    Suunto ZoneSense
    955 Posts 146 Posters 186.0k Views 124 Watching
    • althaea35A Offline
      althaea35 Bronze Member @herlas
      @herlas Thank you for your response.
      I have been monitoring the quality of the data using Runalyze for all runs, and the results have been good with low noise. Generally, I use the Suunto MoveSense strap, but have tried switching it up with a polar H10 for a few sessions to vary the data sources. The results show consistent trends, with a number of long threshold intervals and progression runs in the bag (I have posted results from another session earlier in this thread).
      I am interested if there are outliers (physiologically) or maybe my baseline data is corrupt?
      Suunto M5, Quest, Trackpod, A2S, SSU, S9B, S9P, Race
      Garmin 305, 60, 405, Fenix 2, 945, 955
      Polar M430, Vantage V
        Jaakers @althaea35
        @althaea35 : I have the same kind of results in my graphs.
        Would like to understand this also.
        Using a polar H10 strap.
          Egika Platinum Member @pilleus
          @pilleus said in Suunto ZoneSense:
          If this is the case and the baseline recalculated after the activity on Suunto servers is not synchronized into the watch, then the live display on the watch would be pointless for me … 🤔
          actually this is what is supposed to happen: the baseline is synced back to the watch.
          pilleusP 1 Reply Last reply Reply Quote 1
          • pilleusP Offline
            pilleus @Egika
            @Egika said in Suunto ZoneSense:
            Synced back to all watches? I use the Vertical and the 9PP with ZoneSense … 🤔
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
              far-blue Bronze Member @pilleus
              @pilleus I would expect the ZS baseline to be updated as part of the SuuntoPlus sync step whenever you do a sync - assuming the ZS SuuntoPlus app is installed on the watch being sync’d.
              • pilleusP Offline
                pilleus
                Walking on a 13 % incline and running on a 3 % incline ️on the treadmill.
                Intervals of 2 minutes walking and running. ZS also shows me a conclusive graph here. 👍
                  Is there a way to increase the font size a bit? After a certain amount of time, I have trouble reading the values while running.
                  • herlasH Offline
                    herlas Silver Members @Guest
                    @iterumtenta no font size is adjustable in any Suunto screen, I’d like to see changes but we don’t know if it’s being considered unfortunately.
                    SRS Ti
                    Galaxy Z Flip 3 / Galaxy S24+
                      AntoniusGaius
                      Hi friends, after some weeks of testing, I can’t find the connection between ZS in watch and app. On the watch it seems to work most of the time. APP shows nonsense 100% of time. I don’t catch this. If this should show us “real time effort”, what it does most of the time, why in app is not only the mirror what was measured by the watch. I saw here something about recalculating on the suunto servers but… really? How can be real time effort recalculated on the server? Then it can’t be real time… or? I don’t know guys, I think that this is very poorly explained.
                      If I don’t want to use it anymore, is there any possibility in the app to turn this thing off? It is always as default in the graph. I need to use strap for 100% activities if I don’t want to have absolutely random HR data, so in every activity I have this nonsense graph as default. In the watch it is easy, just don’t use S+ app.
                      Below example, it is like this 100% of time. In the watch there are some times measured in zones, in app 100% Z1. It definitely wasn’t 🙂
                      It is good idea by design, but does not work yet, it should be presented as beta I think.
                      SUUNTO M2 - retired, SUUNTO M5 with bike pod - retired, SUUNTO Ambit3 Peak Sapphire customized, SUUNTO Spartan Trainer - retired, SUUNTO 5 Peak, SUUNTO 9 Peak Pro Titanium, SUUNTO Race S
                      • pilleusP Offline
                        pilleus @AntoniusGaius
                        @AntoniusGaius
                        I use ZS too. For me there is a minimal difference between watch and app, but only in the summary of the times in different zones.
                        I have never seen such straight horizontal lines between two points as in your graph. I think that data are missing or bad in these areas?
                        H 1 Reply Last reply Reply Quote 2
                        • H Offline
                          halajos Bronze Member @pilleus
                          I also think that may be the reason. @AntoniusGaius you can check your data quality in Runalyze (requires free account).
                            AntoniusGaius @halajos
                            @halajos OK, I did, but I can’t interpret it:
                            In Runalyze it says that max HR during exercise was 149 vs. SA says 155 (much more possible) It looks weird because this and SA data are not matching. I would appreciate to turn this thing off instead digging in inconsistent and unreliable data.
                            Strap is Suunto smart sensor - I have two of them - reliability is not high. I did half marathon last month an whole race I had no HR data at all. I had to re-pair sensor and since this it works +/- well. Frustrated again. I miss old good days with Ambit and Movescount.
                            Anyway thanks for help. Appreciate this.
                            H sartoricS 2 Replies Last reply Reply Quote 0
                            • H Offline
                              halajos Bronze Member @AntoniusGaius
                              @AntoniusGaius this clearly shows bad quality data. It should look like a narrow line, instead of scattered points all over like this. There are some sections of good data, where you see a line in your chart. Your HR belt is very likely worn out. Check if this is a recurring pattern in your workout history. If you don’t have any arrhythmias, then you should see a (wavy, if your HR fluctuates) line in this chart.
                                sartoric Moderator @AntoniusGaius
                                @AntoniusGaius
                                What about the battery ?
                                Suunto App Android 6.3.3 beta
                                  @halajos I will try to upload more sessions to see some differences. Thank you for your help.
                                  I will buy H10 instead suunto smart sensor. I had problems with them early after start using them. Maybe there is some upgrade on Suunto side planned? This thing needs redesign as other HR measurement stuff in suuntio universe.
                                    AntoniusGaius @sartoric
                                    @sartoric New one.
                                      @AntoniusGaius said in Suunto ZoneSense:
                                      @sartoric New one.
                                      Do you moist the pads ?
                                      • H Offline
                                        @AntoniusGaius I also switched to polar H10, because I can get replacement belts for it on ebay for the fraction of the price of a new Suunto belt.
                                          @sartoric Of course 🙂 Heavily. I checked other activities in runalyze back to September and I found one export from 24.9.2023 and it was corrupted too. Strap has to be definitely bad…
                                            tomtom73
                                            I’ve tested zonesense for a few sessions and the results seems sometimes strange to me.
                                            Today the watch didn’t show red zone and the suunto app shows it. Well why not but the 2nd threshold seems quite low (lower than my lab tested 1st threshold…) On top of that zonesense dropped backed to green zone when I finish my effort and my HR was going near my “normal” 2nd threshold and what I know I can sustain for ~1hour racing.
                                            2 days ago the 1st threshold was at 116bpm.
                                            The difference in measurements seems huge doesn’t it ? I’m not sure if there is anything I can interpret based on that
