    Syncing problems Ambit3 with iPhone11
    210 Posts 58 Posters 42.6k Views 58 Watching
      Brad_Olwin Moderator @Maryn
      @Marcin-Byrtek Thanks for the info, that is quite bizarre as the firmware should be very similar.
      • entropia437E Offline
        entropia437
        Suunto still does not provide any solution to Ambit3 Peak pairing problem with iPhone 11Pro with IOS13.
        Worst of all, it ignores the bracket.
        Very disappointed are Suunto. My next watch will not be from this brand.
        isaziI L 2 Replies Last reply Reply Quote 0
          isazi Moderator @entropia437
          @entropia437 what if the solution is that there is no solution, and that Apple changed something in their Bluetooth implementation in new phones that is not compatible with older devices?
          PrenjP entropia437E 2 Replies Last reply Reply Quote 0
          • PrenjP Offline
            Prenj @isazi
            @isazi said in Syncing problems Ambit3 with iPhone11:
            Entirely possible, but has there been an official statement about this from suunto? No? Do they not know or just don’t care? Anyway they are sending bad message to it’s current and possible (or not) future customers.
            Suunto Race
              isazi Moderator @Prenj
              @Prenj yeah I don’t know either. If it’s about the watches, well are the Ambits still getting updates? Could not find recent ones on the website. But if it’s something that can be fixed in software within the app, then let’s hope things will get better in future versions.
              PrenjP 1 Reply Last reply Reply Quote 0
              • PrenjP Offline
                Prenj @isazi
                @isazi no, no updates for almost 3 years now even they have not discontinued a3p officially.
                Suunto Race
                  Tundra_1980
                  Exactly the same issue here - iPhone 11 and Ambit 3 peak.
                    entropia437 @isazi
                    @isazi that is possible but Suunto is not giving any information. 😞
                      entropia437
                      … also, if it is a bluetooth problem with iOS13, why does it work perfectly with the Movescount application on the same phone?
                      I don’t think that’s the problem. What I think is that Suunto is taking advantage of the app change to stop supporting old watches.
                        elChai
                        Fortunately, I found this post. Unfortunately, I’ve an iPhone 11 and I just bought a A3P. It was at a good price, I understand why now 😞 Don’t know what to think about Suunto yet. I’ve also an old iPhone 5 and it works. But it can only be a temporary solution. Will post a request on Suunto assistance even if there is no real hope. Thanks to all contributors of this post.
                        • Bryan CookB Offline
                          Bryan Cook
                          Chalk me up as another sucker who bought the watch before researching these problems. I’ve never been able to get my Ambit3 Peak to sync correctly with my iPhone 11 Pro, after following instructions on how to forget devices and reset firmware. Been trying over all updates since January.
                          Hopefully they fix this problem, but Suunto has probably just taken my money and ran. Will be sure to steer away from them in the future unless this is fixed.
                            A Former User @JMOppenheim
                            @JMOppenheim said in Syncing problems Ambit3 with iPhone11:
                            Pity to hear so many people having the same issue without proper responses from Suunto. Maybe need to change brands.
                            Not to defend suunto, but if you do a quick search you understand other brands face similar issue.
                              Hopefully this will help, a new Suuntolink version here
                                entropia437
                                At last! thanks for the warning. It seems to work at least on the PC 😊
                                MarynM 1 Reply Last reply Reply Quote 1
                                • MarynM Offline
                                  Maryn Silver Members @entropia437
                                  @entropia437
                                  Please check if your hr zones are correctly displayed after sync .
                                  entropia437E 1 Reply Last reply Reply Quote 0
                                    entropia437 @Maryn
                                    Yes, everything is correct
                                      simonzn
                                      Same problem here with the new iPhone SE and iOS 13.4
                                      Ambit3 Peak SW: 2.4.17
                                      Suunto App Version: 1.20
                                      It took me about 6 attempts to pair my watch and the app - but I got used to that, as well as having to re-pair the devices on a regular basis for unknown reasons. I’ve had these problems with the old Movescount app and the new Suunto app, on both iOS and Android.
                                      Interestingly (or not), once the pairing was successful, very short activities are sync’ed. At first I suspected dodgy heart-rate readings to be the problem (my sensor has become a bit unreliable), so I recorded two activities of a few seconds, one with and one without heart-rate - both were sync’ed without problems.
                                      Edit: I recorded a third test-activity of > 1h with heart-rate - that failed to sync initially. Just noticed that about one hour later it was sync’ed as well. So it’s at least working to some degree, sometimes. All three of my test-activities were indoors without GPS data - I wonder if that could be the issue. Maybe the “GPS Optimization” (whatever that is) breaks the sync?
                                      I’m tired of opening tickets with Suunto’s support. I’ve reported about 20 issues in the last 3 years, at best I got a response about 3 weeks after, some of them have never been addressed. So what I would like to know instead: Is there a current Suunto watch that is known to work with iOS 13 on a recent iPhone?
                                      (Before anyone jumps ship and buys a Garmin watch, read the reviews for the Garmin app in the app store - it appears to be just as bad, and the customer support just as unhelpful.)
                                        Djanbgo
                                        Hello All,
                                        Having the same issue with my Ambit 3, and Iphone 11, with IOS 13.6 (I also had the same issue with previous IOS)
                                        I can’t sync the watch with the suunto Mocile app. I have read the entire page here, and followed adviced but it looks like the problem is still there.
                                        Any update from your side?
                                          entropia437 @Djanbgo
                                          @Djanbgo No yet for the App.
                                          You can solve the problem update Suuntolink and sinc.
                                            schiggy13
                                            Same issue here.
                                            Ambit3 and iPhone XS. The synchronisation-issue costs me hours and hours. So much errors with long “large” hiking activities.
                                            Short walks are fine.
                                            I will use the usb cable and notebook in the future…
                                            Please fix it…
