Race 2 and Race battery consumption
Both watches battery draining relatively fast in comparison to the past (pre last update), it is especially noticeable when not doing too many activities.
The Race is draining faster than the 2, but both are not keeping as charged as they were in previous versions.
Tried soft resetting but to no avail.
I’ve not been hearing any issues on the media, but a handful of race owners I know have raised this issue. -
@peegee Yes, it is a problem. I and many others are the same.
@peegee it only affect latest version rollback to the previous one solve the drain (but could bring back the ohr issue)
@peegee Whats your battery drain per day? Mines is around 8% if I dont do any gps tracked activities and aod disabled + sleep tracking + no Sp02.
I feel like 8% is a bit high but not sure. got this watch a couple days ago.
@Josaiplu y como se puede volver a la versión anterior?
Also guys don’t forget that a lot of settings have a direct impact on battery consumption :
- backlight level
- notifications or not
- AOD or not…
- in exercice use of maps, touchscreen, multiple guides…
- turn to raise…
@Tieutieu Yes, definitely right, and we totally get it. During activity mode, with GPS, MAP, and a few small things, the battery drops by 6-8% in two hours. And in watch mode, it drops by 15-20% daily; that’s not normal, especially since the watch is just a year old.
The issue is that the same setting that used to give 8-10 days of battery suddenly drops to 4-5 days after the firmware update, and it keeps happening with every update.
I don’t mind going back to the initial firmware where the battery performance was really good 10+ days in watch mode without HR and Notificaions.
@withManish what do you mean with “it happens with every update”?
It is known that the battery calibration is lost with an update. So you will need a full battery discharge/charge cycle.
It is an issue if it keeps using more battery than expected after the cycle. -
I tried the I gave ChatGPT two activity files and let it compare battery consumption.
Different routes, same terrain + HRM connectionParameter 3. 11. 4. 11.
Batte: 38>33%. 29>24%
Recording time 73.7 min 74.6 min
Battery drop 5% 5%
Consumption per hour 4.08% 4.03%
Average current 21 mA b21 mA
Average voltage 3.791 V 3.756 V
GPS parameter 3. 11. 4. 11.Average number of satellites 28.5. 27.8
Average EHPE 3.13 m. 4.05 m
Average EVPE 5.05 m. 6.41 m
Median EHPE 3 m 4 m
Median EVPE 5 m. 6 m
Average SNR 29.60 27.51
Maximum SNR 38.0 35.6 -
@Egika I totally get you; battery usage cycles reduce battery life, but people complain when they see a sudden drop, irritating behaviour and no one from Suunto is bothered to give any firm answers.
Every firmware update brings more bugs, mainly with the battery. Engineers never acknowledge it or work on battery bugs or power consumption issues; they are only busy adding new functions.
Most customers are starting to feel left out of the support while they are still selling those devices. When you try to contact the support team or online support chat, they never come back with a solution or a firm answer, and as a customer, you are living with faulty or buggy products. That hurts a lot.
Recently, I mentioned that my old Ambut 3 Peak still gives me good battery life, but the Race S’s performance is pathetic, even though it’s hardly a year old.
@Egika speaking from experience after multiple battery recalibrations, the issue is not with battery recalibrations but with the firmware. The 15-20% a day on my race is a legitimate battery burn. The claim of it getting worse with each update has held true for me as well. It hasn’t been a slow degrade in battery life over the last 3 years of owning the watch but step changes with each update. I initially got close to 14 days out of the watch, each update would drop that a day or two with the latest update being the worse drop yet, dropping me down to 4-5 days between charges. I initially thought this might be due to the age of my watch battery, but reading here that people with relatively new races have the same issue tells me it’s a firmware issue.
All I want for a firmware update is a fix for some of the battery life issues. I know there are tradeoffs for features vs battery life but a person buys a watch with the expectation it reaches its claimed battery life. I would be very unhappy if I happened to buy a race today to find out I can only get 5 days out of it. I know you can return the watch but in my opinion this is borderline fraud and false advertisement.
