    S9B - problem with battery modes
    16 Posts 6 Posters 832 Views 5 Watching
    • PavlasP Offline
      Pavlas
      I have a problem with battery modes.
      The Performance (1s interval) works fine. But when I set Endurance (60s interval) or Ultra (120s interval), it doesn’t work well.
      The watch still switches between Performance and Endurance (or Performance and Ultra).
      Here is a link to the activity where the Endurance mode was set.
      https://www.suunto.com/cs-cz/move/pavlas2/5f78525121ff1063d8efdd37
      I tried Soft reset and Factory reset. But the problem is the same.
      I have the latest firmware version
      Does anyone have a similar experience?
      🔺Vertical All Black
      ex:
      Ambit2 Black
      Ambit3 Peak Sapphire
      S9B All Black
      >>> YouTube Channel <<<
        What is the problem? To me it looks ok
        • PavlasP Offline
          Pavlas
          Until 0:21:44 is active Performance mode. Endurance mode is active from 0:21:44. But only until 0:27:13. Then Performance mode is active again. And again, from 0:30:21, is Endurance mode until the finish.
          🔺Vertical All Black
          ex:
          Ambit2 Black
          S9B All Black
          >>> YouTube Channel <<<
          • inkognitoI Offline
            inkognito Platinum Member @Pavlas
            @Pavlas S9 automatically switches to 1s GPS fix when you switch to the navigation screen. Isn’t this the case?
            SV: fingers crossed :D
              As @inkognito said.
              A little bit more detail:
              • When you start an activity for the first 1-12minutes until when the altitude is calibrated the perfomance mode is used.
              • When you switch to the navigation screen then performance is used.
              PavlasP 1 Reply Last reply Reply Quote 2
              • PavlasP Offline
                Pavlas @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos
                @inkognito
                No, I didn’t use navigation.
                Well, maybe the altitude was calibrated. But why did the Performance mode reactivate after another 6 minutes?
                I have this problem whenever I want to use Endurance or Ultra.
                🔺Vertical All Black
                ex:
                Ambit2 Black
                S9B All Black
                >>> YouTube Channel <<<
                  Dimitrios Kanellopoulos Community Manager @Pavlas
                  @Pavlas did you go to the breadcrumbs screen. ?
                    Brad_Olwin Moderator @Pavlas
                    @Pavlas This is an extremely short time frame for either Endurance or Ultra modes, as @Dimitrios-Kanellopoulos stated, it may take time for the FusedAlti to activate. I typically don’t use Endurance for anything less than 20h and Ultra for anything around 48h long.
                    PavlasP 1 Reply Last reply Reply Quote 0
                    • PavlasP Offline
                      Pavlas @Brad_Olwin
                      @Brad_Olwin This was just a test. In fact, I usually only use Performance mode. I just want to know if there’s a mistake in the watch.
                      Do you mean a navigation screen without navigation? Yeah, I switch to it sometimes, but maybe for only 1-2 seconds. (to return to the first screen). Can it have an effect?
                      🔺Vertical All Black
                      ex:
                      Ambit2 Black
                      S9B All Black
                      >>> YouTube Channel <<<
                        @Pavlas yeah that turns the GPS to best in order to show you your current location in relation to your track.
                        Remember, Ultra + Endurance modes turn on the GPS every 1minute or 5 minutes (ULTRA).
                        So when you go to that screen it will enable the GPS, then when you leave, turn it off after a few and back on again.
                        If you want to avoid that while toggling screens , you can turn “nagivation off” from breadcrumbs, and that should not happen then.
                        PavlasP 2 Replies Last reply Reply Quote 2
                        • PavlasP Offline
                          @Dimitrios-Kanellopoulos Okay, I’ll try it! 🙂 Thanks a lot!
                          🔺Vertical All Black
                          ex:
                          Ambit2 Black
                          S9B All Black
                          >>> YouTube Channel <<<
                          • PavlasP Offline
                            @Dimitrios-Kanellopoulos Hi, I tried it and it works!
                            BTW Suunto support wanted me to send the watch for service. In the end, it was my fault.
                            Thank you!
                            🔺Vertical All Black
                            ex:
                            Ambit2 Black
                            S9B All Black
                            >>> YouTube Channel <<<
                              @Pavlas said in S9B - problem with battery modes:
                              Thank you!
                              I tested my battery the last couple of weekends in Endurance mode for 3.5h to 6h runs. GPS only + smartsensor +Route loaded no SuuntoPlus my battery estimate on the watch was 50h and on QS was 45h. So, according to my tests all is working as expected.
                              stromdiddilyS 1 Reply Last reply Reply Quote 3
                              • stromdiddilyS Offline
                                @Brad_Olwin just a couple of 3.5 to 6 hour runs, no big deal 😛
                                  johann.fuehrer Bronze Member @stromdiddily
                                  @stromdiddily said in S9B - problem with battery modes:
                                  … sprint training … 👍 👟
                                    @stromdiddily @johann-fuehrer Yes, my average weekend runs in the winter are 4-7h, shorter than my weekend training in the summer:). Once SkiMo gets going full swing here, I’ll have longer days…
