    Doubt about Suunto 9 Baro altimeter/barometer calibration
    104 Posts 14 Posters 11.8k Views 17 Watching
    • mario_bM Offline
      mario_b @Guest
      @flypg if it’s the same algorythm that is used in the ambit3 peak for automatic mode then:
      When in watch mode, it messures every 10 sec. if you move up/down more then 5 meters in elevation (around 0,6hpa) in 3 minutes, it switches to alti-mode. when your are moving less then 5 meters in 12 minutes the watch switches back to baro-mode
        A Former User @mario_b
        Thanks @mario_b! Now I can understand for what on 1st try the reaction not was immediately and I got better results on 2nd try.
        Wow, I imagined that should be a lower value, by this I expected a faster response in the update of the altitude readings. But really not need a faster update in watch mode, because for this I have the Sport Modes.
        Thanks to everyone again!
          @flypg it counts higher than 3-5m variations in 12 minutes. If you would go a bit more low then both devices should react the same.
          That is to wipe out pressure changes as we talked before
            https://www.suunto.com/en-gb/Support/Product-support/suunto_9/suunto_9/valid-for-barometer-version-only/outdoor-insight/
            If you are at a constant altitude (less than 5 meters of vertical movement within 12 minutes), your watch interprets air pressure changes as weather changes and adjusts the barometer graph accordingly.
              Thanks again to everyone!
              Yes @Dimitrios-Kanellopoulos, this explains that on all my attempts I generated a altitude variation > 30m in less than 12 minutes (because I went up and down several times more than the 2 tests).
              The only that is not totally clear is the variation of 1st try that the S9B not registered this +4 of when I went up.
                johann.fuehrer Bronze Member @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos I have a Spartan Ultra: I’m sitting at the moment in my office at 214m above sea level. I know from the weather station on my altitude just some 2km away, that we have 2015.4 hPa at 30 C temperature. My watch shows me 2021 hPa. If I like to have a correct pressure reading, I would have to change the altitude to 165m. SO how can I bring this together to see correct altitude AND correct pressure?
                  A Former User @Guest
                  @flypg said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                  I published this myself a couple of weeks ago
                    Dimitrios Kanellopoulos Community Manager @johann.fuehrer
                    @johann-fuehrer is it sea level pressure? Can you give me now a coarse location (town)? I can look that up for you
                    J 2 Replies Last reply Reply Quote 0
                      https://www.zamg.ac.at/cms/de/wetter/wetterwerte-analysen/wien/luftdruck/?mode=geo&druckang=red
                      It’s Vienna and “Wien Unterlaa” is the station I mentioned …
                      https://www.zamg.ac.at/cms/de/wetter/wetterwerte-analysen/tawes-verlaufsgraphiken/wien_unterlaa/luftdruck/?mode=geo&druckang=red
                        @Dimitrios-Kanellopoulos … and yes, it’s seal level pressure. Local pressure is about 993 hPa
                        You can switch in the pressure chart caption!
                          @Dimitrios-Kanellopoulos said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                          Lets keep an eye on this.
                          I think that I understood some extra… On my workings days I use a lot the stairs. This results in variations of more than 5m in less than 12 minutes, that result that my watch change to alti-mode. When I have a weather change the pressure variation is assinged to the altimeter and by this I see this big changes on the altitude… can be possible or I´m totally wrong?
                            @flypg On watch mode there is no mode
                              @flypg for indoor activities there is automode
                                @johann-fuehrer yeah I see the same from my sources indeed looks like the watch is about 6hpa wrong right ? There is a tool that can calibrate the abs pressure but unfortunately only support can do that.
                                  @Dimitrios-Kanellopoulos is there any support here in Vienna which can do this?
                                  Dimitrios KanellopoulosD mario_bM 2 Replies Last reply Reply Quote 0
                                    @johann-fuehrer I am not sure 😕 I am very far away (in terms of internal comms) with support stations etc
                                      @Dimitrios-Kanellopoulos Thanks, I think that I need re-read all the post again 😌
                                      • mario_bM Offline
                                        mario_b @johann.fuehrer
                                        @johann-fuehrer ZAMG does not report QNH ambient pressure. They take the temperature into account. Compare your pressure with the Vienna airport QNH value: https://aviationweather.gov/adds/tafs/?station_ids=LOWW&std_trans=translated&submit_both=Get+TAFs+and+METARs
                                        They are reporting every 30 minutes. (Time is shown is UTC so don‘t get confused)
                                        You can only compare the ZAMG value when it is around 15 degrees Celsius in Vienna.
                                        Greetings from Tirol
                                        Dimitrios KanellopoulosD J 2 Replies Last reply Reply Quote 2
                                          Dimitrios Kanellopoulos Community Manager @mario_b
                                          @mario_b oh. Thats why the variation!
                                          mario_bM 1 Reply Last reply Reply Quote 1
                                          • mario_bM Offline
                                            mario_b @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos thats why i allways ask, 🙂 which ambient pressure is used to compare. because QNH is allways calculated with 15 degrees.
                                            and since my a3p is back from service, its spot on with every QNH value around me. 👌
