    1.1k Posts 159 Posters 242.2k Views 151 Watching
      DMytro @EzioAuditore
      @hristijan-petreski may your provide links for “that guy’s” measurement? I wonder what exactly did he measure. Bt and WiFi frequently ain’t your typical gamma rays, so one won’t become hulk overnight.
      EzioAuditoreE 1 Reply Last reply Reply Quote 3
        @hristijan-petreski I’m not telling you what to turn on/off, but just saying - humans shouldn’t be affected by these frequencies. It follows from “common sense” as well as from inconclusive research trying to prove otherwise
        • EzioAuditoreE Offline
          EzioAuditore Gold Members @DMytro
          @дима-мельниченко Yes I will try and send this later it was in some sub-question not directly aimed at the airplane mode and radio emission. Basically it is what you say that the emission is surely ‘less’ than a mobile (I might used the wrong word ‘huge’ in my previous post) but nevertheless I just expressed my opinion to turn it off/on.
            @hristijan-petreski nonono, I don’t mean that it’s less or more than that of a phone(it indeed is, but that doesn’t matter now). I’m saying that it’s all about frequency not intensity: only UV frequencies and higher may be harmful to humans.
            I suppose “harmfulness” boils down to DNA damage which may cause cancer. In this case imagine your trying to shoot tennis balls through a key hole: it just won’t fit. That’s the same with low frequency photons and DNA. Very very roughly of course, I’m not an expert on this subject and may be wrong, it just doesn’t make sense.
              Brad_Olwin Moderator @DMytro
              @дима-мельниченко You are enough of an expert it seems but you are correct. There are other biological activities that could be affected by long range frequencies and those include the electrical gradients across cell membranes (how nerves conduct and how your cells generate energy) but those are not going to be affected by radio frequencies.
              lexterm77L 1 Reply Last reply Reply Quote 3
              • lexterm77L Offline
                lexterm77 Bronze Member @Brad_Olwin
                Non ionizing radiation consists of photons that carry too little energy to knock electron off an atom, all absorbed energy is therefore converted to heat. Your bt wifi or mobile radiation would heat your body by a about a very small fraction of what sun wave does to you. To do any harm you need photons that are less than 124nm wavelength or more than 10eV. To compare middle spectrum of visible light (about 500nm wavelength) and bt or mobile or wifi is several cm. Energy carried by photons of bt wifi or mobile device is roughly 120-240 thousand times weaker than green light. Green light is about 4 times weaker than ionizing radiation. It does not matter if it is 1Million watts or 10mW, if it does not knock electrons off an atom only result is heat. If your watch, mobile, microwave does not cook you, you will survive.
                • C Offline
                  chrisc92 Bronze Member @stromdiddily
                  @stromdiddily very good idea . Garmin just released a new sport mode for the Enduro watch which is the direct competitor of s9 line (but from 80 to 300 h autonomy vs 25 to 170 h)
                  Ultrarun Activity:
                  Rather than selecting a run or trail run activity, we’ve added an ultrarun activity profile to Enduro that includes a built-in rest timer. If you’re running in an ultra race or marathon, you’ll be able to utilize the rest timer and log the time spent at aid stations — so later on, you’ll be able to see exactly when you were running and when you weren’t.
                  I think it is a good idea for suunto as the brand has a long battery life strategy for long activities. And this is not a complicated function just laps markers .
                  • surfboomerangS Online
                    surfboomerang
                    Navigation screen feature request: A dual swipe menu
                    Since the S9P has a full round screen instead of the S9B which has a flattened part at the bottom, it crossed my mind how we can benefit from this “extra” space at the bottom. Noticing the rotating information if you go into navigation settings, I thought it would be great to see that rotating information all the time without the menu blocking the route view.
                    So the feature would include 3 views of the navigation screen controlled by the number of times you swipe up or down.
                    Default: Full navigation screen
                    First swipe up: Permanent menu part on the bottom with pre-determined fields which auto-rotate or (even better) customizable datafields. Stays active while selecting different screens.
                    Second swipe up: Full navigation menu options
                    And swipe down for the reverse order.
                    This way the person can choose for itself if it wants to see the whole route or a flattened bottom part, but with some extra information.
                    Brad_OlwinB stromdiddilyS 2 Replies Last reply Reply Quote 20
                      @surfboomerang Great idea
                      • stromdiddilyS Offline
                        stromdiddily Gold Members @surfboomerang
                        @surfboomerang ETA there would be AWESOME
                        F 1 Reply Last reply Reply Quote 2
                          Frederic Bronze Member @stromdiddily
                          Wish Item:
                          An option to automatically lock the watch after starting an activity
                          My Suunto Workflow
                          MyTourbook - First Steps
                          Questions or bugs ?
                          freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 3
                            freeheeler @Frederic
                            @frederic
                            whaaaaat? auto lock? your wild fantasies go beyond far 😉
                              Power off option like peak have in general settings. Time to rest.
                                Brad_Olwin Moderator @Frederic
                                @frederic I prefer the way it is, easy to lock if you want to. I do not want an autolock as during interval running I would forget and miss an interval. The watch is so easy to lock why is this an issue?
                                  Frederic Bronze Member @Brad_Olwin
                                  @brad_olwin I am not saying to have it locked at all times. I was just asking for an option to lock (or not… your choice thanks to a toggle) automatically upon the start of an activity. By default, I always lock my watch and unlock it when I need to. But that’s just me I guess.
                                  My Suunto Workflow
                                  Questions or bugs ?
                                    @frederic
                                    you are not alone… I would lock it even more, if possible 😁
                                      Frederic Bronze Member @freeheeler
                                      @freeheeler And that’s without saying I am still waiting for the ability to lock the watch when not recording an activity…
                                      My Suunto Workflow
                                      Questions or bugs ?
                                        @frederic But you can lock the buttons at the start of an activity, I am confused. And as I said, I do not want an automatic lock at the start of an activity since I can lock anytime I want to during an activity.
                                        F 2 Replies Last reply Reply Quote 0
                                          @brad_olwin Not sure what’s confusing…
                                          Indeed, I can and do lock the buttons but having the watch lock automatically would be even “nicer”
                                          My Suunto Workflow
                                          Questions or bugs ?
                                            @brad_olwin In my mind, it would only lock if you have chosen so in the watch preferences. So that should not impact users like you that want the watch to remain unlocked.
                                            But again, I’ve asked since 2018 to have the capability to lock the watch when not recording an activity and I’m still holding my breath so that might also be a “pie in the sky” kind of wish list item…
                                            My Suunto Workflow
                                            Questions or bugs ?
