    Doubt about Suunto 9 Baro altimeter/barometer calibration
    104 Posts 14 Posters 16.1k Views 17 Watching
    • Mff73M Online
      Mff73 @DavorP
      @DavorP
      Sorry but you are confusing, i will try to explain.
      SuuntoApp is SA, it is an app on your smartphone, your phone have a GPS, and the app could record activities with phone GPS data. This setting in the App is to determine if the Altitude come from GPS or Baro, only for the app recordings.
      Your watch, SSU, but for all others users, can also record activities on its own, have settings and these settings are not managable currently via SuuntoApp. They are still managed in Movescount on the web.
      Activities from the watch are synced to SA, but both kind of recordings (and thus alti settings) are different.
      Does it make sense ?
      D ? 2 Replies Last reply Reply Quote 3
        DavorP @Mff73
        @Mff73 Now I see, thanks for clarifying… 👍
          A Former User @Mff73
          @Mff73 Thanks, now I feel like an idiot! jajajajajaa 😂
          Looks that this mean that the watch started to display correct informations after altitude calibration (auto-adjust).
          Personally I don’t use the SA to record activities. For me is not sense because for this I have my watch, but maybe for other users is useful. I always imagined that this settings was for the watch, like when I did from MC. Maybe they need add some sentence into the SA on this setting to clarify this or I’m be the main idiot that not understood this 😂
          The settings for watch activities altitude source are still not changeable in SA, still only in MC for now.
          I hope that soon is added on SA for each Sport Mode and for the overall watch. Because I moved to use SA and can’t control this now 😞
          mario_bM Mff73M 2 Replies Last reply Reply Quote 1
          • mario_bM Offline
            mario_b @Guest
            @flypg i would not underestimate that feature. 3 reasons for that.
            -when you forgot your watch or forgot to charge it or on vacation you forgot your charging cable (like I did) 🙂
            -when your watch (hopefully not) has to go to a service
            -or when your in training and just wanna record your effort. (PTE, EPOC, recovery time) i use that when I am bouldering or training at the climbing gym. I don’t take my watch or phone with me. I but on the smart belt start the activity on the phone and lock everything in in the dressing room. (I would destroy the watch while bouldering for sure)
              A Former User @mario_b
              @mario_b Nice tips, I mainly use my watch to not use any other instrument or device during activities. Until now I could cover this objetive.
              Is good share different focus or usage of each one of the same product because we learn from other perspectives. Thanks!
              • Mff73M Online
                Mff73 @Guest
                @flypg said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                This setting could confuse when thinking the app is 100% watch related.
                Agree that Suunto should add some tip on this.
                And to conclude, Idiots don’t know they are idiots, so if you feel idiot, you are probably not . 😂
                  Hello everyone, I kept watching this, and after see that other users with Suunto 9 have problem with their altimeters, I did more tests. I really don´t know if this is a problem or is a normal behavior of the firmware. I can´t understand for what the Suunto 9 Baro displays me frequently wrong altimeter data. The sensor is clean and works perfect, I runned tests and take perfectly the altimeter and pressure variations, etc.
                  After a correct calibration that my S9B display me a correct value of altimeter and pressure, if I mantain in the same area and the weather goes wrong, the pressure goes down (OK) and the altimeter drop the value that displays.
                  For example, from a nice day of high pressure in a correct altimeter data of around 35mts, on the same place after 3 days, but with bad weather, the S9B displays me a drop on the pressure (OK) and a altimeter data of -14m… (minus-negative) ¿?
                  I really don´t understand this behavior. This never happen to me with the A3P.
                  What mean? That on S9B I need re-calibrate each day?
                  Also I received a Storm Alarm on a beautiful sunny day and today that we have storm with hail, nothing. I can understand this, maybe the drop of the pressure on sunny day was more violent than today, OK, but the changes on the altimeter not sounds logic.
                  Can be possible that something is wrong on the firmware of the S9B?
                  @Dimitrios-Kanellopoulos I add you in case that you miss this because I see that you have more similar reports about the altimeter. Thanks to everyone.
                    @flypg I suspect it needs cleaning / service.
                    All the above show from my experience this behavour.
                    Do me a favor and put the watch in the fridge for 10mins. Will the altitude rise ? (and the temp of coursE)
                      @Dimitrios-Kanellopoulos said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                      Thanks!!!
                      This for me is strange, because I see this behavior since new. Also I tested the same behavior in other S9B and S9B Titanium from friends :S It would be a lot of coincidence.
                      @Dimitrios-Kanellopoulos OK, I do on the afternoon: fridge or fridge freezer?
                      Thanks again!
