    Once again, S9PP suddenly stops whereas remaining battery was 44% percent
    5 Posts 2 Posters 367 Views 2 Watching
      LudovicTheRunner
      Am I the only one suffering from this behavior?
      Last saturday, my S9PP was fully charged, I started my race and after only 6 hours (using max. GPS performance and navigation) my watch suddently shut down. When I started it again the remaining battery was 44%… So, I ran again (without navigation) and it lasts for 1H30 and then, shutdown again.
      How can I definitely solve this issue (as in the past three years it happened multiple times) ?
      I can’t really trust my S9PP…
      Thanks.
      • isaziI Online
        isazi Moderator @LudovicTheRunner
        @LudovicTheRunner never happened to me, and I have not seen this widely reported. So, chances are that you watch is faulty. Have you approached support?
          LudovicTheRunner @isazi
          @isazi : I’ll contact the support. I just wanted to check before sending it to support.
          • isaziI Online
            @LudovicTheRunner as far as I know, when the watch crashes, it automatically reboots. So you see the Suunto logo in the opening screen, and find yourself on the home screen. Shutting off without rebooting would seem more similar to a hardware fault to me, maybe a faulty battery.
              @isazi thanks. This is my assumption too. Sometimes it even shutdown while charging on the slot ! I’ve sent it to the support center in Prague…let’s see.
