Battery Capacity
@Egika what device did you use? My Race S has not even half the capacity: “BatteryDesignCapacity”:910.8
@2b2bff I think the example above is from my Race 2
Thanks for teh json tips !
I got a surprising result:
“Device”:{“Info”:{“BatteryDesignCapacity”:910.8,“BatteryFullCapacity”:954,“HW”:“Monkfish_RevC1”,“SW”:“2.53.42”}
How can the full capacity be higher than the design capacity ?
I hav just made a soft reboot of the watch due to battery insatisfaction like “I feel like it got shorter capacity”.
Ineed teh reboot seem to have induced a jump from 35% to 59% ! Weird good news !
@LoïcMichel the actual capacity can deviate from the design capacity in both directions.
Mainly due to manufacturing variations and aging.Plus there is the calibration of the energy meter. Like after a firmware update it will only report correctly if from time to time the battery is discharged pretty low (10% or so) and then fully charged to 100%. This will ensure correct readings.
@elbee I want to know “how much juice is remaining on the battery compared to the original capacity”, which helps me decide whether to get a new watch or a battery replacement. For that, you don’t need to break the watch; software can help with that easily if that can be provided to the end user, the same way iPhone or any phone provides.
@Egika, I am not interested in what remains on the current charge; I am talking about battery capacity compared to the original capacity when I bought it.
@withManish understood.
Still the actual capacity can only be known to the system, if it has a chance to calibrate itself as written above. -
@Egika I found the FCC internal photos for this model. The battery label might provide the capacity information you’re looking for:
https://fccid.io/RYPOW222/Internal-Photos/OW222-Internal-Pictures/
Ok from the photo I can see 4,45v and .99wh
@Egika, I think every firmware update should include a way to celebrate the battery, or there should be a separate procedure available to the end user so people can do that on their own and get the right performance for the device, rather than hunting for a solution.
@withManish usually the battery meter will just calibrate itself, if the watch is used normally.
For the few users who check their batteries very detailed, there is Q1 in the FAQ
https://forum.suunto.com/topic/9960/more-faq?_=1793954782334
