    Wing 2 not connecting to Samsung 23 Ultra
    Scheduled Pinned Locked Moved Headphones
    8 Posts 8 Posters 3.0k Views 8 Watching
      aerodynamicviolence
      Phone: Samsung S23 Ultra
      Android latest up to date version: 15
      I just bought a wing 2 but i could not get it to connect to my phone.
      What I did:
      Open the box and charge the device.
      Hold the ‘+’ for 5 sec to pair device trough suunto app.
      Device is not recognized and app prompts to manually connect.
      Connect trough bluetooth by pairing the Wing 2 found by my phone.
      Bluetooth give me a pairing prompt and i select ‘pair’
      Tries to pair untill headset will shut off due to inactivity.
      During this time the leds arw blinking.
      Without the success sound on the headset it will show on the phone under paired devices.
      When i turn the headset back on it wont connect and during this time its still not recognized in the app.
      When i connect the headset to my macbook it succesfully connects flawlessly with the connection success sound.
      Aswell if I connect it to an older samsung.
      My other suuntk devices suunto Race S is working with no problem and is connected to this phone.
      For troubleshoot I have done:
      Reset bluetooth cache
      Remove device from pairing
      Restart phone
      Reinstall suunto app.
      There is already a ticket existing with CS but If i dont have a response i will return it to the shop by friday.
      I will not accept sending it in for repairs since its literally new out of the box.
      Thanks in advance!
      Postes DepotP 1 Reply Last reply Reply Quote 1
      • Postes DepotP Offline
        Postes Depot @aerodynamicviolence
        @aerodynamicviolence I was not able to pair successfully to my Samsung Fold 7 device. I uninstalled the Suunto app, and then retried pairing. That did the trick. Hope it works for others. The Getting Started guide does show that the steps in this order - pair via bluetooth, then download and pair in the app. But this would be a problem for those who already have the app installed.
        Adam WardA 1 Reply Last reply Reply Quote 2
        • Adam WardA Offline
          Adam Ward @Postes Depot
          @Postes-Depot
          I tried this method of uninstalling the app - and it did not work.
          What did work for me was to use the NFC capabilites to connect my Suunto Wing 2 to my phone (Pixel 9a).
          Simply tapping my phone to the left module allowed me to pair successfully.
          althaea35A 1 Reply Last reply Reply Quote 1
          • Alpha 156.42A Offline
            Alpha 156.42
            s24 as well
            Piotr BoberP 1 Reply Last reply Reply Quote 0
            • Piotr BoberP Offline
              Piotr Bober @Alpha 156.42
              @Alpha-156.42
              Hi I was looking on different forums the solution for Wing 2. I use Suunto products for a long time. I tried to connect the Wing 2 to different phones. I tried to pair them just out of the box and fully charged. I tested pairing on below mobile phones with latest updates:
              Samsung S23 Ultra
              Asus Rog Phone 8 Pro
              There was no possibility to connect. So I tried on
              Samsung S22+
              Samsung S23
              Both with latest Samsung updates and it paired!!!
              So the solution to my S23 Ultra and Asus was to pair with any phone that was working and do the firmware update. So after it all problems disappeared.
              It is difficult where the problem is but probably with the Bluetooth operations.
              Find a friend where you can pair the Wing 2, install temporary suunto app and do the update. Hope it helps.
              • althaea35A Offline
                althaea35 Bronze Member @Adam Ward
                @Adam-Ward this method worked for me as well.
                Thankyou would’ve been a frustrating Christmas otherwise!
                Suunto M5, Quest, Trackpod, A2S, SSU, S9B, S9P, Race
                Garmin 305, 60, 405, Fenix 2, 945, 955
                Polar M430, Vantage V
                • S.PichiS Offline
                  S.Pichi
                  i have the same problem , cannot pair my wing2 with samsung23 ultra.
                  • W Offline
                    waynefreerash @S.Pichi
                    @S.Pichi said in Wing 2 not connecting to Samsung 23 Ultra:
                    Im now trying to connect my aqua to s24 ultra. Connects then disconects and and it does this all the time.
                    My vert 2 is fine and has a green dot to say its ok in the app
                    Headphones always have a orange dot in the app. I hit he icon and it takes me to pair section. it then connects and then the dot goes green . Then back to orange the back to psir and it has disconnected. This is a vicious loop.
                    I think it needs to go back. Its like 1 hour old.
