    Suunto 9 with the recent GPS firmware was among least accurate GPS watches in today's 25K trail race
    221 Posts 34 Posters 40.9k Views 32 Watching
      @Łukasz-Szmigiel so today I must have got one of the best GPS tracks ever in my home area using Galileo. Unfortunately it’s too close to home to share it, but I was very impressed!
      N 1 Reply Last reply Reply Quote 3
        Perhaps if posting here we can revive mr SilventVoyager
        I can share that the latest FW for the Sony chip on both S9/S5 performs oustanding.
        Regarding distance, I always get more than Stryd , road or trail. Personal. But about 0.05-0.15 to A3
        Łukasz SzmigielŁ surfboomerangS Brad_OlwinB 3 Replies Last reply Reply Quote 4
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos you mean - unpublished firmware?
          S9PP 2.44.52
            Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
            @Łukasz-Szmigiel yes I get (among others) Fieldtest SW to test.
              @Łukasz-Szmigiel FYI that is not stable nor something a normal person would benefit from.
              As soon, and as across countries and continents, we can pass several tests we can say that it’s a safe FW to go ahead with.
              • N Offline
                nseslija Bronze Member @isazi
                @isazi now that you’ve mentioned, I also had one of the best GPS tracks this last weekend while hiking… with GLONASS although…
                Ambit 2S
                Ambit 3 Peak
                Suunto 9 baro
                Suunto Vertical Ti Solar
                  @Dimitrios-Kanellopoulos said in Suunto 9 with the recent GPS firmware was among least accurate GPS watches in today's 25K trail race:
                  😳 😍 Can’t wait.
                  Are the speed spikes/wobbles also fixed on higher speeds? It got way better in the current firmware, but there is room for improvement as it still fails sometimes
                    @Dimitrios-Kanellopoulos always good to hear that new firmware is being tested and its results are promising. Awesome!
                    S9PP 2.44.52
                      Brad_Olwin Moderator @Dimitrios Kanellopoulos
                      I can confirm way @Dimitrios-Kanellopoulos as I have been Field-testing the new firmware. We both agree the GPS is much better.
                        azeanic
                        Can confirm the latest GPS firmware is a lot better than previous iterations. I’m using Stryd for distance, so not sure about actual distance accuracy. But tracks are a lot cleaner and closer to where I’m actually running.
                          @surfboomerang I have not tested high speeds. Only up to 22km/h that is the fastest j can run.
                          MarynM surfboomerangS zvonejanZ 3 Replies Last reply Reply Quote 0
                          • MarynM Offline
                            Maryn Silver Members @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos let’s hope that this version stays as a release canditate.
                              @Dimitrios-Kanellopoulos I haven’t seen the speed wobbles in my running activities. Only on other profiles. I think it has something to do with a different log algorithm in the running profiles.
                                @surfboomerang we don’t use anything different (algo) between types.
                                It can be though the way you use your arms
                                freeheelerF N 2 Replies Last reply Reply Quote 0
                                  freeheeler @Dimitrios Kanellopoulos
                                  like “shocks” from waves and fusedspeed becomes confusedspeed?
                                  Fenr1rF Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                                    Shrek3k
                                    I am ready for an improved GPS (+ ×) software, too.
                                    I a challenging environment (weekdays I am running in Berlin, approx 30% of the route(s) between rather solid and high houses) pure GPS and/or GPS+ Galileo/Glonass are quite often a real disaster and only offering a ‘wobbling’ track. And it does not even help to activate the exercise type and wait for a few minutes after the position has been found(yes, minutes, which currently is not too cozy 😉 )
                                    OS - Android 16/Pixel Pro 7
                                    • Fenr1rF Offline
                                      Fenr1r @freeheeler
                                      @TELE-HO said in Suunto 9 with the recent GPS firmware was among least accurate GPS watches in today's 25K trail race:
                                      confusedspeed
                                      Bravo. Better than any Friday deserves.
                                        @TELE-HO GPS no. Speed distance yes though 😄 Only if GPS is off / lost / bad.
                                        There is also confusedTrack BTW 😄
                                        • N Offline
                                          nseslija Bronze Member @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos Interesting, I was convinced that there is different GPS algo for different sport modes… open water and cycling, for example…
                                          Ambit 2S
                                          Ambit 3 Peak
                                          Suunto 9 baro
                                            Dimitrios Kanellopoulos Community Manager @nseslija
                                            @nseslija well I said something wrong.
                                            For cycling/running no diff.
                                            For open water only yes there is a special mode.
