    Hard water and lime residues
    4 Posts 2 Posters 577 Views 2 Watching
      Luis Andés Olmedo Bronze Member
      Hi!!! question about hard water and white lime residues in the watch…
      How do you remove it? since 9 months ago I live in Bavaria and water here is very hard. Is there an easy way to remove the residues in the black areas of the watch?
      Maybe @pilleus can give me some hints…
      Thanks!!
        GiPFELKiND Silver Members @Luis Andés Olmedo
        @Luis-Andés-Olmedo i tryed it to remove with Pure Citric Acid. And it works very good for me. But not so much Like cleaning some Coffee Machines. I only take a little piece of it to 200ml water. Only so much like in my Picture. And i leave it in the warm water for 2-3 minutes. After that i clean it SOFTLY with teath bruth and little bit soap. After this i clean it with clear water and make it dry. Hope i can help you! 😊 Be careful, start with very little Pure Citric. If it doesnt work good enough you can take more Pure Citric. Until it s good enough for you! ☀️the results from my Vertical i show Here too. For your information this is all your own risk!
        1000221462.jpg!
        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race 2, Vertical 2, Race 3s Ti, SA (Beta) Android Insta: @gipfelkind
          Luis Andés Olmedo Bronze Member @GiPFELKiND
          @GiPFELKiND thank you!!! could the citric acid harm any plastics or joints? maybe not as it is also used for coffee machines…
            @Luis-Andés-Olmedo dont know. Use only a little bit. You handle with your own risk.
