    New Suunto Nautic firmware 2.49.28 (23rd January 2026)
    16 Posts 8 Posters 3.4k Views 9 Watching
    • N Offline
      Nandodiver Bronze Member
      Staged update starting on January 23rd 2026
      This update brings new features, improvements and bug fixes.
      New Dive features:​
      Option to define separate units for depth, tank pressure, gas consumption, temperature
      Possibility to add GF99 and Surface GF value in switch window
      Option to see a tissue bar graph during dive
      Option to reset tissues
      Tide widget
      Improvements and bug fixes:
      Localization fixes
      Compass bearing gets sometimes stuck
      Password lock bug fixes
      Wrong surface time after 48h of inactivity
      Fixes to visuals regarding decompression stops
      Helium not taken into account in tissue graph
      POI’s not working in Map
      Sidemount alarm not visible in Suunto app
      Fixes to showing tank pods when offline
      Ascent speed warning stuck on surface screen
      Fix timeout time in many menus
      Unified button hint visuals
      Compass mils degrees not cantered
      Fixes to dive planner when diving with algorithm off
      Fixes to icons in weather widget
      New certification markings
      Charging icon and charging state are not shown in dive screen, control panel and power saving screen
      A new gastime alarm was not shown on list
      Inconsistency in showing NX100 and NX99
      The water type in dive summary wasn’t changed when updated in the setting view
      Fix to gas change from gas menu
      Device didn’t go to power saving mode from planner views
      N Ray de JagerR M 4 Replies Last reply Reply Quote 0
      • N Offline
        Nandodiver Bronze Member @Nandodiver
        After the download the update need to be confirmed/activated at the device settings.
        • Pascal RoyP Offline
          Pascal Roy
          Great update, way to go! Keep them coming… You will beat Garmin!👍👍👍
          • H Offline
            hhouter Bronze Member @Nandodiver
            @Nandodiver What a huge list of improvements. Now also GF99 and SurfGF Thank you Suunto
            • pavel.samokhaP pavel.samokha pinned this topic on
            • Alon DotanA Offline
              Alon Dotan
              To be honest I expected way more from this upgrade…
              MIssing features:
              CCR mode
              Change gradients while diving
              Set gas as travel gas
              Also…
              Someone managed to activate Option to see a tissue bar graph during dive?
              Is this refers to the switch window mode that switches to the tissues bar? or to add a fixed bar to the main display?
              Ray de JagerR 1 Reply Last reply Reply Quote 0
              • Ray de JagerR Offline
                Ray de Jager @Nandodiver
                @Nandodiver
                -After turning on the knob orientation is always reset to buttons left. Would be nice if it stayed the way i configure it.
                -Tide info not showing…does it use my current location? Can i somehow select a location and have the tide info shown then?
                -In the app itself the underwater route…if i select a location on the map, the underwater route is not shown anymore, and cant find it anymore where that window is at.
                • H Offline
                  Hugues78fr @Ray de Jager
                  @Ray-de-Jager +1
                    mitchellrishe @Nandodiver
                    @Nandodiver
                    I am having the same issue as Ray de Jager regarding button orientation. The Nautic always resets to button-left orientation after shutdown. I was told by Nautic customer support that this issue was known and would be fixed with this upgrade. But it has not. Does anyone have any information on if/when this issue will be fixed.
                    • H Offline
                      hhouter Bronze Member @Hugues78fr
                      @Hugues78fr please send an email to support@suunto.com and describe clearly what happens to allow them to reproduce the issue. If they confirm it the issue will be submitted to the dev teams to fix.
                      Support is quite responsive so they will reachout about the status of the issue.
                      • H Offline
                        Hugues78fr @hhouter
                        @hhouter : message below sent
                        I am having the same issue as lot of here:
                        • the Nautic always resets to button-left orientation after restart
                        • the Nautic, and I, spent to much time outside to get gps position
                        • the Nautic, and I, spent much more time outside to get the compass calibration
                        • regarding tide, even close to the sea or close to La Seine at Rouen, never see after sync or upload, anything about tide
                        I plan to dive in April to Mexico, would it be fixed or not ?
                        Thanks.
                          @Nandodiver
                          Found a few again
                          -gasses added in older firmware: no change and select…black screen
                          Resolve>remove and make new gasses (bug)
                          -on the disabled gasses there is no arrow fwd for entering the gas menu, although you can enter to change and enable(minor design glitch)
                          -forward AND BACKWARDS in extra screens (wish)
                          -extra lines in tissue graph 10.20.30.40 etc…just lightgrey lines…also in divehistory(wish)
                          -please show the alarms in dive history on computer(wish)
                          -fwd knob in a dive while in divehistory does nothing(minor design glitch)
                          I will sort these with pictures and fwd to suunto support. Keep up the great work!
                            Ray de Jager @Alon Dotan
                            @Alon-Dotan
                            In reply to ‘Change gradients while diving’
                            I added an extra view with “GF99/SurfGF” and “Contingency Delta 5 / @ 5” to see what the implications are if you would override the advice from your computer…sort of a ‘second’ calculation running to your main.
                            It is nice to have this insight…what if i stay longer on a planned dive or even cross the ndl time; what would the implications be…
                            BY THE WAY …CMAS website has great explanations on the gradient factors and how to set for the ones new to this.
                              Sharkhugger
                              I bought the nautical last Friday and got to dive with it this weekend. After 4 dives there are a couple of things that were not ideal. First it would be nice if the tank pressure and full compass could be shown at the same time. In the right lower corner it now shows temperature, battery percentage and if a pod is connected. This could easily be changed to showing the tank pressure. The information shown now is pre or after dive information. Second if you set the bearing and click through the screens it loses its bearing if you do not start dive mode in the compass setting. I like the computer so far. Haven’t taken it on a testride with multigas, side mount, or helium yet bit for the single tank dives this were the things I noticed and might be a nice improvement.
                              • H Offline
                                New Firmware is available… 2.49.32.26108 (Valentines day update… 😉
                                  Ray de Jager @hhouter
                                  @hhouter
                                  Thank you for this update. 🫶🏻
                                  In case of problems while updating Nautic:
                                  -Make sure the Nautic is connected to charger
                                  -Make SURE the power save function on the phone is OFF since it interferes with the app in a serious way in my case. Probably has to do with the power save function settings of the Suunto app.
                                  If it still fails, try turning off and back on the WIFI and BT on the phone. After reconnecting the process should resume. In my case i see the percentage increasing at least every minute. (Samsung s21 ultra)
                                  First bug or disfunction:
                                  In the dives of the divelogbook the diveprofiles are gone or don’t show.
                                  • N Offline
                                    Nandodiver Bronze Member @Ray de Jager
                                    So far i have done 17 dives ( 2 tanks) with Nautic since ive charged to 100% once…
                                    Estimate time 15 or 16 hours underwater and now the battery has reach 50%
                                    Great battery, enough for 7 days liveaboard without need to recharge
                                    Ps: without transmitter
