    1.1k Posts 159 Posters 212.3k Views 151 Watching
      Dimitrios Kanellopoulos Community Manager @hel790
      @hel790 If also Strava has a direct sync from concept then I see that the s9 has done a good job for cadence 😉
      • H Offline
        hel790 @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos Cool. Sorry I neglected that. Indeed the cadence is on point 🙂
        So, we should only need to ‘calibrate’ the correct distance in, even if manually 🙂 during the exercise through some option
          @hel790 Correct , or afterwards. There is though an issue…
          You should be able to edit the distance in the suunto app but it wont get synced to partners. This is an open issue on our side for now. Sorry about that.
          However in your suunto app , totals etc should be just fine.
            @Dimitrios-Kanellopoulos said in Future S9 firmware wishlist summary:
            @hel790
            You could, as a workaround, turn off WiFi and data connection on phone before syncing. Then enable it again after the activity has been modified
            Suunto App Android 6.2.2 beta
              Matze Bronze Member
              I would also lave to see stronger vibration or vibration strength customization.
                tkernen
                I’d really like the paired sensor list to actually provide the name of each device for the paired pods. To make sure it is the right pod that is paired.
                L 1 Reply Last reply Reply Quote 8
                • L Online
                  Likarnik Bronze Member @tkernen
                  @tkernen yes, this is a must for me and also multiple sensors of same type
                  • Bjørnar SeimB Offline
                    Bjørnar Seim
                    I want the opportunity to have more than one heart rate belt paired to the clock and see the name of the device paired against the clock.
                    for example:
                    I have an OH1 polar and a suunto HR monitor. I use them for different activities. I won’t have to pair them up every time I switch
                    zhang965Z 1 Reply Last reply Reply Quote 3
                      zhang965 @Bjørnar Seim
                      @Bjørnar-Seim said in Future S9 firmware wishlist summary:
                      for example:
                      Same here.
                      • pcm_smeetsP Offline
                        pcm_smeets @freeheeler
                        @TELE-HO
                        I’d like these functions
                        • light button in watch/activity mode (no unlocking)
                        • lockbutton in watch mode (e. g. 3sec press)
                        • possibility to adjust altitude during tracking a hike. I could adjust the altitude manually during hiking on my Traverse amber. But not on the baro 9.
                        freeheelerF 1 Reply Last reply Reply Quote 6
                          freeheeler @pcm_smeets
                          @pcm_smeets said in Future S9 firmware wishlist summary:
                          fused alti does that for you.
                          don’t adjust it before you start an activity 🙂
                          pcm_smeetsP 1 Reply Last reply Reply Quote 4
                            Jonathan Schwarz Bronze Member
                            I’d like to see custom sport modes remember the last used configuration (ie WHR, sensors paired, SuuntoPlus choice, etc)!! That would make starting an activity so much quicker
                            Also there is a lag when selecting an Exercise type before you can scroll down into the options which also slows time to starting an activity
                            Suunto Race Steel All Black -
                            Suunto 9 Baro (retired)
                            Suunto Ambit 3 Vertical Lime (retired)
                            Suunto App - Always latest version
                            • stromdiddilyS Offline
                              stromdiddily Gold Members
                              I’d like to see any one of the outdoor Suunto Plus items proposed in the survey integrated.
                              • andrejsgA Offline
                                andrejsg
                                I’d love to see:
                                • strava live segments
                                • custom interval durations (e.g. no 75 second option!)
                                  -new watch faces
                                  -data together with the navi screen. garmin has had this forever now.
                                  -ability to have interval and navi screen on during activity
                                  -enable/disable/change suunto plus mid-workout.
                                  -fix the lag with cycling stop/go/autopause. it’s so slow, it’s unusable.
                                or whatever the new S10 has in stock… hopefully much thinner with stronger vibration and faster UI.
                                andrejsgA 1 Reply Last reply Reply Quote 3
                                  @zhang965 said in Future S9 firmware wishlist summary:
                                  for example:
                                  Same here.
                                  This has been a long-standing request and especially from cyclists that want multiple speed sensors paired. My T6c could pair two HR belts. I don’t know why multiple pods/HR monitors are not implemented. I read long ago on DCRainmaker a statement that he made saying Suunto was aware of this and had plans. Not sure of that now.
                                  • Rob33R Offline
                                    Rob33 Bronze Member
                                    First use of route tracking for a long time and always problems:
                                    • When crossing paths with close tracks, if wandering the course is reset without warning … If you are not attentive or on another screen you are wrong without realizing it. When will we receive an alert to just report the change from the basic route?
                                    • in the same way on nearby trails, the track can be reset on the wrong trail then leave and direct us to a track where we have already passed, hence an elongation of the course more or less long according to the route (seen this morning)
                                    I remember having exchanged on this forum and on FB on this subject, several Suunto users had also encountered this concern. This complicates navigation!
                                    Why not create an alert:
                                    a vibration + a message to choose: confirm the voluntary change of track or the desire to stay on the basic route and therefore either turn around or cut to find the right track
                                      A Former User @freeheeler
                                      @TELE-HO
                                      I find both alarm and vibration could be more recognizable.
                                      Especially for running in HR Zones. Sometimes it is not noticeable (depending on conditions I’m running).
                                      If vibration motor can not got harder, I would like to adjust a longer vibration time.
                                      Or continuous with small interuptions.
                                      Same for alarm. There should be a continuous sound. Not only once…
                                      I would also like to adjust these settings only for training (sound is always off / training always on).
                                      This would be not so hard to do from software point, but I think a big thing for training feeling.
                                      It is not so relaxed, if go on the long run in HR Zone 2 and have to look very often on watch, if you are still in.
                                      I remember 20 years ago, my first HR watch from polar, which had a continuous alarm, if you were out of zone.
                                      The long run is much more deep, if you do not have to look so often on watch.
                                      Please Suunto, this is essential for training. 🙏
                                      T Brad_OlwinB 2 Replies Last reply Reply Quote 5
                                        tomahawk5000 @Guest
                                        @mountainChris totally agree with this what you wrote. I have never missed vibration about autolap because it’s longer than HR zone. And there should be something about audio off for notification and audio on for training
                                        Kind regards,
                                        Tomek
                                        Suunto 9 baro + Android
                                        • gerasimosG Offline
                                          gerasimos Bronze Member
                                          I’d like to see a real time breadcrumb in suunto app map when sync via Bluetooth my S9 watch “on the fly” when I do a trail run.
                                          This feature will be very useful to navigate and see your progress in exercise mode and modify the route
                                          Suunto Vertical Ti
                                          Suunto S9 gen1
                                          Suunto Ambit3 peak
                                            Brad_Olwin Moderator @Guest
                                            @mountainChris said in Future S9 firmware wishlist summary:
                                            @TELE-HO
                                            I absolutely do not want a continuous alarm when I go out of HR zone. I think it is perfect the way it is implemented. If you use the zone ring it is immediately obvious what zone you are in. When trail running it would be incredibly annoying to have the alarm continuously going off. Sorry but while doing long trail runs I often go above zone on uphills and below zone on downhills. It is impossible to keep in a high zone on technical down hill trails.
                                            L Kurt68K ? M 4 Replies Last reply Reply Quote 1
