    Route navigation suunto 5
    navigationroutesroutesuunto 5
    23 Posts 5 Posters 2.7k Views 5 Watching
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel @S.Boardman
      @S-Boardman no, certainly not. You need the phone only for syncing. If the route is in the watch (and it’s the correct one), you should be good to go.
      You may have more than one route stuck in watch memory so it might require some more trial and error. I think that the watch can store up to 15 routes so it shouldn’t be that hard to flush them.
      I’d recommend unsyncing everything so that you can see there are 0 routes in watch. Then, remove all of them from SA and start from scratch.
      Synchronize each one independently (click send to watch and wait until the map stops flashing and there’s no sync indicator on the watch face).
      You can also try reinstalling SA (or just remove all app data, relogin, etc.) if it won’t help.
      If all else fails - hard reset will remove all routes in the watch.
      S9PP 2.44.52
        S.Boardman @Łukasz Szmigiel
        @Łukasz-Szmigiel thanks for your help
          Brad_Olwin Moderator @S.Boardman
          @S-Boardman Are you syncing with Suunto App once per day? Is the green GPS icon lighting up on the watch prior to your start? It is possible that you do not have a current AGPS file and the watch does not “know” where you are. The route will not show properly under those circumstances. To check AGPS on the watch go to Settings/General/About and make sure the AGPS file is current. If not you need to sync with SA and ensure GPS is optimized and a current (today’s date) AGPS file is present.
