    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 422.8k Views 126 Watching
      suuntastic Bronze Member @Łukasz Szmigiel
      @Łukasz-Szmigiel so, sure nothing changed from first production versions last year to now (recent production versions)? Then I will wait.
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @suuntastic
        @suuntastic it’s a fantastic watch overall.
        It’s just mind boggling how can such thing be a non-issue while field and quality testing. The watch is assembled well, materials are premium, it looks and feels premium, and it buzzes like a 5 bucks child’s toy.
        S9PP 2.44.52
        S Brad_OlwinB 2 Replies Last reply Reply Quote 1
          @Łukasz-Szmigiel 100% agree. I do not have to change immediately from s9p, which is still fantastic…
          • HighlandsH Offline
            Highlands
            Been waiting for 10 days or so to share this. Before the last update the oHR was so terrible for me, I had begun to not paying attention to it anymore. I usually use H10, so I had given up on the oHR of my 9pp anyway. After the last update I started to notice that the oHR wasn’t the same. Yes, it took me time to actually notice it. As my H10 broke - strap is kind of torn and the sensor started to drain a new battery in just one week if I don’t get it out. Since this happened I don’t use the H10 (have to buy a new one) and I use the oHR of both my watches. The other watch is pretty much in line with H10. But the real surprise came after the update when the oHR of my 9pp started to give me way more plausible data. Haven’t paid attention to what the change log of the current update says but now I have more or less (yes, it has its pitfalls) working oHR. I’m not saying I’ll give up using a strap. I haven’t changed anything else. I wear the watch exactly the same way. So, the update brought one more good thing for me.
            SV2&SV1
            ? 1 Reply Last reply Reply Quote 5
              A Former User @Highlands
              @Highlands yep and with a velcro strap it’s even better!
                Brad_Olwin Moderator @Łukasz Szmigiel
                @Łukasz-Szmigiel said in Suunto 9 Peak Pro?:
                It was noted in field testing. The testers do not have decision making power, they simply report issues. Suunto decides whether or not the issue is fixable/ worth pursuing/etc.
                  Łukasz Szmigiel @Brad_Olwin
                  @Brad_Olwin regardless. It went to production, I’m not blaming testers personally.
                  S9PP 2.44.52
                    altcmd Silver Members @Łukasz Szmigiel
                    @Łukasz-Szmigiel and has been rendered unimportant to be addressed since.
                      Łukasz Szmigiel @altcmd
                      @altcmd but at last we have brand-new brightness controls, every other firmware release.
                      S9PP 2.44.52
                        @Łukasz-Szmigiel As much as I love Suunto and would not wear any other watch, unfortunately I would say this is obviously a design flaw. Not adequate to superior build quality of watch. Why be comfy with a lot of sendings back (if I read comments here and Amazon) and also with the situation sitting close to a couple of people and they are laughing about the watch because of noisy buzz…? In my mind this is not Suunto adequate and Suunto should fulfill also this premium requirement. Why shouldn’t Suunto not? Suunto is high level good with most other things…
                          suuntastic Bronze Member @suuntastic
                          Today saw the Vertical. Wow what a watch! Great job! Will skip S9PP definitely and go from S9P straight to Vertical 🙂 it seemed vibrations are good 🙂
                            Brad_Olwin Moderator @suuntastic
                            @suuntastic Yes, I agree vibrations are great on the Vertical.
                              Łukasz Szmigiel
                              It seems that the watch is using performance battery mode when the navigation screen is displayed, regardless of setting the battery mode to endurance.
                              I remember that we’ve talked about it here. Did anything change with latest firmware or is it intentional in the same way as eta/ete used to work?
                              S9PP 2.44.52
                                MKPotts Bronze Member @Łukasz Szmigiel
                                @Łukasz-Szmigiel
                                I had a similar experience running a 51hr race in April (so on previous firmware).
                                Checked my watch battery after about 35hrs and it was down to about 25%. I had OHR & sensors turned off, so this battery burn rate is consistent with what I’d expect in performance mode. But the watch was in endurance mode and recorded data consistent with that.
                                I had fields for distance/time to waypoints on one screen and route navigation active (watch was mainly on the breadcrumb screen).
                                I’ve not used endurance mode with the latest firmware, so I don’t know if it’s changed.
                                  Łukasz Szmigiel @MKPotts
                                  @MKPotts it seems that the watch is indeed switching to performance when in navigation view. I wonder why, if the user decided explicitly that the battery life is a priority
                                  S9PP 2.44.52
                                    surfboomerang @Łukasz Szmigiel
                                    @Łukasz-Szmigiel I guess because for navigation a 1 sec GPS fix is necessary. Endurance mode on the S9 series is 10 sec if I’m not mistaken.
                                    For the SV this is different. Performace is 1 sec fix with dual band. Endurance is 1 sec fix with single band.
                                      Łukasz Szmigiel @surfboomerang
                                      @surfboomerang I know. It’s just that 9PP has 1s fix in performance and endurance. And if the same behaviour is present in SV the difference can be even bigger if it’s switching to the best battery mode on navigation screen.
                                      Imagine that you’re going on a long trip when you want to use navigation and you set your watch to most energy efficient battery mode that provides 1s fix only to notice day later that the battery has run dry.
                                      S9PP 2.44.52
                                        A Former User @Mff73
                                        @Mff73 I have seen that it is possible to change the order of the widgets on SA but if I visit the widget menu on the watch the order is not congruent with that of SA.
                                        Not a problem of course, just saying
                                          Highlands
                                          https://www.sport-conrad.com/en/products/suunto/9-peak-pro-sc-3.html
                                          400€ for a 9PP Titanium.
                                          SV2&SV1
                                          Felix FelicisF 1 Reply Last reply Reply Quote 0
                                          • Felix FelicisF Offline
                                            Felix Felicis @Highlands
                                            @Highlands I paid 320€ for my 9pp titanium 🙂
