    Shimano Di2
    53 Posts 17 Posters 5.6k Views 16 Watching
    • Raimo JärviR Offline
      Raimo Järvi @Wilderlicht
      @Wilderlicht BLE issue with Shimano devices should have been fixed in software update 2.37.34. What is your Suunto Race software version?
      Pragmatic Programmer
      WilderlichtW 1 Reply Last reply Reply Quote 0
      • WilderlichtW Offline
        Wilderlicht @Raimo Järvi
        @Raimo-Järvi ! The version on my suunto is V2.37.34.
        Raimo JärviR 1 Reply Last reply Reply Quote 0
          @Wilderlicht Then I don’t know what the problem is. You could try restarting the watch, probably doesn’t help but worth trying.
          SuuntoPlus store says Di2 app has been last updated in June. @pavel-samokha Could you check that latest Shimano apps have been activated in SuuntoPlus store?
          pavel.samokhaP 1 Reply Last reply Reply Quote 1
          • pavel.samokhaP Offline
            pavel.samokha @Raimo Järvi
            @Raimo-Järvi No, they were not. Activated now, thanks!
            • Stoke80S Offline
              Stoke80
              Will there be something similar for SRAM AXS ?? Would be great.
              Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S
                Egika Platinum Member @Stoke80
                @Stoke80 has been discussed before. not possible, as SRAM does not open their protocol for external development
                Run Lime
                Ze StuartZ 1 Reply Last reply Reply Quote 1
                • Ze StuartZ Offline
                  Ze Stuart Gold Members @Egika
                  @Egika surely we could have gear and battery information recorded and displayed? Garmin and Wahoo both do this for SRAM.
                  https://zulusierra.co
                  EgikaE Raimo JärviR 2 Replies Last reply Reply Quote 1
                    Egika Platinum Member @Ze Stuart
                    @Ze-Stuart said in Shimano Di2:
                    then SRAM opened their communication for those companies. Not so for Suunto.
                    Run Lime
                      Raimo Järvi @Ze Stuart
                      Battery information is probably a standard BLE service, but gear information is in SRAM specific format / protocol.
                      @Wilderlicht You could try again now that SuuntoPlus Di2 app has been updated.
                        @Raimo-Järvi Thank you, it works 😉
                        • Stoke80S Offline
                          Stoke80
                          When I start a new Cycling training, the DI2 is shown in the Suunto plus menu.
                          But nevertheless, I have to activate it manually in that menu every time before I start the training (even when it was used in the last training session).
                          Is that the normal behavior?
                          • W Offline
                            wachutunai
                            My Suunto 9 crashes every time I enable the Shimano Di2 App in a cycling activity.
                            I managed to isolate the problem by starting a cycling activity with no sensors connected, that is, no GPS, HR belt/wrist, power meter, cadence/speed.
                            As soon as the Shimano Di2 App is enabled in a cycling activity, with or without other sensors connected, the watch crashes (and soft resets) after a couple of seconds from starting the activity.
                            Any other connected sensors combination in a cycling activity works without issue (GPS + HR belt + Power, or GPS + Power + Speed , etc.).
                            This behaviour is consistent and happens every single time I enable the Shimano Di2 App.
                            It started about a week or so ago but worked fine in the many cycling activities that I have recorded in the past with the Di2 App enabled.
                            I have tried without success:
                            • Soft reset the watch.
                            • Re-pairing all sensors.
                            • Hard reset the watch.
                            I run the latest firmware in my Shimano Ultegra 12 speed set-up:
                            • RD-R8150: version 4.2.3
                            • FD-R8150: version 4.1.1
                            • ST-R8170: version 4.2.2
                            • BT-DN300: version 4.2.0
                            Any guidance would be much appreciated.
                            Cheers!
                            • C Offline
                              chesini @tuxella
                              @tuxella
                              Where can I set the d-fly channels?
