    Syncing problems Ambit3 with iPhone11
    210 Posts 58 Posters 42.6k Views 58 Watching
      Dimitrios Kanellopoulos Community Manager @runnr_az
      @runnr_az https://testflight.apple.com/join/DJyDC5SU
      runnr_azR 1 Reply Last reply Reply Quote 1
        benoitg Bronze Member @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos it didn’t seem linked to the activities. In my case the app was showing Syncing with a progress bar progressing very fast and then Sync failed. Every time, for every activities.
        It wasn’t a problem with the watch or the phone going in sleep mode, you told us to watch for that and it is explained in the troubleshooting pages too.
        With the beta it worked more like in the movescount days: sync failed a few times, app showing « not connected » or sync failed, I turned off and on Bluetooth, start sync from watch, retried the process until it worked 🙂
        Next activity I’ll try to get you some logs to check.
        • runnr_azR Offline
          runnr_az @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos thx. install worked… will do an activity a bit later today, see if it syncs…
            Dimitrios Kanellopoulos Community Manager @benoitg
            @benoitg thanks for the explanation. Just making sure.
            runnr_azR 1 Reply Last reply Reply Quote 0
              lkovari @livia_Gmelin
              @livia_Gmelin
              Hi
              Not just the synch the paiting also failed for me A3 peak via iphone se 2020…
              • runnr_azR Offline
                No luck getting this to pair with the beta… nor could I export the workout from the debug menu. It eventually throws a “Failure: Archive or data fetch failed unknownError” message. It does seem to recognize there are three workouts there…
                When I just try and sync from debug, I get a “Header Parsing Failure”
                  @runnr_az said in Syncing problems Ambit3 with iPhone11:
                  Thank you
                    Dimitrios Kanellopoulos Community Manager @lkovari
                    @lkovari you cannot pair the watch ?
                      @runnr_az just to get this right. Did you manage to pair the watch ?
                      • runnr_azR Offline
                        @Dimitrios-Kanellopoulos yeah… the watch has always paired with my iPhone 11, it always seems to begin sync, but can’t seem to close the deal.
                          Hey guys I need your feedback if we need to get this fixed.
                          @runnr_az I you have a pm 😄
                          • Fermin Lopez UnzuF Offline
                            Fermin Lopez Unzu
                            @Dimitrios-Kanellopoulos has anyone tried iOS 14?
                            • P Offline
                              pcarval @Fermin Lopez Unzu
                              @Fermin-Lopez-Unzu @Dimitrios-Kanellopoulos I tried yesterday with Iphone 11 - IOS 14 same problem !
                              • P Offline
                                pcarval
                                @pcarval said in Syncing problems Ambit3 with iPhone11:
                                I also reset everything (unpair watch, delete from bluetooth…) and then restart from beginning.
                                Pairing the watch is still working … good news ! but after even the GPS Optimization failed ! Iforgot to add that I have also downloaded the latest Sunnto App. The real question is when you will admit that no one in Sunnto cares about managing this situation. I am wondering if it worths to continue to follow-up this subject on this forum. May be communicating on social Media & networks and explaining that a Sync problem openned in Sept. 2019 is still not solve, we help all people thinking about Suunto will reconsider their choice !
                                isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote -4
                                  isazi Moderator @pcarval
                                  Wow, someone that works for Suunto is trying to help you, and your answer is a veiled menace to social media blackmailing. Kudos to you sir.
                                  Fermin Lopez UnzuF 1 Reply Last reply Reply Quote 3
                                    Dimitrios Kanellopoulos Community Manager @pcarval
                                    @pcarval hi.
                                    as you can see I am helping here, and we have already a candidate for the issue.
                                    @runnr_az has sent us his watch for investigation and we thank him for that.
                                      Fermin Lopez Unzu @isazi
                                      @isazi I do not know what is your role in this suunto based forum. I totaly understand what @pcarval said as i am suffering the same situation for almost a year now. If i were working for suunto i would not dare to argue with an angry customer which is right. I was promised by suunto that i would be able to upload my activities using an app, and when they discontinued the movescount app we thought that the new suunto app would do the job, and it does not and no one is doing anything serious in the company. Otherwise they would have come with a solution long time ago.
                                      The only thing we have had is a “solution based in using a beta version of an app, tapping seven times somewhere in the phone, and entering in “debug” mode to do something I do not understand” every time I need to syncronize. By the way some people already said it does not work, and you say this is acandidate to solve the problem ?. I hope there is a better solution.
                                      isaziI Dimitrios KanellopoulosD Fermin Lopez UnzuF 3 Replies Last reply Reply Quote 0
                                        isazi Moderator @Fermin Lopez Unzu
                                        @Fermin-Lopez-Unzu said in Syncing problems Ambit3 with iPhone11:
                                        This is not “the solution” ™, it is a way in which Suunto programmers are debugging the issue and looking for a solution that can be rolled into production and finally solve the issue.
                                          Dimitrios Kanellopoulos Community Manager @Fermin Lopez Unzu
                                          I asked this personally and here its a community forum and not support. Even as a Suunto employee that I became recently (sept) this is not my work here.
                                          @isazi is a moderator voted by the community in the previous call for moderators.
                                          Regarding to what I asked from all the people here, only one person answered and his watch, is now on it’s way to investigate what is going to cut a long story short.
                                          Now, while I do understand your position and frustration, I would like to gently remind you once again that this is a community forum.
                                          That doesn’t belong to @isazi nor here please.
                                          B 1 Reply Last reply Reply Quote 5
                                            Fermin Lopez Unzu @Fermin Lopez Unzu
