yfipohs
                  ok got back an answer from support.
                  Apparently 24/7 HR must be enabled.
                  Before the update it was not required.
                  not it means my battery won’t last longer than 7 days with current use…
                  before it was at least 14 days…
                    @yfipohs-yfipohs ok, this is what my first answer to your post was.
                    Did you even read it?
                      Brad_Olwin Moderator @Egika
                      @Egika Was that a rhetorical question?
