    Battery drain
    7 Posts 7 Posters 1.4k Views 7 Watching
    • J
      JohnnyB
      Re: Battery drain - share your settings
      I have a Suunto 9 Peak pro. After the the 2.50.26 and especially 2.50.28 update the battery drains very fast. In one day without any activity the battery from 57% goes to 28%.Has anyones else the same problem?I tried a soft reset but nothings happens.Also i checked the backlight but is off.
      V 1 Reply Last reply
      Reply Quote 1
      • V
        vladutz @JohnnyB
        @JohnnyB Yes indeed, I also realized after the last january update (2.50.26) that my battery is draining much faster than before!
        1 Reply Last reply
        Reply Quote 1
        • Loïc GangloffL
          Loïc Gangloff
          Me too. I have already send my watch to the support, but nothing change… still battery drain problem.
          thibault berardT 1 Reply Last reply
          Reply Quote 0
          • thibault berardT
            thibault berard @Loïc Gangloff
            @Loïc-Gangloff same here ! 10 days without bt connections and no wake off the backlight when i move m’y hand.
            1 Reply Last reply
            Reply Quote 1
            • Martin NavrátilM
              Martin Navrátil Silver Members
              After the 2.50.28 update, I also have some battery drain issues. It’s not as bad as what you guys have, but the battery goes down twice as quickly as before.
              Suunto 9 Peak Pro Black
              Suunto 9 Baro Black
              Suunto Ambit 2
              Suunto Observer
              M 1 Reply Last reply
              Reply Quote 0
              • M
                MihaS @Martin Navrátil
                Hi guys! I’m new here, made this forum just for this problem:
                Since the firmware update as you guys report 2.50.28 on my Race S I have big battery drain about 1% an hour even in airplane mode and the dumbest digital watch face.
                From some Chat GPT help I uninstalled offline maps, made a soft reset, factory reset, now I’m leaving it in airplane mode overnight to see. But it’s doesn’t look good, it already dropped from 74% at 18:45 to 71% 21:45.
                Renzo KarsdorpR 1 Reply Last reply
                Reply Quote 0
                • Renzo KarsdorpR
                  Renzo Karsdorp @MihaS
                  Anyone found a solution for this?
                  Im a bit over Suunto 9pp, my Spartan 5 years ago was bulletproof. Had one replacement already 2 years ago and cannot be bothered to go through that process again.
                  1 Reply Last reply
                  Reply Quote 0
