    Suunto Plus Climb (Hill training) and grade in %
    19 Posts 8 Posters 1.9k Views 8 Watching
    • pilleusP Offline
      pilleus
      Watch: S9B
      Activity: Cycling, mountain biking
      Suunto Plus: Climb activated
      While climbing a hill the grade of the uphill is shown in %, the value is spot on, no great delay to the real incline.
      At the top of the hill it will take up to 30 seconds untli the grade of the uphill will decrease number by number in %, the way is flat and no up and down.
      Often there is a way of 500 meters done, before the grade will show the actual grade of 0 % on a flat terrain after the uphill.
      I use a Polar Grit X Pro too, there is a hill splitter available and a very fast and accurate value of the actual grade in %. Much more faster than on my S9B.
      A problem of my watch or of the system?
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
        Dimitrios Kanellopoulos Community Manager @pilleus
        @pilleus that’s ok. Vertical speed is averaged from 10s to 30s.
        pilleusP 2 Replies Last reply Reply Quote 1
        • pilleusP Offline
          pilleus @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos said in Suunto Plus Climb (Hill training) and grade in %:
          An option to adjust the calculation for cycling/mountain biking to a lower average (max. 10 seconds) would be great. For me the average up to 30 seconds is okay for hiking and trailrunning.
          • pilleusP Offline
            Climb hill as a S+ feature is behaving identical on S9Baro and S9Peak? Or is there a difference on different watches?
            Thanks for an information!
            EfejotaE 1 Reply Last reply Reply Quote 1
            • EfejotaE Offline
              Efejota Bronze Member @pilleus
              @pilleus it works the same. And the behavior in slope incline is the same, under my experience. I had the same feeling. It would be a good addition if the vertical speed could be averaged faster when cycling. Not a big deal anyway (excepto in short, very steep slopes)
              • pilleusP Offline
                pilleus
                Now I could test the climb function of S+ on a S9 Peak and the responsibility is much better than on the S9B. It is fast and in my opinion nearly a little bit nervous. The sport mode was the predefined cycling mode with S+ climb activated.
                Any ideas?
                Thanks!
                  freeheeler @pilleus
                  @pilleus
                  I’ve used the hill climb today to “play” a little bit with it again. (after using burner frequently…)
                  I noticed that the hill climb is very sensitive, especially for cycling in rolling terrain. (ok, I’ve had baro holes covering issue again today, that made it even more nervous…).
                  I’ve had autolaps activated and had the idea that either with hill climb the autolaps could be deactivated when activating S+? OR hill climb laps should appear in a different color.
                  also the hill climb lap screen shows the same data as autolaps… for hill climb I would expect different values.
                  But I think the lap screen itself is controlled by the activity, not by the S+ feature… even it would make sense to be controlled by S+ 🙂
                  and more important: I would love to be able to select several S+ features at a time. I would use hill climb AND burner 🙂
                  suzzloS 1 Reply Last reply Reply Quote 3
                  • suzzloS Offline
                    suzzlo Moderator @freeheeler
                    @freeheeler said in Suunto Plus Climb (Hill training) and grade in %:
                    Same here!!!
                    At least selecting a Suunto Plus Guide + Suunto Plus Feature!!!
                    Garmin: FR745, Edge 530
                    SA topics:
                      DMytro @suzzlo
                      @suzzlo wasn’t that already beta tested by suunto and proven to be to difficult for the watch to handle?
                        isazi Moderator @DMytro
                        @dmytro that’s probably not coming to current watches, there’s not much resources available right now. But I’m not 100% sure and may be wrong.
                          DMytro @isazi
                          @isazi that is what I meant.
                          • suzzloS Offline
                            suzzlo Moderator @DMytro
                            @dmytro @isazi a 2020 proccesor cannot afford to have 2 parallel Suunto Plus features? I was hopping that it was a problem more in SW area 😔😔😔
                            SA topics:
                              DMytro @suzzlo
                              @suzzlo I think s9p wasn’t necessary marketed as a successor more like a younger sibling.
                              • suzzloS Offline
                                @dmytro I’m not talking about mobile sagas, just about which HW include in a 2021 year.
                                According to my Google search:
                                • S9P was launched in June 2021
                                • S9 was launched in June 2018
                                They have different HW, at least Bluetooth had been updated, and I hope also memory and proccesor, so this is why I feel that S9P should be more capable than S9 and be able to run 2 Suunto Plus in parallel
                                BR
                                SA topics:
                                freeheelerF DMytroD 2 Replies Last reply Reply Quote 2
                                  freeheeler @suzzlo
                                  @suzzlo said in Suunto Plus Climb (Hill training) and grade in %:
                                  would be nice, I’d appreciate and also use that frequently 🙂
                                  with ambit we could use up to 5 apps… but I don’t want to dig around in the past and say that everything was better in ancient days 😂
                                    DMytro @suzzlo
                                    @suzzlo you could be right - it also has smaller display resolution, so less stressful for the processor as well. We will see, how the things turn out I guess.
                                    K 1 Reply Last reply Reply Quote 2
                                    • K Offline
                                      Kramble @DMytro
                                      Hi, I can’t select the Climb Suunto plus app anymore on my S9 peak. It’s ok with Safe or Burner…but when I touch on Climb it doesn’t appear and the field Suunto plus is empty on the setting screen of my activity.
                                      I tried to remove it from th watch with Suunto app but when I selected it again to put it in the watch, the problem remains the same on the watch. I see it but I can’t select Climb.
                                      Do you have something similar?
                                      Ambit 3 peak saphir
                                      Spartan Ultra (sold)
                                      S7 graphite copper
                                      S9 peak all black
                                      Wings
                                        freeheeler @Kramble
                                        @Kramble
                                        yes, it seems that @Tieutieu faces this issue frequently. not sure if it is still the case for @Tieutieu ?
                                        https://forum.suunto.com/topic/8401/software-update-2-23-20-all-s-watches-except-s9-peak-pro/93?_=1673193588806
                                        • K Offline
                                          Kramble @freeheeler
                                          @freeheeler thanks 👍
                                          Ambit 3 peak saphir
                                          S7 graphite copper
                                          S9 peak all black
                                          Wings
