    Suunto 9 Firmware Update Suggestions
    64 Posts 33 Posters 4.7k Views 33 Watching
    • JorgeFDJ Offline
      JorgeFD
      so we need a Dimitrios who breaks NDA 😛
      BulkanB 1 Reply Last reply Reply Quote 2
      • BulkanB Offline
        Bulkan Moderator @JorgeFD
        @jorgefd78 I wonder what thinks @NickK
        • Andrzej DabrowaA Offline
          Andrzej Dabrowa
          1. Waypoint names displayed (not only types),
          2. Next waypoint name field that can be configured to be displayed on a training view (today only distance is avilable)
          3. Dedicated view (Ambit2/3 like) with next Waypoint name, distance and direction.
          sky-runnerS 1 Reply Last reply Reply Quote 5
          • ink357I Offline
            ink357
            Virtual partner !
              sky-runner Silver Members @Andrzej Dabrowa
              @Andrzej-Dabrowa I had exactly the same asks so many times (in this forum under a different name and on Facebook).
              Suunto should copy Garmin’s way of customizing navigation. When navigation is enabled 1-3 additional screens can be added, and fields on those screens can be customized separately. For example I customized an additional navigation screen to display next waypoint name, distance to next waypoint, and ETE. The best part is that when not navigating on a route that screen is automatically hidden. That is a simple and elegant solution - better than Suunto’s approach of adding navigation specific fields on regular sport screens.
              • MarynM Offline
                Maryn Silver Members
                you can make two sport profiles. One for use with navi and 2nd without.
                • GNZ ctG Offline
                  GNZ ct
                  • Customizable fields in watchfaces through APP, like workout fields are done
                  • More than one suuntoplus function at a time
                  ldxmsgL 1 Reply Last reply Reply Quote 2
                    sky-runner Silver Members @Maryn
                    @Maryn I did have special sport profiles with Navigation in the past when I used Suunto 9. But that is cumbersome because that would lead to multiplying of very similar sport modes. I ended up having something like this:
                    • Trail running with HR
                    • Trail running without HR
                    • Trail running with HR and navigation fields.
                    • Trail running without HR but with navigation fields.
                    Pretty soon it becomes unmanageable and error prone.
                    It is far more elegant to enable additional navigation specific screens, that are also customizable, only when navigation is enabled.
                    • ldxmsgL Offline
                      ldxmsg Bronze Member @GNZ ct
                      @GNZ-ct completely agree. I like steps on all watch faces and as a S9B owner feel unhappy that all other watches got this on the new face!
                      • ink357I Offline
                        ink357
                        Possibility to setup « climb » in suunto+. 10 m is really to low, my watch ring lot of time this morning.
                        I’ll go this week to 42kms, 3000D+ and i’m affraid for battery life if it vibrate any + or - 10 meters
                        Dimitrios KanellopoulosD cosme.costaC 2 Replies Last reply Reply Quote 0
                          Dimitrios Kanellopoulos Community Manager @ink357
                          @ink357 if will been not every 10m. Except if you go on a camel type mountain (lots of camels) 10m is just the threshold for the feature to kick in. You can go up 1000m and it will be only one hill counted.
                          zvonejanZ 1 Reply Last reply Reply Quote 4
                          • cosme.costaC Offline
                            cosme.costa @ink357
                            @ink357 As @Dimitrios-Kanellopoulos says it not counts a hill every 10 m. Today I tested it in a 10 km run with 383 m of ascent and it registered 8 climbs.
                            • zvonejanZ Offline
                              zvonejan Bronze Member @Dimitrios Kanellopoulos
                              @Dimitrios-Kanellopoulos said in Suunto 9 Firmware Update Suggestions:
                              thank you for that. My next question is what is the trigger to complete the climb which can be 10m or more hight.Maybe 10m descent?
                                A Former User @Storz
                                2 datafield screens. There are certain runs when all I need is pace and distance or pace and interval number…etc.
                                  Egika Platinum Member @Guest
                                  @zrumlow have you tried using the 3 field display and choose the empty field for the lower and smaller number?
                                  That should do it pretty well for you 👍
                                  Run Lime
                                    A Former User @Egika
                                    @Egika, that’s not the same, the font size is maintained, so all you’re doing is wasting screen space on an empty field.
                                      @zrumlow said in Suunto 9 Firmware Update Suggestions:
                                      I agree - not the same. But a solution for: “I only need two numbers”
                                      the lower field is smaller anyway, so not wasted too much space.
                                      I use it this way and can eaysily read the two big numbers at the short glance I get on my wrist when kayaking.
                                      Run Lime
                                      lexterm77L 1 Reply Last reply Reply Quote 1
                                      • lexterm77L Offline
                                        lexterm77 Bronze Member @Egika
                                        My wishlist after 7th September update of S9b
                                        • Andrew ChauA Offline
                                          Andrew Chau
                                          Here is a simple request… from a new Suunto 9 owner coming from Garmin F5 & F3.
                                          • Looped menu, when you hit the bottom of the list, you go back to the top. Instead of having to scroll all the way back up.
                                          As I play with the watch I’ll probably come up with more suggestions!
                                          freeheelerF F 2 Replies Last reply Reply Quote 3
                                            freeheeler @Andrew Chau
                                            @Andrew-Chau said in Suunto 9 Firmware Update Suggestions:
                                            I’m sure you will 🙂 search and vote, there are already very good ideas from experienced users 👍
