    Maps are sluggish and have low update frequency
    44 Posts 12 Posters 3.4k Views 13 Watching
      borgein @Boss-Hogg-450
      @Boss-Hogg-450 said in Maps are sluggish and have low update frequency:
      @borgein I’ve read your description of the isuue, and know exactly what your talking about. I noticed the issue when i first got my vertical in Feb. The map has only ever been latency/lag free for me when i’m stood still and rotating on the spot, any directional movement initiates the watches 1 second gps recording and update model. If you have 2 watches, surely if you “hard reset” the original watch it will have reverted to the original build version of the firmware, and enabled a direct comparison with the new watch running on the current firmware?
      The videos others have uploaded only serve to illustrate the range in peoples perception/opinion of “lag/letency” The guy who’s vertical ran butter smooth when walking was completely oblivious to the 4 clearly visible and separate frames it took for the watch to perform a 90 degree rotation when he changed direction. Either that or he is in-fact a pigeon,lol. Everyone’s watches are gonna be the same, for the most part it’s the interpretation that will vary.
      For what it’s worth, i also wish the refresh-rate was a little higher, to help smooth things out on the map screen. I fail to see how different sport modes will yield any differing results, given they all use the same base GPS presets…but give it a shot i guess.
      I agree with you, and it seems we have the same experience. The first watch I hard reset was only reset so that all settings were wiped, but a hard reset does not downgrade the firmware to an older version.
      Maybe this has always been there (I got my first one in feb-march sometime too), but maybe it has become more noticeable lately? I’m not sure. The annoying thing is the lack of consistency. Today I walked a distance of 14 kilometers up and down a mountain (650m climb up/down) in clear blue skies. No cell coverage or nothing that can cause interference. T-shirt only as it was pretty warm. I also used a chest strap instead of the built-in heart rate sensor, not that I think that makes a difference.
      Sometimes the maps was laggy. Sometimes surprisingly so they were not. If I went down to 50m scale then the map seemed smoother, but when I went back to 100m and 200m zoom levels the map became very slow while moving again. When I stand still and turn in a circle-like motion the maps become very smooth again. But as soon as I have started walking and have taken 2-3 steps the maps become very sluggish again.
      I haven’t had the ability to test “faster activities” yet. Maybe I’ll try tomorrow.
      Suunto App username: borgeindergaard750
      Sportstracker (Suunto App) profile: https://www.sports-tracker.com/view_profile/borgeindergaard750
        Boss-Hogg-450 @borgein
        @borgein Ah, thats a pitty about the firmware. Didn’t realise that was the case. It would have been the definitive way to compare them. See how the different sport modes fair i guess… By the way, I see no perceivable difference between the map behaviour; either just using the map widget alone, or when recording an activity and using the map…all the same for me.
        • Stanislav DamjanovS Offline
          Stanislav Damjanov
          Has anyone found solution for this problem? Or, at least reason why it’s happening? I experience slow map movement until I make full 360 degree rotation just like OP stated. After that map “unlocks” smoother performance, only until I start walking or breadcrumb navigation screen shows up again. It’s really frustrating, I had Race S before and this doesn’t seem to be happening on Race S, map performance was always smooth.
          B EgikaE 2 Replies Last reply Reply Quote 2
            borgein @Stanislav Damjanov
            @Stanislav-Damjanov said in Maps are sluggish and have low update frequency:
            No solution here yet. The last 2.37 update didn’t fix it either.
              Egika Platinum Member @Stanislav Damjanov
              still very likely magnetic interference…
              Stanislav DamjanovS B 2 Replies Last reply Reply Quote 0
                Stanislav Damjanov @Egika
                @Egika But if I use only map, without activity started, this doesn’t happen, so I suppose that it’s something else. It’s very irritating, mapping is one of the main reasons I bought this watch. Also, I had Race S for a while, and I didn’t had this problem.
                  @Stanislav-Damjanov interesting. Can you reproduce it?
                  Regardless how long the route is?
                  I have to check myself as well.
                  Stanislav DamjanovS 1 Reply Last reply Reply Quote 3
                    @Egika I will go for a hike in a day or two and I will report how it behaves. I can make a video and post it here. It’s really strange, it hardly detects movement, but after that 360 degreee rotation everything is smooth again and watch reacts even for smallest movement, as it should be. Compass is calibrated off course. I have tried it on 15-20km routes, it’s not that they are especially long.
