    Difference between Running Performance Index and est. VO2
    42 Posts 6 Posters 7.6k Views 6 Watching
    • mario_bM Offline
      mario_b
      Hi!
      I am new to Suunto. What is the difference between Running Performance Index and est. VO2max. (When looking on the run in Movescount, recorded with Ambit3 Peak).
      Thanks very much for your help.
      As my understanding Running Performance Index is the estimated VO2max calculated with Firstbeat algorithms. but what is est. VO2?
      lexterm77L 1 Reply Last reply Reply Quote 1
        zhang965
        Hello Mario, do you eat mushroom?
        It’s the same.
        mario_bM 1 Reply Last reply Reply Quote 1
          zhang965
          Performance level is from Firstbeat,
          Est Vo2 should be estimated by movescount which I might another algorithm
          • mario_bM Offline
            mario_b @zhang965
            @zhang965 yes i like mushrooms for example chanterelles. but what has it to do with the question? 😉
            that are 2 completely different values. thats why i asked.
            i think the value on the watch is the running performance index. so i will look at that value. that fits nearly my values which i got with the garmin watch before.
            Thank you!
              zhang965
              just please ignore my asshole question,
              Garmin’s watch does use the Firstbeat algorithm so it’s normal to be the same,
              The one in movescount, I don’t know the algorithm, for me it’s always smaller the performance level and my lab test index
              mario_bM 1 Reply Last reply Reply Quote 2
              • mario_bM Offline
                mario_b @zhang965
                @zhang965 i have no problem with it. funny question / funny answer. ☺
                yes i know that garmin too use the same first beat algorithms. i am used to that an i like it. (don’t care about if the number is correct, but the trend for training)
                yes mine too. thanks for your help. i think i ignore the estimated VO2.
                  zhang965
                  you should have a try the runalyze’s Vo2 max estimation
                  • mario_bM Offline
                    mario_b @zhang965
                    @zhang965 i read that many times. but i like the simplicity of just a value and not have too many services in the background. also i like to see the 30day trend directly on the watch of the running performance index. (ambit3)
                      zhang965
                      luck you,
                      Goddamned Suunto 9 has no performance level
                      • mario_bM Offline
                        mario_b @zhang965
                        @zhang965 i went for the ambit3 because its the only watch from suunto which was a barometer and performance index. 🙂
                        may i ask you another another question? maybe you know that. on the sports mode running, i can set heart rate limits. so i set my lactate threshold as upper limit and thought i would get an alarm when reaching it. but it only shows me an arrow down next to the heart rate. is it possible to set such an alarm for running?
                        if not i think i can create a workout with upper heart rate limit 171 bpm. would that create an alarm? (have not tried it yet)
                          zhang965 @mario_b
                          @mario_b
                          I don’t remember anymore the details, but I do remember if I ran too quick, it will beep beep, so I deactivated all alarm
                            zhang965
                            check if your alert tones are ON
                            • mario_bM Offline
                              mario_b @zhang965
                              @zhang965 thx i’ll try that again.
                              • mario_bM Offline
                                mario_b @zhang965
                                @zhang965 yes i did. auto lap beeps. i just deactivated the button tones. that drives me nuts.
                                i’ll try with the workout. i saw a video on youtube and there was a beep.
                                thx!
                                  zhang965
                                  I don’t care about HR while running
                                  • mario_bM Offline
                                    mario_b @zhang965
                                    @zhang965 i do on longer uphills. (i suffer too much and get tired quickly) haven’t got the right feeling yet.
                                      zhang965
                                      I’m attacking 10KM for 40mins, but too hard
                                      • mario_bM Offline
                                        mario_b
                                        Just in case anyone is asking the same here is the answer:
                                        if you set a limit in the activity or in a workout on the ambit3 and you exceed that limit for more then around 1 minute then an alert is coming. before it only shows you an visual arrow back to the hr zone.
                                          I think that V02max is from first beat. Check their page I think A3 is listed for that
                                          • mario_bM Offline
                                            mario_b @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos hi! thank you but nope, the running performance index on the ambit3 is the one wich calculates the VO2max with firstbeat algorithms . the estimated VO2 must be from suunto.