                        @flypg also your friends had the same? It can be also due to a storm that came too fast to be detected thus influencing the altitude.
                        In general, lets leave aside the day with the bad weather, if you leave the watch at the table you should have the same altitude. (or wear it in house but no shower etc )
                          Yes, I not tested in deep with their watches, but they comment me the same/similar differences on the altitude.
                          This mean that if I wait until a good weather arrive, the altitude go back to correct values from the -14 of today? Thanks, nice info to check.
                          Just as curious: what is the fridge test?
                          Do you need that I put on the fridge (lower area) or fridge freezer (upper)?
                          Thanks again!
                            well let me set it like so :
                            In regards to weather:
                            When there is pressure change caused by good or bad weather the watch should record it as a pressure change. However, the watch only looks at the pressure. It has a pressure sensor. So there is threshold that defines if it’s altitude change or pressure change. 1hPA is ~6m (if I recall correct) so think about it a bit. If you see the pressure rarely changes more than 3hPA. Imagine that the storm alarm gets triggered if it drops 3-5hpa per I think 3 hours. So that means that if only in 3 hours you would have descented (in terms of alti) 24m or so it would trigger.
                            If the pressure changes faster than 1hpa or so it will assume you are moving vertically as well. Then the altitude will change. Can a weather change do this ? yes . not often.
                            Will it change back to the original? No most probably. Most rapid weather changes go over slowly and might not produce the same pressure drop as when they are approaching or might be less impact-full (leave a pressure permanent change)
                            Fridge will do . Leave it there to drop from eg 25c on you to ~10-0c and check that the temp changed and tell me the altitude diff after .
                              Thanks for your complete explanation! I understand this, but the watch not get the parameters of alti-baro profile from MS that when sense a pressure variations assign this to the weather and not to the altitude? Or I´m wrong and the watch do this only into a Sport Mode?
                              Near ~8m
                              Now I think that I get what you explain me. Sounds logic.
                              But the watch not have a method to compare this bigger differences with the GPS altitude to get a more precise altitude measurement? If not exist changes in the watch positions, mean that all this pressure difference is from the weather.
                              Done, but the only that change was the temperature. I believe that is correct because we not change the pressure neither the altitude. Results:
                              📈 1010hPa 🏔 -14m 🌡 21ºc
                              ⏰ After 20 minutes at fridge
                              📈 1010hPa 🏔 -14m 🌡 8ºc
                                @flypg great results love the icons. Your sensor looks more than fine.
                                On time mode the watch does not use any fused alti stuff.
                                Those are used only during activity. When indoors using the gps would be a disaster.
                                Lets keep an eye on this.
                                • Mff73M Online
                                  Mff73
                                  One little remark, is it me, or it there many more posts about altitude/ascent /fusedalti stuff these times?
                                  Personnaly hiking today. Altitude spot on at home 550m. 4 hours hiking after 30min drive. Watch altitude at Summit was 100m under reality. OK.
                                  Back home and altitude spot on again 😕🙄
                                  Dimitrios KanellopoulosD J 2 Replies Last reply Reply Quote 1
                                    Dimitrios Kanellopoulos Community Manager @Mff73
                                    @Mff73 😮 that doesnt make so sense does it?
                                    • Mff73M Online
                                      Strange indeed.
                                      My remark is more oriented on the fact that I read many posts here and in other forums, where people “complain” about this “altitude”.
                                      Something behind or just more people doing ascent during summer 🤔.
                                        johann.fuehrer Bronze Member @Mff73
                                        @Mff73 May I ask how you did drive? Bike, Train, Car? My assumption is, that when you go ie. by car, it is not recognized as movement and therefore the altimeter stays on the “home” level. I think this is how fused alti works. Could it be that there are really 100m altitude difference between “home” and end of drive and vice versa?
                                        • Mff73M Online
                                          Mff73 @johann.fuehrer
                                          @johann-fuehrer
                                          Thanks for answering.
                                          I made a mistake 😞
                                          Altitude ok at home before and after activity in watch mode.
                                          Ride by car from 550m to 1610m (real) without recording, so watch in “auto” mode . Not checked the altitude at start
                                          Then hike from 1610 to 2110 real (summit) and here is Altitude vs GPS altitude.
                                          Conclusion : no fusedalti in my hiking activity.
                                          Btw, alti at home is OK before and after.
                                            @Mff73 I think to solve this we would need to know the trigger for an altitude change when in watch mode - so when the watch assumes you are moving or static. Maybe some wrist movements triggers this from time to time. That would explain, why the difference is “only” 100m and not the full 1000m difference from “home” to hiking start point.
