    Suunto Spartam GPS problem
    12 Posts 5 Posters 2.9k Views 5 Watching
    • Michal CzekajM Offline
      Michal Czekaj
      I have a problem with GPS in my Suunto Spartan Ultra. My Spartan can’t find the signal of GPS. I made reset hard and soft still doesn’t work.
      I use Ambit 3 sport and Spartan Ultra. Ambit3 works perfectly, but Spartan failure last few weeks.
      Any ideas about what happened?
      Is it time to move on Garmin?
      • Mff73M Online
        Mff73 @Michal Czekaj
        @michal-czekaj
        Do you have AGPS information in the watch?
        Settings / général / about. Is there a recent date?
        SSU (retired), SV1, SV2
        Android + Galaxy S205G
          Sylvain Pepin @Mff73
          @Mff73 hi, I have exactly the same issue with my SS whr Baro, since ~1 month, the AGPS value = N/A
          I tried soft reset, hard reset…nothing solved the issue
          The worst is sometimes the watch cashed, I get update logo on the screen and I must restart it…
          I don’t if the prob is software or hardware…
          I very desapointe, all functions are working correctly…
          if someone can help, i’d appreciate
          thanks,
          Sylvain
          sartoricS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
            sartoric Moderator @Sylvain Pepin
            @Sylvain-Pepin
            I have no problem with agps. My Spartan is always up to date (as soon as I sync with Suunto app)
            As a note, agps data are deleted when you do soft reset, so you need to sync
            Did you try to contact support?
            SVTS - 2.50.28
              Dimitrios Kanellopoulos Community Manager @Sylvain Pepin
              @Sylvain-Pepin try to see if there is some firewall or something blocking the AGPS sync. Else the issue can be in the GPS chip
              sartoricS S 2 Replies Last reply Reply Quote 0
                or try to sync via mobile and SA to avoid using local network
                SVTS - 2.50.28
                  Sylvain Pepin @sartoric
                  @sartoric I tried the both, I ran the sync on my own pc and iPhone I didn’t notice error, the sync looks ok…
                    Sylvain Pepin @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I’m really afraid about a hw issue 🤕
                    • Mff73M Online
                      Mff73 @Sylvain Pepin
                      @Sylvain-Pepin
                      do you see this step screen on SuuntoLink PC , saying GPS optimization ?
                        @Mff73 yes ! the synchro looks ok… I don’t notice error alert…but AGPS value doesn’t change, it’s still n/a !
                        • Mff73M Online
                          @Sylvain-Pepin
                          so, and just out of logic, like Dimitrios said, if it is not software, it could then be hardware and then you are not lucky.
                          AGPS is ““only”” assisted GPS, watch could theorically find GPS lock without external data, just little longer.
                          Maybe worth trying to put your watch in clear sky, searching for GPS veryyyyyyyyyyyyy long time and see at least if it is finding something.
                            @Mff73 yes, i’m afraid about a hw issue 😖
