    Night battery consumption (5%)
    6 Posts 3 Posters 775 Views 5 Watching
      Luis Andés Olmedo Bronze Member
      Hello all!!
      I am back to Vertical from F7X since 4 days ago and I do have an issue with night battery consumption…
      During the day the Vertical (No solar) is consuming ±4% including daily workout, that is very good! but during the night it is wasting ±5% while laying on the table.
      I leave it on the table facing down (to prevent the HR sensor from turning on from time to time). Night tracking OFF, DND mode OFF.
      Any idea? thank you!!
      Mouse CruiserM 1 Reply Last reply Reply Quote 0
      • Mouse CruiserM Offline
        Mouse Cruiser Bronze Member @Luis Andés Olmedo
        @Luis-Andés-Olmedo I would suggest going through the settings again and temporarily turning off as many things as possible and observing the behavior of the clock. In particular, I would pay attention to the button and screen lock, automatic backlight, tones and vibrations, Bluetooth connectivity etc. In case that situation will inprove, you can find failure step by step.
        Suunto 9 Baro
        Suunto Spartan
        Suunto Ambit3 peak
          Luis Andés Olmedo Bronze Member @Mouse Cruiser
          @Mouse-Cruiser thanks!!! I’ve activated auto DND mode from 23:00 to 6:00. I’ll check tonight if something changes…
            Luis Andés Olmedo Bronze Member @Luis Andés Olmedo
            Update: night consumption 0%, awsome!!
            I left the watch on the table at 22:00 with 78% battery and took it at 6:00 with 78% (I assume consumption has been more than 0% but less than 1%).
            What did I change: DND mode auto from 23:00 to 6:00 and left the watch laying on its side, not with the screen facing down.
              Tieutieu Platinum Member @Luis Andés Olmedo
              @Luis-Andés-Olmedo Just to let you know : with sleep tracking ON (so h24 HR Tracking on), and DND from 23:00 to 7:00, consumption is very low too.
              (Don’t forget also that if your watch is new, it needs few cycles to properly calibrate battery)
              On use : SV1 Ti Solar, SRs3, SRs, S9pp Ti sand, Suunto Wing & Spark
              As collector : S9B titanium Ambassador edition, A3P, X6
                Luis Andés Olmedo Bronze Member @Tieutieu
                @Tieutieu said in Night battery consumption (5%):
                Thanks!! I do not like to wear any watch while sleeping 🙂
