    Suunto ZoneSense
    955 Posts 146 Posters 186.9k Views 124 Watching
    • thanasisT Do not disturb
      thanasis Bronze Member @halajos
      @halajos said in Suunto ZoneSense:
      @thanasis your Z4 minimum is set manually in the HR zones settings, while the aerobic threshold is measured by ZoneSense. Probably you need to adjust your zones.
      thank you . however i am not sure what should i do considering that the minimum Z3 according to Zonsense is supposed to be higher than the minimum Z4 .
      J Brad_OlwinB 2 Replies Last reply Reply Quote 0
        jussim Bronze Member @thanasis
        @thanasis You obviously need to increase zone 4 and zone 5 limits. How confident are you about what you have set as max Hr?
        9PP since 09-2025.
          The_77 Silver Members @thanasis
          @thanasis I had much the same last Sunday, and my zone 2/3 boundary is similar to yours.
          Usually my aerobic threshold ranges from as low as 120bpm to upper 130s - at no point has it ever gone up to 156bpm, and I wonder if it struggled with the specific workout type I did, which was a gentle warmup, some strides, and then 12x 3:30 with 1:30 breaks.
          You can see that it enters the VO2 threshold at around 163bpm repeatedly, and obviously it enters Anaerobic when I’ve already been at a high HR for the previous couple of minutes, hence pegging the aerobic limit as being so high I guess. Food for thought anyway, most likely ZS can’t cope with intervals being so short as per the documentation.
            Brad_Olwin Moderator @thanasis
            @thanasis said in Suunto ZoneSense:
            I have similar ZS results and our HR zones are very similar too. I am leaving my zones where I feel comfortable with and essentially not worrying about them! They are arbitrary anyway! Even a lab measured LT test is going to vary depending on your fitness, recovery, fatigue and stress the day you are tested. I believe that ZS is giving me an accurate representation of my effort based on 16 years of running ultras. I will likely never adjust my zones again and essentially ignore them.
            My interval efforts are based on RPE anyway and now long runs and recovery runs will use ZS. So it doesn’t matter if my LT is 120 bpm one day and 148 on another day. This is the reason to use ZS!
            • Brad_OlwinB Brad_Olwin referenced this topic on
              SalvaGali
              Hi! I bought a race s a week ago, and started working with the zonesense feature. I understand how it works, and that the threasholds are not static. I have a few questionnfor you guys:
              • During my easy runs this week, i got a measured aeT of around 130 bpm, which it seems in line with where i thought it might be. On suneay i run my local 10k and despite i can check the zonesense graph, it does not provide any measured aeT. Any explanation for this? I did a 10-12 min warming up before the race in order to get the zonesense calculate threasholds.
                alt text
              • When looking at the graph from the 10k, i can see that the change from green to yellow seems to be somewhere near the 160 bpm, far away from the usual 130. It seems to me that this value has been afected for not being an easy run (despite the previous 12 min warmup? Is it posible?
                alt text
              • In order to have a measurement of the anT, do i need to get to that intensity?
                Thank you!
              • herlasH Offline
                herlas Silver Members @SalvaGali
                @SalvaGali https://forum.suunto.com/post/161391
                SRS Ti
                Galaxy Z Flip 3 / Galaxy S24+
                • SportsfreundS Offline
                  Sportsfreund Bronze Member @thanasis
                  In my case ZS is absolutely not in time. Always after mainrace in cooldown mode the Display shows value changes between the 3 zones.
                    Leonid Yasyukevich
                    I trust the laboratory test more, which for an amateur is desirable to do once every two years. Lactate is a key parameter in the measurement, our top runners measure it right in training.
                    In any case, Suunto has a lot of beta testers and time to test this feature👨‍🔬
                    9 Peak Titanium (43 g.)
                    Ambit 3 Sport
                      tschogo
                      Hi there! Can you confirm for zonesense to properly work, you first need to put in some (how many?) workouts or minutes (which of both?) at each of the 5 zones? And basically ignore zonesense during this calbration workout(s)? I’m asking as today I was running a 10k (probably my 3 workout with a HR belt and zonesense enabled) and wanted to do it in zone 2, but (almost) regardless of what HR I ran at, the DDFA-index stayed green: alt text, alt text. On the other hand, it seems that zonesense was able to calculated my aet correctly, still. This is a bit confusing to me. Any help is much appreciated, thanks!
                        thanasis Bronze Member @Leonid Yasyukevich
                        @Brad_Olwin can you help me with why this happens ?
                        14e8b40b-6876-43a0-87c4-ea5dc0d9a958-image.jpeg 79713120-2a44-4be0-9d64-8afb52a96487-image.jpeg 12a5ebf9-0875-4828-8398-17b6dfeede65-image.jpeg
                        While the app seems to be running it also shows waiting for data
                        Also the there is a big difference in the data in the watch ( eg I had some 5-6min the red zone ) while in the app the duration is 0
                        SportsfreundS GiPFELKiNDG Brad_OlwinB A 4 Replies Last reply Reply Quote 1
                          @thanasis Yes, this ZoneSense is not really usable yet. Live data does not work. Only after the activity in the app.
                          thanasisT Stephen KennyS 2 Replies Last reply Reply Quote 0
                            thanasis Bronze Member @Sportsfreund
                            @Sportsfreund I think what is being mentioned here is that some people like @Brad_Olwin are using the real time zonesense instead of HR zones . If the watch and the app are so much different there needs to be an explanation
                            SportsfreundS 1 Reply Last reply Reply Quote 1
                              @thanasis Who knows. In my case live data does not work. For example, last week I did Cooper test, all the time while running the vertical showed green aerobe, after running in the last minutes off cool down the graph changed into the other zones.
                              VoiGASV ChrisAC 2 Replies Last reply Reply Quote 0
                              • VoiGASV Offline
                                VoiGAS Silver Members @Sportsfreund
                                @Sportsfreund Yes, I have the same behaviour. After washing the belt the quality of the data looks much better, but still the live data just stays green. I ordered a new belt - maybe this helps.
                                I would also love to hear some long term real life experience with using Zonesense during the run
                                SportsfreundS Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                • ChrisAC Offline
                                  ChrisA Platinum Member @Sportsfreund
                                  @Sportsfreund If I run steadily and slowly in a aerobic zone and then change to walking, stop suddenly or even just fiddle with my phone, I can feel my HR rising and my heart beating more intense for some time after. Perhaps Zonesense „senses“ this changes in HRV and how your body tries to find homeostasis and therefore the change?
                                    GiPFELKiND Silver Members @thanasis
                                    @thanasis do you have “running” a Second suunto+ App while running? Tey to deactivate the Second one and the Zonesense data should be visible correct
                                      Sportsfreund Bronze Member @VoiGAS
                                      @VoiGAS my belt is very new. Bought it last week.
                                        The watch is not receiving data.
                                        The belt must record electric changes NOT OHR.
                                        The belt must provide good R-R data
                                        Delete and reinstall the Suunto Plus ZS app from phone and watch
                                        At the beginning of your exercise 10 min of aerobic warm up is required before live ZS is displayed.
                                          Brad_Olwin Moderator @Sportsfreund
                                          @Sportsfreund what belt?
                                            Brad_Olwin Moderator @VoiGAS
                                            @VoiGAS said in Suunto ZoneSense:
                                            I have been using and testing ZS since last May/June. Is that long term enough?
