    1.1k Posts 159 Posters 242.2k Views 151 Watching
    • EfejotaE Offline
      Efejota Bronze Member @Soojong Moon
      @soojong-moon I will be fine with the possibility to change S+ during exercise. I found it very cumbersome to have many screens and having go to through all of them to get to the required info. My only complain in that case would be the Safe feature. It should be possible to have it activated since the beginning for some users, as it provides distance, bearing and altitude inference since start.
        What about SportMode with S+ pinned?
        Ie Hiking + weather
        Running (intervals) + sprint
        surfboomerangS GNZ ctG EfejotaE MdzOttM 4 Replies Last reply Reply Quote 6
        • surfboomerangS Online
          @dimitrios-kanellopoulos What if I want something else then the pinned one?
          For example: running + weather instead of running + sprint
          Or do you mean I can set my own pin preference?
          • GNZ ctG Offline
            GNZ ct @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos i guess configured in custom sport modes in app
            • EfejotaE Offline
              Efejota Bronze Member @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos sounds very good, like a default S+ that you might change if you need something else.
                I still prefer to enable the S+ when necessary before the activity. Some S+ apps are too impactful (i.e. they generate laps and do things) to have them always there when I do not need them, and I do not want to create a custom mode for every activity, I like the default modes and use them 95% of the time.
                So, I want everything to remain as it is, except being able to change S+ during the activity 😄
                  A Former User @isazi
                  How about the following thoughts:
                  You have one „screen“ to configure x different S+ options, e.g.: climb laps, NGP data field and lat/long of rescue field
                  With this Suunto can limit the needed software resources but gives users the flexibility to use different options of the S+ possibilities.
                    isazi Moderator @Guest
                    @_marcus_ sorry I don’t understand your idea. Even if you would combine different S+ apps in a single screen, if they are all working they are still consuming resources. And some are even conflicting, creating laps for different reasons.
                      I try it with the following example
                      Choose a metric for each data field out of the S+ options:
                      Data field 1: NGP
                      Data field 2: Weather e.g. hPa with arrow up/flat/down
                      Data field 3: LAT/LONG
                      Lap counting mechanism: choose one
                      Climb - Sprint - Loop
                      Know what I mean?
                        @_marcus_ I understand now.
                          I don’t know if there are many real life scenarios. For trailrunning I could imagine that example.
                          • MdzOttM Offline
                            MdzOtt @Dimitrios Kanellopoulos
                            @dimitrios-kanellopoulos i suggested this earlier - remember the last used setting (e.g., the S+, Target, Wrist HR, Battery mode).
                            I know that you may want to change it occasionally, but even if you reuse once, you already saved yourself some clicks.
                            Or, in the defined sport mode, have an option to select all options (I think what @GNZ-ct suggested, but a bit expanded).
                            btw. it would help if you could scroll around the options (in a loop). If you preferred option in S+ is Weather, you have to scroll through almost all other options (you are lucky, if you always select Climb).
                            R2
                            S9 Baro
                            SA on Android
                            Ambit 3 Peak
                            Ambit 2 Sapphire
                            northeast_trekkerN 1 Reply Last reply Reply Quote 4
                            • northeast_trekkerN Offline
                              northeast_trekker Bronze Member @MdzOtt
                              @mdzott the loop idea is a great one. I find 90% of the time I just want the weather page and it is annoying to either not have the ability to customize order of the list or no ability to more quickly get to what you want.
                              sky-runnerS 1 Reply Last reply Reply Quote 3
                                sky-runner Silver Members @northeast_trekker
                                @northeast_trekker The list should reorder according to most recently used S+ apps.
                                And ideally S+ should be customable in the app per sport mode. Having to select it every single time on the watch was OK when S+ was first introduced, but I expected that to be made customizable in a next app update.
                                  A Former User @sky-runner
                                  After some experience with A3P and some garmin devices (FR45, 245 and F6S) and now the S9P, what I think it misses on the S9P firmware (should be same as S9B)
                                  • Customization of data fields on watchface
                                  • Quick toggle for airplane mode (on the same page as do not disturb)
                                  • Broadcast ohr to other devices (not super needed, but nice when your forgot your hr strap)
                                  • EzioAuditoreE Offline
                                    EzioAuditore Gold Members @Guest
                                    I would really like adding the shortcut to the airplane mode in the shortcuts menu 😞 I usually turn off the BT radio at night when I sleep or when I do not want to receive notifications and the steps I have to take to disable/enable it are too much imho.
                                    • pavel.samokhaP Offline
                                      pavel.samokha @EzioAuditore
                                      @hristijan-petreski why not use DND mode for that?
                                        EzioAuditore Gold Members @pavel.samokha
                                        @pavel-samokha for one DND does not disable the radio emitting, secondly I do not have every-day’s meeting in the same time during the day so to enable it. I use it at night but that is that.
                                          @hristijan-petreski you can enable/disable DND any time via shortcuts menu, just saying
                                            @pavel-samokha I know 🙂 But I may not have been clear enough. I do not mind the notifications so much as much as I like to reduce the emission around me. I know it is minor but it is close to you especially when you sleep and you have your hand near your head for example, etc. There is the wi-fi, the philips hues, the netatmo sensors, other BT devices and all this combined results in increased radiation (not to mention the neighbors wi-fi and devices). For example in garmin forums one guy measured the radiation of the fenix 6 (if you do not toggle airplane it emits wi-fi, bt and ant+) and found it to be huge. So I was just trying to find a fast way to disable the BT radio.
                                            DMytroD 2 Replies Last reply Reply Quote 1
