    Tedious double tap to manual lap on track
    5 Posts 5 Posters 360 Views 4 Watching
      You have to press the watch twice to manually mark a lap or pause. The first press (or wrist movement) wakes up the watch. The second press marks the start of the next lap.
      The problem is that when you’re doing short intervals on the track, for example, it’s tedious to have to press twice when you cross the line or to have to anticipate by moving your wrist first.
      I tried setting the watch to always-on display mode, but that didn’t change anything.
      Do you know if this is the case for all Suunto models or just the Run watches? Also, do you know of any tricks to get around this problem? Thanks in advance.
      Hari SeldonH C 2 Replies Last reply Reply Quote 1
      • Hari SeldonH Offline
        Hari Seldon @Guest
        @quentinho said in Tedious double tap to manual lap on track:
        Knowing that, I simply raise the arm and then press the lap button. Works for me.
        Suunto Run
        • C Offline
          cheetah694 Bronze Member @Guest
          @quentinho Nope, this experience is foreign to me. My watch never sleeps during a workout. So on my 9PP it’s enough to single-tap for a lap or pause.
          Suunto 9 Peak Pro
            Egika Platinum Member
            I also don’t like this.
            Same for any other button press, like pause etc.
            Luckily this will change with the next update. Then it will be possible to configure to keep the current behavior or that button presses have an instant action.
            • N Offline
              neilme @Egika
              @Egika if this update get implemented then ill be much closer to buying this device. Where did you read this behavior will be updated?
