    Tank pressure must be displayed at all times!
    6 Posts 5 Posters 538 Views 7 Watching
    • N Offline
      Niels-Søren Bøgh
      The tank pressure(s) are hidden behind the compass and user enabled Fields!
      Solution: There is enough vertical space right to the Depth Gauge to graphically show the active tank pressure at all times. E.g. as a 5 bar indicator that are green until the user set alarm level, then orange and red from 50 bars and down - and blinking red below 20 bars.
      AND a 1 Field sized compass will be nice - even that its shows only the numerical bearing from north and a red arrow to the left or right to indicate the shortest direction towards north - and a vertical yellow line marking the user set course…
      A Pascal RoyP 2 Replies Last reply Reply Quote 6
      • H Offline
        hhouter
        In our dark and merky waters in NL the main screen for me is allways the compass screen. And yes you can switch but I really would like to see an option with the tank pressure in compass mode…
          Aquario @Niels-Søren Bøgh
          @Niels-Søren-Bøgh and @hhouter I am miffed about the same issue that compass hides the tank pressure.
          I made a list of a few software limitations in the following thread, let’s hope Suunto developers are listening:
          https://forum.suunto.com/topic/14363/software-limitations-of-suunto-nautic-vs-garmin-x50i
          • Pascal RoyP Offline
            Pascal Roy @Niels-Søren Bøgh
            @Niels-Søren-Bøgh Goodnidea I up vote for this.
              antoine_ld
              Indeed tank pressure and compass should be visible in 1 screen.
              It should be a simple fix.
              With a small compass widget, with just the heading in degrees, I would be happy.
              Setup a screen with tank pressure and heading.
              And never have to change screen on most of my dives.
              • H Offline
                hhouter
                # Suunto Request:
                It would be great if can you make a Switch Window “Compass View” double field. In this case we can assign it to the main screen and have the pressure + compass in a single view.
                The view would be perfect to hold position and check regurarly during the dive.
                The limited view should hold the position N/S/W/E markers and bearing indication as in the picture below.
