    1.1k Posts 159 Posters 212.3k Views 151 Watching
    • Jonathan NewbyJ Offline
      Jonathan Newby @tomviv
      @tomviv yes there is I have it.
        You guys know the update can take time, probably in few hours everyone will get it.
          tomahawk5000
          at last, I really count on new watch faces šŸ™‚ but they didn’t add
          ps it’s my first udate, should I after update restart or wipe device?
          Kind regards,
          Tomek
          Suunto 9 baro + Android
          Saketo NemoS 1 Reply Last reply Reply Quote 0
          • horvathbotondH Offline
            horvathbotond
            Sorry, there aren’t any…
            • cosme.costaC Offline
              cosme.costa
              already updated…but no way to test anything outdoors due the confinement…
                Jonathan Newby
                Cant see much apart from trainingpeaks. But let’s wait on more details.
                • Saketo NemoS Offline
                  Saketo Nemo Moderator @tomahawk5000
                  @tomahawk5000
                  nope, is not necessary
                  Kostas Zinelis 0K 1 Reply Last reply Reply Quote 1
                  • Kostas Zinelis 0K Offline
                    Kostas Zinelis 0 @Saketo Nemo
                      Kostas Zinelis 0 @freeheeler
                      1. Ability to export POI’s to SA
                      2. Ability to turn on and off hr monitoring during exercise
                        Mff73 @Kostas Zinelis 0
                        @Kostas-Zinelis-0 said in Future S9 firmware wishlist summary:
                        1. Ability to turn on and off hr monitoring during exercise
                        It should be there already.
                        https://forum.suunto.com/topic/4182/software-update-2-11-38-for-s5-s9?page=1
                        Kostas Zinelis 0K J 2 Replies Last reply Reply Quote 0
                          Kostas Zinelis 0 @Mff73
                          @Mff73 No it’s not. I’ve tried it some hours ago.
                            Jonathan Schwarz Bronze Member @Mff73
                            @Mff73 said in Future S9 firmware wishlist summary:
                            I wish the new ā€œTurn off wrist HRā€ option would save the memory of what you selected the last time. Just like the other settings. To add to that, I wish the SuuntoPlus did as well!
                            Suunto Race Steel All Black -
                            Suunto 9 Baro (retired)
                            Suunto Ambit 3 Vertical Lime (retired)
                            Suunto App - Always latest version
                              I can’t check, no update for me.
                              Don’t hesitate to reply in the update post, because i understand that
                                isazi Moderator @Mff73
                                @Mff73 you can select that on S9/S5 before starting an activity. No idea if it works mid activity, but apparently not according to the comments here.
                                • H Offline
                                  hel790
                                  The possibility to calibrate the Indoor Rowing distance measured.
                                  Additionally, capture the total stroke number (through the accelerometers, it’s just the horizontal back-forth horizontal movement šŸ˜„ )
                                  Over the top would be to allow the device to pair with Concept2 ergs, retrieve rowing metrics from it while providing heart rate data to the PM5 . That would be awesome
                                    Dimitrios Kanellopoulos Community Manager @hel790
                                    @hel790 Stroke is there …
                                    Distance impossible if not paired as a BT pod sensor
                                    • H Offline
                                      hel790 @Dimitrios Kanellopoulos
                                      @Dimitrios-Kanellopoulos Actually no
                                      Distance is measured by default without external sensors (although only approx. 1/2). No stroke rate.
                                      https://www.suunto.com/pt-pt/move/hel790/5e80f945c749e334ff7fcd3d
                                      https://www.strava.com/activities/3232769277
                                        @hel790 I can see cadence and that is your stroke rate.
                                        How do you expect it to record a correct distance since it doesn’t know the intensity ?
                                        • H Offline
                                          @Dimitrios-Kanellopoulos There is no cadence on the Suunto log . The Strava one was uploaded from the rowing machine. Notice the difference in distance
