    Doubt about Suunto 9 Baro altimeter/barometer calibration
    104 Posts 14 Posters 15.8k Views 17 Watching
      freeheeler @mario_b
      @mario_b
      😱 15’000km service?!
      what was wrong with it?
        johann.fuehrer Bronze Member @mario_b
        @mario_b Hm, then I do not understand that:
        LOWW at 8:50 local time: 1020 mBar at 22 degree Celsius, altitude 183m
        ZAMG reading of Schwechat, 9:00 local time 1019.8 (998.6) hPa at 22.1 degrees Celsius, alt 183m
        ZAMG reading in Vienna at 9:00 for all stations in between 1019.4 and 1019.9, of course depending on altitude and temerature, which varies about 2 degrees Celsius.
        My reference from yesterday, Unterlaa at 9:00: 1019.6 mBar (996.6) at 21.8 degrees C, alt 200m
        My reading on the watch: 1024 hPa at 22 degree, alt 209 m
        So it’s off about 4 mBar. Or can you explain this?
          johann.fuehrer Bronze Member @johann.fuehrer
          @johann-fuehrer … that would be an altitude difference of about 35 m. I used this calculator: https://www.mide.com/pages/air-pressure-at-altitude-calculator
          • mario_bM Offline
            mario_b @freeheeler
            @TELE-HO šŸ™‚ more a 1000km service. but to be honest. it was nothing wrong. just a few other guys had the same value with ambient pressure, and mine did not match them. but altimeter worked flawlessly.
            i have to say thank you again to @Dimitrios-Kanellopoulos and the awesome suunto customer service for help. they wanted me to send the watch in to check if everything is ok. they’ve exchanged the pressure sensor. now it is spot on. i was just tooo nitpicky. (also i know that it will show a different value over time).
              freeheeler @mario_b
              @mario_b
              my experience with Suunto customer service is one of the best I’ve ever experienced!
              My wife had problems with her A3R from start (battery capacity calculation etc) and it was fixed within a week šŸ‘Œ
              Ok, I did not expect huge problems with your watch, good to know šŸ™‚
              I did not play around on the baro settings, I actually only use the alti mode and really never look at the baro itself.
              But it was a very good hint from you regarding the fused alti and when it kicked in. Next time I will know, thank you!
              mario_bM 1 Reply Last reply Reply Quote 1
              • mario_bM Offline
                mario_b @johann.fuehrer
                @johann-fuehrer just to be sure:
                • you know the exact elevation you are when reading your watch pressure? and the altimeter is set correctly?
                • you did the fridge test which @Dimitrios-Kanellopoulos mentioned above?
                • you are not inside a building?
                • mario_bM Offline
                  mario_b @freeheeler
                  @TELE-HO yes suunto service is fantastic.
                  no it really didn’t.
                  on small hikes i do not record it, but wanna know the nearly correct elevation. and a guy from search and rescue (with an a3p) told me: if you look at the nearest weatherstations ambient pressure and compare that with your watch, you know about +/-10-15 meters if your elevation is correct, without the need of activating gps. and that works very well. šŸ‘
                    @mario_b said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                    Definitely!
                    Yes, coming back to exact the same altitude. In my opinion it was very quick, some 5 minutes. But I’ll do it again if you like.
                    No.
                    I did check this also inside the office (open windows), so ambient pressure inside and outside should be equal, no aircondition and the behaviour is the same like outside.
                    mario_bM J 2 Replies Last reply Reply Quote 0
                    • mario_bM Offline
                      @johann-fuehrer so maybee it should be recalibrated. i would ask the support.
                        @johann-fuehrer said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                        Definitely!
                        No.
                        I did check this also inside the office (open windows), so ambient pressure inside and outside should be equal, no air condition and the behavior is the same like outside.
                        Finally, meetings are over: watch was 1 hour in the fridge @ 8 degrees Celsius:
                        10:00 before fridge, 1024 hPa, 30 C, @ 210 m
                        11:00 immediately after taking out the fridge, 1024 hPa, 8 C, @ 210m
                        11:15 another 15 mins later…, 1024 hPa, 25 C (still going up) @ 210m
                        LOWW & ZAMG still at 1020/1019.5
                        Dimitrios KanellopoulosD mario_bM 2 Replies Last reply Reply Quote 0
                          Dimitrios Kanellopoulos Community Manager @johann.fuehrer
                          @johann-fuehrer if not affected by temp your sensor is pretty well clean and no defect
                          • mario_bM Offline
                            @johann-fuehrer are you at the ā€œUmspannwerk Südostā€? that’s the only point which is on 200m elevation. according to different maps, the rest of unterlaa is between 165 and 180m of elevation.
                              @mario_b I had been, but now im at Hauptbahnhof/Belvedere which is (funny) also at 200m (Info from Geodatenviewer, wien.gv.at).But the pressure in different altitudes here in Vienna is not that big at the moment so that this would have an effect.
                              • mario_bM Offline
                                @johann-fuehrer if the baro works, so altimeter is correct, meanwhile i would not mind, because i know over time it slightly drift anyway. but if you care, i would contact the support. the support is really great and helpfull.
                                • Fatih KaleF Offline
                                  Fatih Kale
                                  Hi all,
                                  Yesterday I ran on a track while raining so watch was covered by my jacket.
                                  When I check altitude profile it’s veird. It shows that I went downhill but it’s not possible as I was at the same location turning around. Why could this strange values observed?
                                  Here is altitude profile
                                  link text
                                  Here is the temperature graph
                                  link text
                                  Suunto 9 Baro
                                  freeheelerF sartoricS Brad_OlwinB 3 Replies Last reply Reply Quote 0
                                    freeheeler @Fatih Kale
                                    @Fatih-Kale
                                    I’ve seen a similar behavior with my Suunto Core some years ago.
                                    When the sensor is covered or in contact with wet skin it seals off and or has a pumping effect.
                                    I would expect that this wrong measurement is detected by fusedalti, but until today I still don’t understand how fusedalti works in detail and what it does over an entire activity or when for some reason the alti is completely off reality.
                                      sartoric Moderator @Fatih Kale
                                      @Fatih-Kale
                                      Check if you also have some magnetic stuff (like magnetic jacket cuffs)
                                      Suunto App Android 6.3.3 beta
                                      • Mff73M Online
                                        Mff73 @sartoric
                                        @sartoric said in Doubt about Suunto 9 Baro altimeter/barometer calibration:
                                        @Fatih-Kale
                                        For altitude issue? 🧐
                                          Also if it was raining and there was a storm coming in, or any other air front, and you just came out of your place, the altimeter may be adapting to pressure change.
                                            sartoric Moderator @Mff73
                                            @Mff73
                                            mostly for gps (so fusedalti)