                    EgikaE sebchastangS 2 Replies Last reply Reply Quote 2
                      @Stanislav-Damjanov I know exactly what this looks like.
                      My setup was, that I was on my bike. My drink pack had a tube that attaches to the chest belt using a magnet.
                      Whenever I was raising my arm to look at the map it came close to the magnet on the tube and I saw exactly what you describe.
                      When I tucked away the tube, the strange behavior was gone and with routing still on, the map was smooth all the time…
                      Stanislav DamjanovS 1 Reply Last reply Reply Quote 0
                      • sebchastangS Offline
                        sebchastang Silver Members @Stanislav Damjanov
                        @Stanislav-Damjanov I have noticed the same thing during hiking activities.
                        I confirm map rotation was smoother before 2.35.34 firmware update.
                        Suunto Traverse
                          @Egika i am pretty sure that I didn’t had anything magnetic with me on those hikes. Even if I did, it wouldn’t go away everytime with that simple 360 degree rotation. I can assume that there is some sowtware bug. Is there some way to request from Suunto to investigate this issue? It’s really annoying, smooth navigation is one of the main reasons why I bought Suunto instead of Garmin.
                            @Stanislav-Damjanov if you can reproduce it, you can send logs right after the activity.
                            Then PM me with your Suunto account email address and the date and time you sent the logs.
                            I can then add this into Suunto’s bug tracking system for further investigation.
                            Stanislav DamjanovS 1 Reply Last reply Reply Quote 1
                              @Egika Thank you for replying. I did a quick walk last night and the problem persists. I made a 10km track on Suunto app and uploaded it to the watch. Most of the time navigation was buggy, map didn’t rotate even on 90 or 180 turns. If I was running it would be pretty unusable. Same as other hikes, compass was “unlocked” eventualy, and stayed unlocked for a while. This time activity was “Walk” Instead of “Hike” if that makes any difference.
                              Previously I had Suunto Race S with 2.35 firmware and it was working smooth as it should be. The day I bought Suunto Race firmware 2.37 was available, so I used Race only on 2.37, I don’t know if it behaved normally on previous firmware.
                              I guess I cannot send logs now when activity is already saved. I will try to do that after next hike and report it to you.
                                @Stanislav-Damjanov thank you very much!
                                Yes, the logs should be sent no more than a few hours after something was happening.
                                If possible you could possibly even take a video from the effect.
                                  @Egika I will as soon as I finish my next hike, and I will make video how the watch behaves.
                                    Stanislav Damjanov
                                    I just finished hike. This time activity was “Hiking”, route was made in Suunto app and sent to watch, with turn by turn navigtion option selected. Navigation sometimes didn’t had any delay, and “unlock” usually happened when a 90 degree turn was made, but many times it was 5-6 seconds delay until map started to rotate smoothly. I am uploading logs from the app right now, and I am sending a PM to @Egika.
                                      Stanislav Damjanov
                                      Here is the video how it looks like, compass doesn’t detect rotation at all. I talked with @Egika about this, and it seems that it is like that intentionally, compass doesn’t work until I stop moving.
                                      https://youtu.be/bDwDqwvQ_nc
                                      I think that compass should detect rotation even when I am moving, can anybody else confirm if that was normal behaviour on previous firmwares?
                                      SamuelPS 1 Reply Last reply Reply Quote 1
                                      • SamuelPS Offline
                                        SamuelP Bronze Member @Stanislav Damjanov
                                        @Stanislav-Damjanov
                                        Normal behavior also on my vertical since i bought it july 2023.
                                        Personally I like it the way it is right now. It shows me the direction im moving. When i stop the compass takes over smoothly
                                        Vertical All Black
                                          As already said, while you’re moving direction from gps is used. Compass kicks in while you stop.
                                          This is a way to preserve battery charge, afair
                                          Suunto App Android 6.3.3 beta
                                            Stanislav Damjanov
                                            @Samuel-Pirttikangas @sartoric Thank you for reply. I understand that it is designed as a feature, but it really looks like a bug in the real world scenario. It would be nice to disable it as an option. Is this the same even in the “Running” activity? For that use case it would be really annoying of you have to stop in order to use compass.
