    Suunto ZoneSense
    955 Posts 146 Posters 186.6k Views 124 Watching
      Swaddy61 Silver Members
      I’m still puzzling over the ZoneSense results in the APP a bit, as the info seems slightly contradictory.
      Example: Today I did a reasonably hard indoor rowing session where my heart rate was between 140 and 150 BPM for the last 22 minutes (of a 33 minute session), which normally equates to a Zone 4 HR session.
      ZoneSense says that for this workout, my aerobic threshold is 131 bpm, and my anerobic threshold is 148 bpm. Surely then those 22 minutes should have been in the yellow zone, as anything above 148 bpm would have been VO2 max, and therefore red.
      But it has the whole 22 minutes as green (I didn’t check it live on the watch whilst rowing… too busy rowing!).
      My previous indoor rowing was similar. Again, I think it should be showing that 22min steady state as yellow as it is above the aerobic threshold and below the anaerobic threshold.
      So what is going on?
      • herlasH Offline
        herlas Silver Members
        S+ ZS got updated again (twice this week) looks like Suunto is actively working on this S+, which is a good sign.
        SRS Ti
        Galaxy Z Flip 3 / Galaxy S24+
        J TieutieuT 2 Replies Last reply Reply Quote 3
          jussim Bronze Member @herlas
          @herlas I was going to report a weird thing I experienced on a morning run just the other day: the ZS screen stayed black & white the whole run. A random glitch or a bug that got fixed? We’ll see 🙂
          9PP since 09-2025.
            Tieutieu Platinum Member @herlas
            @herlas : does update automatically applies to the app or it needs to be reinstalled ?
            herlasH 1 Reply Last reply Reply Quote 2
            • H Offline
              halajos Bronze Member @Swaddy61
              @Swaddy61 ad ZoneSense makes is computations on the inter-beat (R-R) intervals of the heart to find patterns over a time window, if the heart rate is not steady enough for long enough (couple of minutes), then the result of all that math (a single derived number) can fall into the wrong bucket. I have experienced ZoneSense showing aerobic effort during uphill, when my HR was around my lactate threshold (top of Z4). In more steady state periods the result is much more plausible.
              As any technology, ZS also has its limitations.
              • herlasH Offline
                herlas Silver Members @Tieutieu
                @Tieutieu it should but it’s recommended to uninstall, sync, make sure it’s gone from watch, then install again.
                SRS Ti
                  Brad_Olwin Moderator
                  Three examples working well for me:
                  First is 3 20 min Tempo Intervals. ZS was showing yellow for most of these on the watch and the app matches well. HR and ZS match up well.
                  For the other two I ran a fairly long RPE 5-6 3.5 h Trail Run on Saturday 07/12 where my AT was near the threshold that has been measured.
                  Today 08/12 a day after the longer and harder run I ran easier in mid Endurance RPE4-5. Unsurprisingly even though the run was easier my fatigue from yesterday was apparent as my AT was measured at 130 bpm. ZS for me is accurately measuring my RPE in almost all cases.
                  • herlasH Offline
                    3rd time ZS+ gets a new update in the last week or so, it wasn’t working with Race Nutrition S+ app and that was fixed.
                    SRS Ti
                    • herlasH Offline
                      herlas Silver Members @Zdeněk Hruška
                      @Zdeněk-Hruška @Francesco-Pagano, looks like he’s had a chat with Suunto and Monicardi recently and his original post has some new edit comments. Check it out.
                      Marco Altini’s blog:
                      https://marcoaltini.substack.com/p/q-and-a-what-are-your-current-thoughts
                      SRS Ti
                        Strangest thing happened with the latest update on ZS app: suddenly I wasn’t able to select it for an activity. It was listed on SuuntoPlus section of settings but you just couldn’t activate it. Some combination on uninstall / reinstall and watch reboots finally resolved it, huh.
                        9PP since 09-2025.
                        • the_ultramanT Offline
                          the_ultraman
                          My watch is Suunto Race. Why doesn’t Zone Sense work in trail run?
                          EgikaE Mff73M Brad_OlwinB 3 Replies Last reply Reply Quote 0
                            Egika Platinum Member @the_ultraman
                            @the_ultraman said in Suunto ZoneSense:
                            without more information, at which part it is not working for you, this is difficult to answer…
                            the_ultramanT 1 Reply Last reply Reply Quote 1
                              Mff73 @the_ultraman
                              @the_ultraman
                              Are you using a belt and not OHR? Also, in pre-start screen, is it well connected to HR belt (green heart icon with belt around)?
                                the_ultraman @Egika
                                @Egika said in Suunto ZoneSense:
                                When I start it as a run it works. When I start it as a trail run it doesn’t work.
                                EgikaE RayfoxR L 3 Replies Last reply Reply Quote 0
                                  @the_ultraman what exactly does not work?
                                  S+ screen is not there?
                                  S+ screen shows wrong data`
                                  S+ screen shows no data?
                                  Activity in app has no ZS data?
                                  please try to be more specific, so that we can get to the core of the problem
                                  • RayfoxR Offline
                                    Rayfox @the_ultraman
                                    @the_ultraman
                                    Try deleting the ZoneSense S+ app from the watch and reinstalling it. That might help
                                      larrybbaker @the_ultraman
                                      @the_ultraman You enabled it for the trailrunning activity?
                                      SV Solar
                                      iPhone 16 Pro
                                        Brad_Olwin Moderator @the_ultraman
                                        I only use trail running and mine works perfectly. Are you using a custom or the standard sport mode? Any other Suuntoplus apps running in addition to ZS?
                                        • DareoD Offline
                                          Dareo
                                          I’m having a difficult time wrapping my head around the usefulness of the ZoneSense real-time watch display. My initial thought was that the real-time display on the watch would be useful for those days that I set targets for the 3 zones, but it is completely off from what my perceived effort is. Here are two shots from this morning’s run which wasn’t particularly challenging.
                                          According to the watch I should have been doing some serious huffing and puffing, but that wasn’t the case. The next image is from the app after synching my watch.
                                          Now that’s a more realistic picture of how I actually felt, so I really don’t understand why the real-time display on the watch is so off.
                                          Watch vs. App
                                          Aerobic 02’35 vs. 30’36
                                          Anaerobic 12’02 vs. 22’40
                                          VO2max 38’12 vs. 00’00
                                          This is a consistent inconsistency since I installed the S+ app on my watch. Could it be something so simple as perhaps needing to remove the app from the watch and re-install it, or am I totally ignorant of how to effectively interpret and use the real-time info on the watch while running?
                                          enriqueescomsE H 2 Replies Last reply Reply Quote 2
                                          • enriqueescomsE Offline
                                            enriqueescoms @Dareo
                                            @Dareo I have already told you this before:
                                            The same thing happens to me, inconsistencies everywhere. The live data from the watch never matches what is later indicated in the app. When it is indicated, of course, because sometimes that data appears and other times it doesn’t. I have uninstalled, re-installed, reset, etc. and everything remains the same. I still don’t know how I haven’t given up on the effort… it seems I’m a masochist.
                                            DareoD 1 Reply Last reply Reply Quote 1
