    Suunto Vertical all black 2024: stuck in boot loop / continuous restart every 12 sec – Need help!
    7 Posts 3 Posters 764 Views 4 Watching
      LukasLukas
      Hi everyone,
      I’m reaching out to the community because my Suunto Vertical all black (purchased in April 2024) has completely stopped working and I’m hoping someone here might have some advice or experience with this.
      The Problem:
      The watch is currently stuck in a permanent restart loop:
      Off the charger: The watch vibrates continuously every 12 seconds until the battery drains completely.
      On the charger: The screen backlight sporadically flashes on and off. The watch fails to boot up into the system at all.
      It seems like an internal button signal or hardware glitch is triggering a constant soft-reset loop. I can no longer turn the watch on normally or access any menus.
      Current Situation:
      I’ve already contacted Suunto Support. Since the watch is just past its warranty period, they only offered a 30% discount on a new purchase. For a premium outdoor watch that is barely over two years old, offering a 30% voucher instead of a proper repair or fair replacement solution is simply not acceptable to me. I’m so frustrated right now. I am supper interested in an balanced solution but not suunto.
      Has anyone encountered a similar issue with their Vertical? Is there any way to break this reboot loop on my own, or any other troubleshooting steps I could try?
      Thanks in advance for your help!
        Squirrel Silver Members @LukasLukas
        @LukasLukas
        Try to boot into safe mode, if possible, as per this post:
        https://forum.suunto.com/post/194184
        Otherwise, send to service for repair estimate.
          LukasLukas @Squirrel
          @squirrel
          Thank you for your advice - but didnt work!
          BUT:
          I solved the problem by spending more the 30 hours in try and error - in the end I loaded the watch with the loading cable plugged in by the laptop. Whether it still looped, after pushing randomly all the buttons while doing other daily things, the watch started with like 6% of battery. After having 40% (40% are required for complete reset) I reset the watch. The reset went good but the endless scroll glitch (upper button) was still there. I was disappointed. Multiple times I changed the personal settings - endless scroll. After like 5 minutes endless scroll stopped! I put in all settings and connections - watch started working. Stable since yesterday 11 p.m.
          Suunto Support wanted me to by a new watch with 30% discount on enlisted price! I wouldnt have bought a new suunto since support was not really helpful nor customer oriented.
          If Suunto is reading this: PLZ fix this issue, this bug is hell.
          I will edit in a week or when the watch is going to “issue” again.
          L 1 Reply Last reply Reply Quote 2
            LukasLukas @LukasLukas
            Still working. Battery consumption was high, now usually as always approx. 4% per day. Upper button nearly unusable as it seems that no signal is sent to platina. A lot of power is needed to push button.
            L runomaticR 2 Replies Last reply Reply Quote 0
              An other update for 20.08.2026: Holiday in Malta
              An other sip of salt of salt water watch is having the same issues and the same behavior!
              Try to get it reset with connection to PC.
              Will update you as soon as it gets better/functional!
              Greetings from Austria
              • runomaticR Offline
                runomatic Silver Members @LukasLukas
                I’ve had that problem before too. Try putting the watch in a glass of water for a few hours (plain water – not salt water 😉 ). If there are any salt crystals in the buttons, they’ll dissolve. The buttons will then work normally again.
                https://runomatic.de
                SUUNTO VERTICAL 2 Titanium
                SUUNTO WING Black
                SUUNTO App (iOS)
                  LukasLukas @runomatic
                  @runomatic Hi,
                  did that over the night, still autoscroll upper button.
                  Meanwhile I got pushed the setting “restore the watch…?”, now the watch is stuck and changing between "the device is being restored in a safe mode " and “this is taking longer than expected, thank you for being patient”. In both visuals there is loading bar which is never running through fully. Than blackscreen and then alternating “safe mode” or “taking longer”.
                  Super fustrating
