    Compass loses calibration after charging
    compasscalibration9 peakissuedefectbug
    24 Posts 7 Posters 4.4k Views 6 Watching
    • SimonS Offline
      Simon Bronze Member
      As soon as my S9P Titanium comes in contact with the charger, it loses its compass calibration. Rather obviously, this is caused by the magnet inside the charger - and will very likely happen with any magnet.
      This only seems to happen when the watch is active (recently pressed a button, or in navigation/activity mode…). When the watch is idle (when it no longer reacts to touch), it doesn’t seem to be affected by the magnet.
      I realized, when in navigation mode, I can recalibrate the compass by making the figure 8 with the watch - even though compass calibration is not explicitly asked for. And the fact that the watch doesn’t ask for it, is a bigger issue, because I don’t know when the compass is off. And it’s not just by a bit, but it’s fully unreliable and sometimes jumping around.
      Does anybody else have this issue? I can’t remember having this before the last firmware update, but I may just not have noticed it …
      S9P Ti - ex Altimax, A3P, SV Ti
        Brad_Olwin Moderator @Simon
        @simon Happens with any magnet, the watch will ask when needed
        SimonS 1 Reply Last reply Reply Quote 0
        • SimonS Offline
          Simon Bronze Member @Brad_Olwin
          @brad_olwin Thanks for your teply. But it doesn’t ask for re-calibration, even when the compass is jumping around like crazy. That’s the actual problem.
          Also, if every charging offsets the calibration, that would be a bit weird/ annoying.
            @simon said in Compass loses calibration after charging:
            I have magnets on my pack. Whenever the watch gets too close I have to recalibrate. Having to do so after charging is nowhere near as annoying as calibrating every 20 min during a ≥24h race.
            • SimonS Offline
              @brad_olwin 😂 Sure - still, is it normal that the calibration is off after just charging, while there is no activity, navigation or the compass itself shown? That would mean that everybody needs to recalibrate it after charging…
              And why doesn’t the watch ask for re-calibration, even when the compass isn’t working at all…?
                @simon If you don’t need the compass you will not need recalibration. I think as simple as that.
                SimonS 2 Replies Last reply Reply Quote -1
                • SimonS Offline
                  @brad_olwin Maybe we have have some misunderstanding: I do need the compass urgently. Navigation is the main reason I’ve decided for the S9P. But when the direction is wrong (and it really is completely wrong), it’s impossible to use.
                  While moving constantly in a higher pace, the map orients itself in the direction of movement, which is great and working. But when I stop, the map rotates in the compass direction. But if that’s off, that’s really bad! And as mentioned, the watch doesn’t seem to recognize that the compass needs recalibration.
                  Is this a case for Suunto service?
                  • SimonS Offline
                    @brad_olwin I do feel like my issue is not explained or not read properly. My questions are just not answered - and I’m a bit disappointed now, given that I do help out in this forum when I notice a question that I can help with.
                    BulkanB Brad_OlwinB 2 Replies Last reply Reply Quote -1
                    • BulkanB Offline
                      Bulkan Moderator @Simon
                      Why the watch is not asking? I think the watch ask for recalibration when compass is not working properly, One thing is the magnets affect compass and the other recalibration.
                      I don’t get the case and I read the threat. Is because is not asking to recalibrate? But I assume you are using the compass somehow. Maybe without an activity? Sorry if I don’t understand it well.
                        I think I have been quite clear, if you need to use the compass either as a compass or for navigation or for Endurance/Ultra modes and it needs calibration the watch will ask for calibration. If the compass is not needed the watch will not ask for calibration. It is as simple as that. Magnets, including the charger will require the compass to need calibration. I do not understand why you have an issue. If you are in an area with metal (buildings, cars, etc.) the compass will not work well, open space with no large metal structures nearby. Every time I need the compass, I am asked to calibrate by the watch. I hope this helps.
                        AudaxjoeA 1 Reply Last reply Reply Quote 1
                          Strange, my compass always asks for calibration, basically every time I charge the watch. It automatically calibrates after a while if using it, but it may calibrate wrongly and in that case you can start a manual calibration (it’s in the navigation menu if I’m not wrong).
                          • SimonS Offline
                            Simon Bronze Member @isazi
                            @isazi Thanks isazi. To make my issue clear: My watch does NOT ask for calibration. Basically never! Even if the compass is not working at all!
                            Again: Does the unit need to go to Suunto service?
                            • SimonS Offline
                              Simon Bronze Member
                              In the end, I see that the watch is not behaving as expected. Is there anything I can do? Or do I need to get in touch with Suunto for warranty/service? If so, how?
                                sartoric Moderator @Simon
                                How can I be any clearer with this issue??
                                I guess it’s clear enough, and it’s clear too that others do not have the same issue.
                                So what do you expect as an answer ?
                                If you think your watch it’s defective, contact Suunto support via website and ask for a check/repair.
                                SVTS - 2.48.16
                                Suunto App Android 6.4.7 beta
                                • SimonS Offline
                                  Simon Bronze Member @sartoric
                                  @sartoric Thanks, I will 🙂
                                    isazi Moderator @Simon
                                    @simon you can also contact support via the app.
                                    • AudaxjoeA Offline
                                      Audaxjoe @Brad_Olwin
                                      @brad_olwin This really isn’t my experience, sometimes it does ask others it doesn’t. am when in an activity I can see no way of celebrating the compass unless the watch askes. And as mentioned it often does not ask.
                                      Suunto 9 BARO
                                      Garmin Fenix 3, 5
                                      Suunto Vector
                                      isaziI SimonS 2 Replies Last reply Reply Quote 0
                                        isazi Moderator @Audaxjoe
                                        @audaxjoe if you move it doesn’t ask. You need to stop.
                                        AudaxjoeA 1 Reply Last reply Reply Quote 2
                                        • SimonS Offline
                                          Simon Bronze Member @Audaxjoe
                                          @audaxjoe You can actually make the same movement with your wrist like you do for calibration (this figure eight) DURING an activity and it will calibrate your compass. Good to know. Sad that nobody here nor the manual give this very useful hint!
                                          Also, it looks to me like very, very poor engineering work when the compass loses calibration that easily. My Ambit3 Peak asked me once. And that was it! The compass was spot on for years to come. Same with a Coros Apex.
                                          Almost funny - but also very sad - that Suunto opted for a magnetic charging cable with this flawed compass issue.
                                          Please pass this on to Suunto engineering.
                                          • inkognitoI Offline
                                            inkognito Platinum Member
                                            I have similar experience with my S9 (non-baro). Compass indeed sometimes (actually quite often) looses calibration and it doesn’t ask for it. I usually rely on the route navigation in my watch during my hikes and I definitely hiked more than 1500 km with it. My findings are as follows:
                                            1. There are cases when compass somehow reacts but you can recognize the calibration is wrong. As it does something while you spin around, the watch probably thinks it’s calibrated. But it’s not.
                                            2. Making the eight figure with my wrist when I’m on the navigation screen does not usually recalibrate it for me (trust me, I often look like an idiot, waving my hand for one minute in various ways only to find out it didn’t work 😄 ).
                                            3. What actually works is putting my watch close to any magnet for a moment. Then it recognizes the calibration is now totally off and the recalibration is triggered 😄
                                            So, the ability to trigger the recalibration manually would be much appreciated. Especially when we have such nice things as bearing navigation (which is useless when your compass is not calibrated and your watch doesn’t know it).
                                            SV: fingers crossed :D
                                            isaziI SimonS 2 Replies Last reply Reply Quote 5
