    Shimano E-bike systems
    64 Posts 20 Posters 10.8k Views 21 Watching
    • Raimo JärviR Offline
      Raimo Järvi @kuba1234
      @kuba1234 and @MikkoKartano Thank you for the logs. You both have a similar issue where watch connects to bike, but is then disconnected and connected again repeatedly. We made a small fix to the SuuntoPlus app, let me know if it works better now.
      Watch should reconnect to bike or any other Bluetooth device after you turn it back on, or if you have been out of Bluetooth range.
      Pragmatic Programmer
      K Günter ThurnerG 2 Replies Last reply Reply Quote 3
      • K Offline
        kuba1234 @Raimo Järvi
        @Raimo-Järvi Hello! Thanks for your help with new software version. After update my Vertical connects with no issues to the bike. However now no data is transferred to the watch. During my ride only speed was displayed all the time.
        I tried then at home several times to reconnect and:
        • 3-4 times there was only speed or completely no data
        • one time there was all the data except speed 😉
        lack of speed is probably because weak or no GPS signal indoor.
        I’ve uploaded my logs again.
        Thank you very much for your great support! 🙂
          ttsirkia
          I tried with my bike now with this May 14th release. Earlier, the watch couldn’t connect to the bike at all (although the BT icon appeared in bike’s display) but now I see the watch gets the connection for one second, loses it, connects again etc.
          I need to debug this more tomorrow.
          PS. I have E-Bike with Di2 electric shifting, how the both could be applied or could E-Bike also collect the gear information in the future?
            GPpov
            Since yesterday I am the owner of a Suunto Race, installed new firmware and everything is set up.
            After several attempts, the watch connected to the bike.
            But the clock showed nothing except speed.
            Everything back to factory settings and the whole thing again.
            What I noticed was when I reconnected. The BT signal was briefly interrupted. So I tried the whole thing several times and in the end it worked
              GPpov @GPpov
              @GPpov said in Shimano E-bike systems:
              This is what the whole thing looks like now
              • MikkoKartanoM Offline
                MikkoKartano
                Yep… Now it looks like watch and bike connects but watch shows only speed (witch propably is not coming from bike?) Maybe i will also take a fresh start for watch and reset it.
                Raimo JärviR 1 Reply Last reply Reply Quote 0
                  Raimo Järvi @MikkoKartano
                  @MikkoKartano You’re right, speed is not coming from bike. Watch and bike connect initially, but then Bluetooth keeps disconnecting and therefore there’s no info shown in watch. I still don’t know what causes the disconnections, and resetting your watch may not help with it (but I can’t be sure).
                  T K 2 Replies Last reply Reply Quote 1
                    ttsirkia @Raimo Järvi
                    I have still the same problem after all debugging. Where is exactly the option to send logs to Suunto? I tried to follow the instructions for Android but in Suunto 9 Peak view opened from the watch icon in the app, the menu gives only an option to show information about the watch.
                    Android app version is 29.4.2024 (Beta version).
                      Raimo Järvi @ttsirkia
                      Click user profile in top left corner, then Settings, and Send Logs to Suunto should be at the bottom
                      T 2 Replies Last reply Reply Quote 0
                        @Raimo-Järvi said in Shimano E-bike systems:
                        Thanks, now I found it. I tried to follow these instructions without success:
                        https://www.suunto.com/fi-fi/Tuki/faq-articles/suunto-app/diagnostiikkalokien-lahettaminen-suunto-appin-android-versiosta/
                        I’ll replay the issue again in the evening and submit the logs for analysis. Thanks for your help!
                          @Raimo-Järvi I submitted now my logs. The start of my Gmail address is teemu.sirkia. Thanks for your assistance!
                          • Günter ThurnerG Offline
                            Günter Thurner
                            Hello E-Bike system developers. I tried to connect my Shimano EPS-8 Ebike with my Suunto 9 and ended up with the issue described earlier. The watch changes between connected and disconnected constantly like an permanent loop. After some second the screen goes back to the level where I choose my APPS. My Suunto is on the latest release V2.26.8. I sended my Diagnose Data using Suuntolink from my computer. Hope you find a solution. Regards Günter
                              Günter Thurner @Raimo Järvi
                              @Raimo-Järvi
                              I already made a post about my issue yesterday. I have the same issue on Suunto 9 that whatch says connects and disconnects for several time before connection closes. I found no way to install newer APP neither from APP Store for ebike APP nor the suunto APP itself or a later version than 2.26.8.
                              Any other suggestion how to resolve?
                              Regards
                              Günter
                              • K Offline
                                @Raimo-Järvi Maybe this information will be helpful:
                                1. Before last update:
                                • there was issue to connect watch to bike, multiple restarts were necessary to do this
                                • after connection was stabilized all the data was shown on the screen.
                                1. After last update:
                                • watch connects to bike instantly
                                • after connection no data is shown
                                Maybe last update corrected the connection issue and somehow damaged data transfer…?
                                  loviso70 @kuba1234
                                  Anche con ultimo aggiornamento di oggi, si connette dopo vari tentativi e, i dati spariscono dopo poche secondi
                                    @ttsirkia Thank you for the logs! And apologies for the wrong instructions in our web site. I guess Suunto app user interface has been updated, but not the instructions. Did you have heart rate belt and/or other Bluetooth sensors connected to the watch when the problem occurred?
                                    @kuba1234 Thank you, I think both issues are manifestations of the same problem (Shimano Bluetooth device is continuously disconnected and reconnected). Last update moved the problem to a later stage and maybe made things worse.
                                      No, no other devices. Just the bluetooth connection to the bike and BT connection between phone and the watch. I didn’t try to switch of the BT of the phone.
                                        GPpov
                                        Ich habe nun meine erste Uhr zurückgeschickt, selbst nach dem letzten Update war keine Verbindung über Bluetooth möglich, bzw hatte sich die Uhr kurzfristig mit dem Fahrrad verbunden und sich dann aber sofort wieder getrennt.
                                        Dasselbe Problem nun mit der zweiten Uhr, die Bluetooth-Verbindung bricht sofort wieder ab.
                                        Jetzt habe ich ein Lock file von der neuen Uhr an Suunto gesendet, mal sehen ob ich eine Antwort von Suunto bekomme
                                          Boss-Hogg-450
                                          @Raimo-Järvi Seeing how this thread hasn’t been updated recently, I just wondered if there have been any fixes / updates to the shimano watch and bike connection issues as detailed by others. I know there was a bluetooth connection update for verticals and race models not so long ago, just wondered if that made any difference. Many thanks.
                                            Raimo Järvi @Boss-Hogg-450
                                            @Boss-Hogg-450 Fixing the issue with Shimano e-bike and Di2 SuuntoPlus apps requires another Bluetooth update in the watch. Unfortunately it can’t be fixed just by updating the SuuntoPlus apps. Fix hasn’t been published yet, we’ll post an update here when it’s published.
                                            F 1 Reply Last reply Reply Quote 5
