    Using Timer/Stopwatch function simultaneously is not possible...
    feedback
    2 Posts 2 Posters 769 Views 2 Watching
    • Christian MogensenC Offline
      Christian Mogensen
      Greeting from Denmark!
      I am very sad about the fact that the use of the Timer/Stopwatch function simultaneously is not possible…
      I would be very happy if I could split them up and use them both at the same time. You know, start a timer and then use the stopwatch function at the same time XD.
      Thank you very much.
      brechtvbB 1 Reply Last reply Reply Quote 2
      • brechtvbB Offline
        brechtvb Bronze Member @Christian Mogensen
        @Christian-Mogensen To add: the stopwatch lacks timer function.
        Better to split the timer widget to timer & stopwatch widget.
        If there is a lap timer, timings and laps can be stored as a log, but not as an activity (obviosuly).
