    Suunto HR belt stuck
    4 Posts 3 Posters 331 Views 3 Watching
    • Stoke80S Offline
      Stoke80
      Hello
      Yesterday, my HR belt got stuck mid training:
      Also the time spent in the different zones was not recorder anymore.
      Has anyone experienced anything similar so far?
      Have I done something wrong? Or might this just happen?
      I mean it is not a big thing, although my HR rate got pretty high during the rest of the training and I was curious how high it went. Now I can’t figure it out.
      Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S
      • GiPFELKiNDG Online
        GiPFELKiND Silver Members @Stoke80
        @Stoke80 i would try to change the batterie… I had something like this when the Batterie goes empty. Try it and give us a message if it helps 👍
        Stoke80S 1 Reply Last reply Reply Quote 1
        • Stoke80S Offline
          Stoke80 @GiPFELKiND
          @GiPFELKiND
          Thank you for the advice. So far I only had a problem twice with my HR belt. Once, some months ago, it showed way to high readings. Plus getting stuck yesterday.
          I know it has been discussed somewhere else, but do you know if the the app BT Inspector (iOS) can help to check the battery status of the sensor?
          Or is there even a better app?
            DF130 Bronze Member @Stoke80
            @Stoke80 I use LightBlue but I guess there are plenty of apps that can read the battery level.
