    No fitness performance level no VO2 max in Suunto Vertical
    15 Posts 9 Posters 3.1k Views 10 Watching
    • Przemko Karpinski 0P Offline
      Przemko Karpinski 0
      Re: Suunto Vertical does not assess fitness level
      Hi
      I just updated my watch (vertical) and my VO2 max and performance level was gone
      I had to hard reset 3-5 times my watch in order for it to pick up calibration of walking and running. What i did I used for each time basic run for around 30 mins and after 5th reset it said right away after finishing activity that walkinf and running was calibrated. Hope it helps;)
        Brad_Olwin Moderator @Przemko Karpinski 0
        @Przemko-Karpinski-0 You do not need to reset to calibrate.
        Vector/T6c/Vertical 2 Ti
        Przemko Karpinski 0P 2 Replies Last reply Reply Quote 1
          Przemko Karpinski 0 @Brad_Olwin
          @Brad_Olwin
          It seems it told me that walking and running is calibrated but still no fitness age or performance or vo2 max… hopeless
            @Brad_Olwin
            Whacha mean?
              @Przemko-Karpinski-0 you do not need to hard reset for calibration. You need good quality HR with sufficient intensity.
              Przemko Karpinski 0P 1 Reply Last reply Reply Quote 0
                @Brad_Olwin
                This is so imprecise . Manual says one walk or run for at least 30 mins - you say couple of good variety HR runs but no e of this works . It seems we need to wait for another software update.
                BrunoHB 1 Reply Last reply Reply Quote 0
                • BrunoHB Offline
                  BrunoH Gold Members @Przemko Karpinski 0
                  Suunto’s manual is notoriously vague and often out of date. The support gave me the exact requirements when I demanded explanation:
                  • 15 to 20 mins walk or run
                  • perfect HR and perfect GPS tracking. Any glitches will ruin VO2max
                  • at least 8 minutes of zone 3 HR (don’t know if it needs to be continuous)
                  Even with these instructions I am still missing my VO2max in Vertical.
                  Compasses: M-311, A-10, SK-7
                  Przemko Karpinski 0P ? K 3 Replies Last reply Reply Quote 0
                    Przemko Karpinski 0 @BrunoH
                    @BrunoH
                    Disaster🤦🏽
                      A Former User @BrunoH
                      @BrunoH Are we sure that walking activities produce VO2max estimates? Since the new update my walking activities don’t have any estimate, only running. It also says Running VO2max in the watch. Just wondering.
                      BrunoHB Marton AttilaM 2 Replies Last reply Reply Quote 2
                      • BrunoHB Offline
                        BrunoH Gold Members @Guest
                        @tomasbartko I have no idea. I just repeated what Suunto support told me. Like I said, I still haven’t seen a single VO2max measurement in my Vertical.
                        • Marton AttilaM Offline
                          Marton Attila @Guest
                          @tomasbartko Walking doesn’t produce VO2max estimates anymore. Thank god for that. It was completely unnecessary and it would only mess up with the running.
                          As for running I’ve noticed it that the VO2max updates every 2 weeks if you run consistently every week. For me it works.
                          • K Offline
                            kawdenco @BrunoH
                            @BrunoH
                            Hi there. I’m frustrated that my watch quit giving me vo2 max and equivalent age numbers too. Their literature tells me it’s supposed to do this, and it’s not. In fact, when I first got the watch, it was working. Really weird that it quit working.
                            Mouse CruiserM 1 Reply Last reply Reply Quote 2
                            • Mouse CruiserM Offline
                              Mouse Cruiser Bronze Member @kawdenco
                              @kawdenco same for me. Regardless of sport and intensity, the parameter is always the same from november 2023 (more than half a year). Apparently something went wrong with one of the upgrades and the watch no longer calculates it, but shows the value from the last saved value or from the internal memory.
                              Suunto 9 Baro
                              Suunto Spartan
                              Suunto Ambit3 peak
                              segi_pnS 1 Reply Last reply Reply Quote 0
                              • segi_pnS Offline
                                segi_pn Bronze Member @Mouse Cruiser
                                @Mouse-Cruiser Looks like we have the same problem. My VO2 max is still 46.3 and the run estimate is completely out of sync with my actual fitness level. Is there any way to restart this? I’ve had two firmware updates since I started using it and it’s still the same.
                                Suunto Core (17y)
                                Suunto Vertical Ti
                                • Stefano M64S Offline
                                  Stefano M64 Silver Members
                                  after more than one year, my Race showed me the VO2max only after having walked (using the Walking activity) for the first time with the Suunto Smart Belt. Another subsequent walk and short run with the HR belt showed the VO2max as well.
