    Ambit3 Peak ambient pressure calibrating question
    15 Posts 4 Posters 923 Views 4 Watching
    • mario_bM Offline
      mario_b
      Hi to all!
      i have the ambit3 now for 2 weeks. and have seen that the barometer is always 3 hPa to high when the altitude is correct. so i went into the service menu and checked the ambient pressure compared to the other things i have around.
      Ambit3: 937 hPa
      iPhone: 933,77 hPa
      Garmin: 934,2 hPa
      analog absolut barometer: 934
      nearby weather station: 934,1
      does anybody know how to set the ambient pressure?
      or change the sea level pressure without changing the altitude?
      thanks much for your help and have a nice start into the weekend! ☺
      PrenjP 1 Reply Last reply Reply Quote 0
        Here it is your best friend 😁
        https://www.suunto.com/en-gb/Support/Product-support/suunto_ambit3_peak/suunto_ambit3_peak/features/alti-baro/
        SVTS - 2.40.38
        Suunto App Android 5.3.5 beta
        • PrenjP Offline
          Prenj @mario_b
          @mario_b
          I wouldn’t trust those devices to be more precise than suunto a3p. Even official weather stations nearby can be wrong, but if you are certain they are giving correct absolute pressure, to compare, you’d have to be at the same altitude as their barometer.
          Suunto Race
          • mario_bM Offline
            mario_b @sartoric
            @sartoric 😀 thanks very much, i read the manual, it does not show how to calibrate absolute pressure.
            • mario_bM Offline
              mario_b @Prenj
              @Emir-Karisik hi! i know. 🙂 just having all devices on the same table and all have been within around 0,5 hPa except the ambit, it was 3 hPa higher. i contacted the support if that is in range, they told me, that’s too much off. thank you!
                sartoric Moderator @mario_b
                @mario_b
                Yep, sure. Absolute is absolute 😄 but you can change Sea level one
                SVTS - 2.40.38
                • mario_bM Offline
                  mario_b @sartoric
                  @sartoric 🙂 is it possible to correct sea level pressure without changing the altitude value? how do you do that?
                    @mario_b
                    I don’t have the A3, but a friend does and I remember he can do it.
                    And the manual says “Sea level pressure: Set the sea level pressure reference value manually.”
                    SVTS - 2.40.38
                    • mario_bM Offline
                      mario_b @sartoric
                      @sartoric ah ok. this lets you set the altitude with the current sea level pressure for example from a weather station. so changing the barometer, changes the altitude too. thx again. i got a reply from Suunto. a 3 hPa difference between some other barometers should not be. i should send it in. but thx very much for looking for it. 👍 ☺
                      sartoricS Umer JavedU 2 Replies Last reply Reply Quote 0
                        @mario_b said in Ambit3 Peak ambient pressure calibrating question:
                        i got a reply from garmin.
                        SVTS - 2.40.38
                        mario_bM 1 Reply Last reply Reply Quote 1
                        • mario_bM Offline
                          mario_b @sartoric
                          @sartoric 😱 🤦 😁 from suunto!!! (corrected it) thx
                          • Umer JavedU Offline
                            Umer Javed @mario_b
                            Hey @mario_b Curious if the issue was resolved when you got your A3P back. I have an almost identical issue where my A3P reads the pressure higher. I figured it was maybe because my local weather station is far enough away that I’m getting that difference and I also live next to a large lake while the station is a few kilometers inland. But it’s a peculiar issue and curious if you ended up having your A3P read the same as the other barometers you were referring.
                            Cheers,
                            Umer
                            • mario_bM Offline
                              mario_b @Umer Javed
                              Hi @Umer-Javed!
                              The watch now works perfectly.
                              I use the Metar data from the next airport. I checkt a view times and it always nailed it.
                              😎👌 cheers Mario
                              Umer JavedU 1 Reply Last reply Reply Quote 1
                                Umer Javed @mario_b
                                @mario_b
                                Glad it worked for you, Mario!
                                Funnily enough I was considering reaching out to customer support because my watch baro was off while I was standing next to the airport at around the runway elevation and checking the latest METAR on a stable weather day… then I realized I had never checked the ambient pressure value in the service menu against something else. Interestingly my watch is apparently recording ambient pressure correctly, it was matching an older Garmin eTrex I have… I’m not sure why this ~3 hPa discrepancy between the METAR and the A3P. Interestingly, using the FusedAlti my A3P was giving me the correct runway elevation, almost to the meter.
                                This rekindled my childhood interest in flying lol so I’m definitely going to try checking my watch against other nearby airports/METAR. Should be a fun experiment hah…
                                • mario_bM Offline
                                  mario_b @Umer Javed
                                  @Umer-Javed sounds good! my watch also showed the ambient pressure too high. compared to other ambits. at around 2hPa. when altitude is the same, the pressure should also be the same.
                                  (but i have to say, it’s a “nice” to have, when it fits, specially when you are using the watch without GPS too. (i don’t track every evening hike). so it’s nice to look on your phone in a brake while hiking. and see if the barometer fits the next airport value. but i would not care anymore about it. over time, it could get inaccurate too.
                                  FusedAlti uses the GPS to calibrate the barometer. so even if your barometer is not working correctly the gps calibrates it to the same value. but i am glad i bought it. i think such a simple “workhorse” watch will never be build again.
                                  • Umer JavedU Umer Javed referenced this topic on
