    1.1k Posts 159 Posters 241.2k Views 151 Watching
    • tomvivT Offline
      tomviv Bronze Member @Brad_Olwin
      @Brad_Olwin Please could you explain how you do this. I thought you could not use both SA & MC app at the same time.
      X10, Vector, Ambit2, Suunto 9 Baro + HR smart sensor, PolarX10 HR strap (current) & SA 2.24.1
      Walking, hiking, running, climbing & mountaineering.
      • auxinaA Offline
        auxina
        Probable date of death \(◎o◎)/
        Garmin will put it soon.
        • Another metric.
        S9B Titanium Iron Man
        2.26.8
          freeheeler @auxina
          @auxina
          what if watch is wrong, will I get my money back?
          • Fenr1rF Offline
            Fenr1r @freeheeler
            This post is deleted!
              Brad_Olwin Moderator @Fenr1r
              @Fenr1r said in Future S9 firmware wishlist summary:
              @Brad_Olwin As stated above (a few times):
              Well aware of the apps. The thread’s about FW for the watch. My particular insane wish is for the watch to do navigation things the A3P and the Fenix series do (minus the latter’s maps). Without having to haul out and fire up a phone that might be in a rucksack, etc.
              So I don’t understand what you are missing? Once waypoints and POIs are implemented (assuming we can name them) what more would you need. The fenix can plot a route on the watch but not the A3P and the A3P cannot calculate or display distance along a route, only in a straight line to the next waypoint. I found that essentially useless, so waypoints on A3P were not as good as the dual app solution we have now for the S-series.
              • Fenr1rF Offline
                Fenr1r @Brad_Olwin
                @Brad_Olwin Short version: I’ve nothing against the Dual App Solution (worst prog rock band ever). It is just that the watch could be more. Navigationally, the Fenix is. In remote areas, why require a second potential tech failure point? Or drain two batteries via BT (and a display) rather than one.
                Longer version I’ve PM’d to avoid clogging this thread. Bit of a screed but explains the usage cases/arguments.
                • Fatih KaleF Offline
                  Fatih Kale
                    Fatih Kale @freeheeler
                    @TELE-HO said in Future S9 firmware wishlist summary:
                    while I enjoy the latest S9 firmware, I don’t want to make an ungrateful impression…
                    But I’d like that we summarize some suggestions as a list…
                    • light button in watch/activity mode (no unlocking)
                    • lockbutton in watch mode (e. g. 3sec press)
                    • swipe left-right to flip screens in activity
                    • toggle satellite systems on-off independently
                    • HR info (and pace?) in navigation screen
                    • longer duration of vibration for alarm
                    • FW update by bluetooth and SA
                    • blood oxygen saturation (in case Valencell is ready for this?)
                    anything else?!
                    Just a little addition
                    On Navigation Screen
                    Data Field for “Distance covered / Total distance (If route is used)”
                      freeheeler
                      I know I mentioned a proper lock in watchmode already… this becomes more relevant in wintertime I noticed today.
                      During summer I only need to lock my watch in activities to prevent unwanted button press while I’m working hard 😉
                      … but in winter I use gloves everyday and sleeves of winterjackets are also bulky… all these help to do unwanted button press…
                      I know by own experience that scandinavians only wear hats and gloves when it starts getting cold (like - 20°C) but it would be cool to add this before winter is over 🙂
                        freeheeler
                        … this lock in watch mode would be also good when for swimming in the lake or pool… because I was in watch mode and wanted to switch from alti to battery icon I had to “unlock” the screen.
                        But then the touch does never get deactivated because water keeps the touch active and the auto “lock” never kicks in.
                        locking manually would really help here
                          freeheeler
                          showing a flashing heart symbol next to HR value in the rhythm as HR is measured as a possibility to double check if OHR is measured correctly
                            BKtoo Bronze Member @freeheeler
                            @TELE-HO the light buttom in exercise is solved in option-battery- custom battery- touch screen. Then you just tap the screen to make the light go on fore some sek.
                            freeheelerF ? 2 Replies Last reply Reply Quote 0
                              freeheeler @BKtoo
                              @KnutB
                              I wish for a light button in watch mode and a manual lock button in watch mode…
                              and while I think of my original post and swipe left-right is possible it would be good to make swipe possible in activity mode even when buttons are locked…
                              or long story short: make a toggle to choose if you like to lock only buttons, only touch or both 👌
                                A Former User @BKtoo
                                @KnutB said in Future S9 firmware wishlist summary:
                                Until it rains… Good luck with using the touch screen when it is wet.
                                  freeheeler @Guest
                                  @silentvoyager
                                  that’s why lock should be possible to toggle for buttons and/or touch
                                  maybe long press lower button lock buttons and longpress upper button lock touch?
                                    @TELE-HO think the best thing would be that the first push of the middle button activates light. Next press activates screen switching (same as in clock mode)
                                    Brad_OlwinB 1 Reply Last reply Reply Quote 5
                                      Brad_Olwin Moderator @BKtoo
                                      I think this is a bad idea as those (me) wanting long battery life would be activating the light a lot and battery life for long events would be seriously affected. Sorry, but I think the negatives for this are far worse than positives.
                                      freeheelerF B 2 Replies Last reply Reply Quote 0
                                        freeheeler @Brad_Olwin
                                        @Brad_Olwin
                                        that is also true…
                                        in general it would be good to have more customization of button behaviour. I see a lot of people have different requirements even for the basically same type of sport.
                                        I noticed that I will not need switch on and off lights during an activity. If I go for a run at night 30% backlight permanent on is plenty of light to see the display even with a blinding/reflecting headlamp.
                                        Right now I do a batterylife test with 24h HR and standby light on. (it seems standby light is what it is and not adjustable?)
                                        But for me it’s good enough without the standby light.
                                          BKtoo Bronze Member @Brad_Olwin
                                          @Brad_Olwin but the backlight is activated anyway when you push the middle button. So I can see that the battery drain will increase? The only difference is that the first push on the middle button does not enable display switching, but only backlight.
                                          • stromdiddilyS Offline
                                            stromdiddily Gold Members
                                            1. Improved notification process
                                              Dismiss/delete notification from the watch itself
                                              Not repeat notifications if a new one comes in and the previous had not been cleared on the phone
                                            2. Improved contrast for navigation lines when theme is set to “light” (blue works well against black but is a bit tough with a white background)
                                            3. Configurable nav screen (related to yours above but personally care more about duration/distance/lap pace)
